On 24/02/2011 11:05 PM, Bruce Varley wrote:
> "fritz"<(E-Mail Removed)> wrote in message
> news:ijqp8c$ate$02$(E-Mail Removed)...
>> Several years ago I came close to getting electrocuted in the shower.
>> While having a shower I noticed a strongle tingle when I touched the
>> taps, so I checked with a DMM and found there was AC between the
>> taps, showerhead etc and the wet floor. Strange, so we called in an
>> electrician to check what was going on. Turned out the shower floor
>> had a metal tub underneath - looked like lead - which extended up into
>> the wall cavity. On the other side of one wall was the kitchen with
>> a GPO near floor level for the fridge. The wiring was the old rubber
>> insulated type which had gone brittle - and the edge of the tub was
>> scraping the active ! So the wet shower floor was only insulated
>> from the mains by the deteriorating rubber. The Sparky replaced the
>> GPO wiring with TPS, bent the metal away from the GPO and said
>> we were lucky the fault only showed a high resistance and the metal
>> hadn't gone in another mm.
> I still get the shivers about this one, although it occurred many years ago.
> I was working with an American engineer on a plantsite in a country where
> electrical licences hadn't been heard of at the time, we were commissioning
> 440 volt drives in a sub. You check the wiring and insulation, do a dry
> start with the main fuses out, then when it all looks OK, you ram the fuses
> into the stabs and check the motor direction. I was working at one end of
> the sub, and when I looked, my colleague was sitting on the floor looking
> very shocked, although he was physically OK.
> What this guy was doing to save time was to defeat the door interlock by
> pushing a welding rod into a little hole, so that he could open the door
> with the isolator closed. in that condition the top fuse stab would have
> been live at 440, right in front of his eyes. That way, he could do some
> checks quickly. The plan was then to close the door, open the isolator,
> reopen the door and insert the fuses.
> The guy had shoved the fuses into the stabs *with the isolator closed*. The
> drives were in the 100 KW range, so the fuses were about the sizes of a milk
> carton, with a ceramic body and metal ends that fitted the stabs. 3 times,
> he did it without his hands touching the metal at the ends!!!
> I bet that's something he'll never forget.
I knew a guy who tried the same idea with the interlocks on a 5MW peak
primary radar modulator cabinet. The EHT supply was several hundred KV
which arced over to the steel rule that he was carrying in the leg
pocket of his overalls. They did manage to save his leg, but he never
walked the same way again.
