Electronics Forums
Electronics Forums > Electronics Forums > Electronic Projects > Solar Dragsters project - need advice
Reply
Thread Tools Display Modes
Junior Member
      02-28-2013, 12:53 AM
Hello everyone!
I'm researching the feasibility of an idea I had for a school science fair project. I want to make little solar drag racers to demonstrate the concepts of light -> electricity with a photovoltaic cell and how capacitors work.
My knowledge of electronics is very limited. I only understand the concepts of how components work (caps, resistors, etc).
The cars are based on this: http://blog.makezine.com/2012/05/03/...-this-weekend/
That project isn't very exciting though because the vehicle barely moves. When the caps discharge, it moves about 10mm every 5 seconds or so.
I would like to make them faster, either by discharging the caps more frequently or with a bigger discharge. They would be powered by a 4.5v 90mA solar cell. Any suggestions?
Super Moderator
davenn's Avatar
      02-28-2013, 02:22 AM
well the power generated and that is discharged by the cap is goverened by the solar panel
so 3 choices....
much more light or
bigger solar panel or
both
if what is seen in the video is the same as what you are getting with your one
and it looks like its outside in the sun?
then a bigger solar panel is your only choice
No Mathematical model can ever predict my wife's mood swings
When all else fails.... Read the instructions!
Senior Member
      02-28-2013, 06:15 PM
A 4.5V 90ma solar cell should be enough to run a small motor continuously. Here is an example of one that should work.
http://www.karlssonrobotics.com/shop...FQdU4AodgAcAKA
Junior Member
      02-28-2013, 08:59 PM
My solar cell is larger than the one in the video. Also, the motor BobK suggested below looks like a perfect match for it! Thanks for the help guys!
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
Bicycle project - Need help designing circuits and advice on the project. FixedG3ar Electronic Projects 4 10-26-2012 05:00 PM
Newby project idea for HND main project help and advice needed please wiganwez Electronic Projects 13 09-20-2011 10:13 PM
I need advice on a project im building jacob88 Circuit Help 9 04-15-2011 01:42 PM
Need Advice on a 10x1W LED Strobe Project natejp Electronic Projects 4 05-04-2010 12:05 AM
Need Design Project Advice kfmuelle@gmail.com Security Alarms 17 05-31-2007 03:44 PM
