Electronics Forums
Electronics Forums > Newsgroups > Electronics Newsgroups > Electronic Repair > Sony KV-27EXR25 just clicks, (STRS6301 to "A" or not to "A")
Reply
Thread Tools Display Modes
Lenny
Guest
Posts: n/a
      03-02-2004, 02:12 PM
This set clicks, the degausing coil energizes and thats all. Almost
every solder joint on the power supply board was cold. The Hor out in
circuit does not look shorted. I repaired the solder and the set is
still dead. There is an STRS6301 on the power supply board. I have
seen a few of these bad over the years and usually just replacing them
restores proper operation. However lately I've been reading about the
"A" version of this chip as being improved or better. Then again in
some forums it seems that its not recommended to replace an original
with an "A". Does anyone have any further insight on this? Also not
having a schematic, does anyone have a straight forward
troubleshooting procedure for this chassis or perhaps a published tip
on it that they could possibly share with me? Thanks very much for any
assistance you may be able to offer. Lenny Stein, Barlen Electronics.
john
Guest
Posts: n/a
      03-02-2004, 05:08 PM
Lenny !
Reflow all solder connections on that Module
also ESR all the caps especially thosw close to
the Heat sink.I have always used the STRS6301A
with 100 percent success.
kip
"Watch the return E-Mail addy its false"
"Lenny" <(E-Mail Removed)> wrote in message
news:(E-Mail Removed) om...
Sofie
Guest
Posts: n/a
      03-02-2004, 08:20 PM
Lenny:
The reply by John/Kip is absolutely correct about the "A" version of the
chip...... 100% success.....
.....and be absolutely certain to ESR check all the electrolytics on the
power supply board.... check and reflow any and all questionable solder
joints.... especially near and around the high heat producing parts like
power resistors, diodes, chips, etc...... AND also on the main pcb look
for bad solder joints on the flyback and HOT and the power resistors,
especially near and around the flyback derived B+ circuitry and the main B+
distribution paths.
Best Regards,
Daniel Sofie
Electronics Supply & Repair
"john" <(E-Mail Removed)> wrote in message
news:newscache$ixkyth$cko$(E-Mail Removed).. .
> Lenny !
> kip
RonKZ650
Guest
Posts: n/a
      03-02-2004, 09:44 PM
Yes, but is there a difference in the "Sony A" for $30 or the "generic A" for
$7? I'm going to find out next Sony I work on. The last 2 generics I replaced
were running over 160 degrees F. I think that's really too hot. I'm anxious to
compare the original Sony. Sony still sells both the STRS6301 and 6301A as a
different part number.
Ron
Sofie
Guest
Posts: n/a
      03-02-2004, 11:26 PM
RonKZ650:
I think we will all be interested in your future posting with the comparison
testing results.
"Running too hot" has NEVER been an issue with the $7 "generic" or rather,
after market replacements I get from my jobber. 100% OK.
The markings on the replacement chips that I have always obtained from my
jobber @ $7 appear to be the same as the more expensive Sony supplied
chips.... it looks to me like the SAME manufacturer and almost definitely
NOT some cheapo Hong Kong, inferior, rip-off.with obvious cosmetic
challenges that we are all familiar with.
Best Regards,
Daniel Sofie
"RonKZ650" <(E-Mail Removed)> wrote in message
news:(E-Mail Removed)...
for
replaced
anxious to
a
> Ron
RonKZ650
Guest
Posts: n/a
      03-03-2004, 01:58 AM
>RonKZ650:
>testing results.
I meant to also mention I did the test on RCA STR730 series regulator ICs last
month. On same set, same meter setup, the original RCA STK 730-030 ran 5
degrees cooler at peak, then a generic STK730-150. It also drew less current at
standby, less at normal on conditions, as well as regulating a dead on 140v
where the generic was close to 142v.
I'll post the STRS6301 results soon.
Ron
Tim Marcus
Guest
Posts: n/a
      03-03-2004, 04:31 AM
TELEVISION*
SONY*
KV27EXR25*
DEAD?CLICKING NOISE, B TOO HIGH*
CHECK R673 4.7 FOR OPEN*
TELEVISION*
SONY*
KV27EXR25*
DEAD, CLICKS, SWITCHING XFMR HAS NO POWER OUT-BOARD G*
REPLACE IC651 STRS6301, R656 560, Q611 2SC3311A*
I have repaired several of these - first I swap out the str regulator,
which is almost always bad. Then take care of the cold joints. If that
does not do it one of these 2 tips probably will. best of luck - Tim
"Sofie" <(E-Mail Removed)> wrote in message news:<(E-Mail Removed)>...
> RonKZ650:
> testing results.
> Best Regards,
> Daniel Sofie
> for
> replaced
> anxious to
> a
> > Ron
Leonard Caillouet
Guest
Posts: n/a
      03-03-2004, 01:15 PM
If you are going to make comparisons, why not compare the generic vs the RCA
in the same version of the chip?
Leonard
> >RonKZ650:
comparison
> >testing results.
last
current at
140v
> Ron
Lenny
Guest
Posts: n/a
      03-03-2004, 02:31 PM
Thanks to everyone for the advice. I'm ordering the A version today
and then I'll dive back in. Best regards, Lenny Stein, Barlen
Electronics.
(E-Mail Removed) (Tim Marcus) wrote in message news:<(E-Mail Removed). com>...
> TELEVISION
> SONY
> KV27EXR25
> TELEVISION
> SONY
> KV27EXR25
> > RonKZ650:
> > testing results.
> > Best Regards,
> > Daniel Sofie
> for
> replaced
> anxious to
> a
> > > Ron
TKL
Guest
Posts: n/a
      03-03-2004, 05:41 PM
My set KV34MN11 also have same CLICKing problem, no screen & sound when
power on. Can i try the same solution? Pls help, thks in advance.
> Electronics.
> > TELEVISION
> > SONY
> > KV27EXR25
> > TELEVISION
> > SONY
> > KV27EXR25
> > > RonKZ650:
comparison
> > > testing results.
rather,
my
definitely
> > > Best Regards,
> > > Daniel Sofie
"generic A"
> > for
> > replaced
> > anxious to
6301A as
> > a
> > > > Ron
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
$BnyS4;:IJ(BIGCT$B!"(BIGBT$B!"(BGTR$B!"(BIPM$B!"(BPIM$B!"2D95(B$Bbk!"@0N.66!"2w2zJ#Fs6K4I!"Fp2zJ#Fs6K4I(B. 〓專業IGBT銷售〓 Electronic Design 0 10-11-2008 07:34 AM
Medical Records On Escorts Darya "Dasha" Gunchenko and Rajni "Sonia"Parmar - RELEASED ffxff Electronic Repair 0 06-26-2008 12:50 AM
Re: Arny Krueger deliberately sabotages ABX "I don't really have a replacement career," Morein said. "It's a very gnawing thing." Robert Morein Hobby Electronics 13 10-08-2005 03:37 AM
Whats the difference between "resolution" and "effective no of bits" for Analog to Digital Converter sagar Electronic Basics 2 07-23-2004 04:05 AM
SONY 32" KV-32XBR37: Schematics, REAR COVER and "W" CIRCUIT CARD need Steevo Electronic Repair 1 11-25-2003 06:07 AM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33
