Electronics Forums
Electronics Forums > Electronics Forums > Electronics Repair > SamSung DLP Ballast Test?
Reply
Thread Tools Display Modes
Junior Member
      12-15-2010, 02:18 PM
First off I have some electronics experience but it has been years so please bare with me. I have a Samsung DLP HLN5065wx. The lamp was shattered. I have a new lamp which still doesn't light. I have started to troobleshoot the ballast board.
From the power board I'm getting 382v which is suppose to be correct. I was wondering is there any test with continuity while the board is removed from the TV that I can perform to show whether or not the board is bad?
Power up sequence I see a barrel shaped component that looks like a cap but I'm sure it's not. It glows blue during startup. It seems to be some kind of starter for the lamp.
Any help would be greatly appreciated.
Jerry
Super Moderator
      12-15-2010, 05:10 PM
That component is a gas-discharge tube (often used for overvoltage protection). Here however it's used much in the same way a fluorescent tube starter works.
I believe it should flash, not glow continously. There may be a capacitor not discharging through the starter transformer. Look for breaks in pcb tracks.
Junior Member
      12-15-2010, 05:28 PM
Sorry I stated it wrong. It didn't glow it made 3 zap noise with the flashing during startup.
Super Moderator
      12-15-2010, 06:00 PM
Ok, it does what it's supposed to then. I don't know any brand/model specifics, but scour the net and triple check that there are no subtle differences about the lamp(s).
I've read about people having had problems with different versions of the same lamp having different spec's and some therefore being impossible to ignite in some sets.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
Samsung HL-R4667W DLP Ballast? madhatter Electronics Repair 7 07-26-2010 11:35 PM
Bad DLP Ballast? Chris F. Electronic Repair 5 09-09-2008 09:33 PM
Samsung DLP tv HLM617W color wheel dkuhajda@locl.net Electronic Repair 10 10-12-2005 10:45 PM
Samsung DLP problems Ken G. Electronic Repair 5 10-12-2005 10:06 PM
need a service manual for a samsung DLP tv hulksmash Electronic Repair 1 11-22-2004 02:31 PM
