Electronics Forums
Electronics Forums > Newsgroups > Electronics Newsgroups > Electronic Basics > serial port analyzer
Reply
Thread Tools Display Modes
singlewchildren@gmail.com
Guest
Posts: n/a
      03-02-2006, 04:25 AM
I need to get some form of a serial port analyzer. Its not for use
forever, just need to fix a problem with an app that uses the serial
port.
Somehow, I would like to capture data and, if possible, view it in
ascii.
A quick search reveals lots of software applications which appear to be
the type one would load onto the PC with the questionable port, it runs
in the background, captures data in and out of that port for, I assume,
a preset amount of time or data.
These apps monitor the port on the PC they run on, no other hardware
required?
I have never used one like this before.
It would be ideal if I could just load this app and monitor that PC's
serial port, and even better if it could give me a dump of the traffic
in ascii text.
There are so many of these little apps, I also would like to know if
anyone has used one of the freebie, or fairly cheap ones ($50) as it
would be nice to know that what I am trying is something known to
actually work.
Thanks for any advice,
Mark
Dr. Anton T. Squeegee
Guest
Posts: n/a
      03-02-2006, 05:15 AM
In article <(E-Mail Removed). com>,
(E-Mail Removed) (known to some as (E-Mail Removed))
scribed...
> Hi,
> port.
> ascii.
<snippety>
HHD Software has some very nice serial monitoring and analysis
applications. Serial Monitor Lite is right in your specified price range
at about USD $45.
http://www.hhdsoftware.com/sermon.html
I've used Serial Monitor with excellent results. Darn good UI,
clean monitoring, good stuff.
Happy hunting.
Dr. Anton T. Squeegee, Director, Dutch Surrealist Plumbing Institute
(Known to some as Bruce Lane, KC7GR)
http://www.bluefeathertech.com -- kyrrin a/t bluefeathertech d-o=t calm
"Salvadore Dali's computer has surreal ports..."
Deefoo
Guest
Posts: n/a
      03-02-2006, 12:53 PM
<(E-Mail Removed)> wrote in message
news:(E-Mail Removed) ups.com...
> Hi,
> port.
> ascii.
> required?
> in ascii text.
> actually work.
> Mark
If you have two serial ports on your PC try TAL's serial breakout, its free.
http://www.taltech.com/freesoftware/fs_sw.htm
--DF
Si Ballenger
Guest
Posts: n/a
      03-02-2006, 11:54 PM
On 1 Mar 2006 20:25:13 -0800, (E-Mail Removed) wrote:
>Hi,
>port.
There is a free application on the internet called portmon. It
might give you the data you want.
Guest
Posts: n/a
      03-04-2006, 01:49 AM
Thanks a lot. I found it, and it seems to be what I need. I am now able
to progress through this problem, and its so much nicer than guessing
I appreciate everyone's input on this. I actually found several pretty
nice apps, but forgot to mention that the machine is running NT 4.0,
which left out a number of programs that I think looked pretty slick
when I tried them on my Win2K machine first. <shrug>
Much obliged for everyone's time.
Mark
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
I need circuit diagram of keyboard and mouse port, USB port, DDR port, IDE port,... fixpc Electronic Repair 6 03-01-2006 02:59 PM
Re: FS: HomeAccess mountable 4 port/8 port LAN HUBS Mersereau Security Alarms 0 10-09-2004 01:05 AM
I'm looking for a cheap cpu module with dual serial port and an ethernet port Rune Christensen Electronic Design 9 08-25-2004 08:22 AM
I2C through PC parallel port, serial port and/or USB port - please help Adam Electronic Basics 28 06-29-2004 08:15 PM
I2C through PC parallel port, serial port and/or USB port - please help Adam Electronic Design 23 06-29-2004 04:48 PM
