"jean-marc MERCY" <(E-Mail Removed)> wrote in message
news:2003912-112118-(E-Mail Removed)...
> I am starting to work on smps and my goal is to achieve an output
> ranging 250~300 volts. Power would be 250w or less. Are there any
> (non-obvious) pitfalls I should be aware of with such a voltage
> level. One of my concerns is rectifiers, the other is insulation.
> Would anyone out there have any expertise/advice ? General discussion
> can be carried out here, private one to my email.
> Thanks
> Ce message a ete poste via la plateforme Web club-Internet.fr
> This message has been posted by the Web platform club-Internet.fr
> http://forums.club-internet.fr/
Without more details about topology and whatnot you plan to use, there are
two general hints I might suggest.
Absolutely positively make certain that you use very effectual fast (IE,
pulse by pulse, something that can respond in say less than 10us and keep
the duty cycles thereafter to around 1% or less thereafter) current limiting
scheme capable of providing full protection from indefinite output short
circuits. Include this current limiting right from the very beginning,
don't wait until you've blown up several iterations of prototypes before
doing this.
The other thing I would suggest is to not get carried away with seemingly
good diode ratings. Some device like the UF4007 (1A 1000V very fast
recovery) is NOT appropriate for your output rectifier even though your
output voltage and currents are well within the datasheet ratings of the
device.
As you increase the blocking voltage of the diode, the reverse recovery
charge (don't worry too much about the "reverse recovery time" figure,
mainly it is the reverse recovery charge figure that determines the losses)
goes up quite a bit. Ultrafast diodes rated 200V and below can have some
pretty good reverse recovery charge figures, but when you start playing with
higher voltage rated parts like beyond 300V, the reverse recovery charge
gets rather substantial. Complicating this fact further is the increased
voltage stress caused by the higher blocking required in your high voltage
output application.
If you can figure out the reverse recovery charge of your diodes under your
operating conditions (use figures of 125 deg. C, the 25C values are much
smaller than real world will likely be), which will be measured in coulombs,
then multiply by the frequency they will see (measured in inverse seconds)
and you will get a product with the units (coulombs/second). You will find
those units are the same units for current, so you effecively get a somewhat
equivalent rms reverse recovery current given your switching frequency.
Then multiply this rms reverse recovery current figure by the reverse
applied voltage (in your case probably say 30% greater than 300V or 600V
depending upon your circuit topology and input voltage variation margin) to
find a power loss figure due to rectifier reverse recovery. The power will
be dissipated in both the power MOSFET(s) in your circuit as well as the
rectifier itself.
So as you might be able to see from the above, when you try to make SMPS
devices with high output voltage you end up with a double whammy in terms of
diode losses getting dramatically worse when compared against lower output
voltage switch mode power supplies.
As a result you need to operate at a lower frequency than powersupplies with
5V or 12V outputs (using nice schottky diode technology) to obtain best
efficiciency (or perhaps in some cases just to stay within the power
dissipation ratings of the output rectifier). Given your conditions I
suggest the output rectifiers should see a frequency of say something in the
range of 50kHz to 100kHz (so in say a half bridge the main MOSFETs should be
switching at 25kHz to 50kHz). This is unfortunate in that it makes your
magnetics and perhaps capacitors bigger, but is necessary to avoid
overburdening your output rectifier. Use nice TO-220 or TO-247 packaged
diodes with adequate heatsinking. The biggest problem with little devices
like DO-41 and DO-201 packages is their lack of easy to use heatsink tab,
despite their seemingly good current, voltage, and recovery time ratings.
