Electronics Forums
Electronics Forums > Newsgroups > Electronics Newsgroups > Electronic Design > Run PC off 12VDC, efficiently
Reply
Thread Tools Display Modes
George R. Gonzalez
Guest
Posts: n/a
      05-04-2004, 01:42 PM
I know just enough about PC power supplies to be dangerous...
I'd like to run my PC in the back of my van, as efficiently as possible, so
using a 12V to 120VAC inverter is out.
My idea is, and please correct me if you see some major goof, is to do this:
(1) Snip out the MOSFET or transistor that is switching the rectified mains
voltage into the ferrite transformer.
(2) Install a hefty MOSFET to do the same switching, only from the 12V car
battery into the 5V secondary of the ferrite transformer.
(3) snip off the 120V wires on the transformer and hook them to the 120VAC
input wires (to power the voltage doubler, which powers the regulator chip).
The idea is to turn this circuit semi-inside-out, so we're using the 5v
winding as a primary and source for 5V, then the transformer works
backwardfs, powering the 12V and 120VAC lines.
The transformer should be running cooler, as it isnt loaded with the major
load (5V at many amps).
Sounds a bit crazy, but maybe has a chance of working?
Ian Stirling
Guest
Posts: n/a
      05-04-2004, 02:45 PM
You can purchase these.
The most efficient way, probably 200 or 300% efficient is to swap the PC
for a laptop.
Tim Wescott
Guest
Posts: n/a
      05-04-2004, 03:28 PM
> for a laptop.
You mean there's truth to that other thread titled "330% Efficient"?
Can we hook the output shaft of the laptop to the -- oh, right.
Tim Wescott
Wescott Design Services
http://www.wescottdesign.com
mike
Guest
Posts: n/a
      05-04-2004, 06:21 PM
If you're using a CRT monitor, the loss of efficiency in that
is probably worse than the computer.
I recall a thread about a commercial PC power supply replacement with
12V input. Google is your friend.
mike
Return address is VALID.
Toshiba & Compaq LiIon Batteries, Test Equipment
Honda CB-125S $800 in PDX
Yaesu FTV901R Transverter, 30pS pulser
The Real Andy
Guest
Posts: n/a
      05-05-2004, 09:12 AM
On Tue, 04 May 2004 14:45:24 GMT, Ian Stirling
>for a laptop.
Or even better, use a 12v only embedded PC. Cheaper too.
Ian Stirling
Guest
Posts: n/a
      05-05-2004, 09:13 PM
The Real Andy <.pearson@wayit_dot_com_dot_au_remove_the_obvious_ to_reply> wrote:
>>for a laptop.
Debatable.
For some apps, a laptop with a broken screen from ebay can be a
really, really good match.
N. Thornton
Guest
Posts: n/a
      05-06-2004, 12:28 PM
"George R. Gonzalez" <grg2.Elide-(E-Mail Removed)> wrote in message news:<r5Nlc.20779$IG1.861464@attbi_s04>...
I'm doubtful about your original scheme, seems to me there are a
number of pitfalls, such as: starting up, the fact that the 120ac wont
be converted to dc to run the SMPS chip, current ratings, but probably
the biggest of all is this:
Auto 12v supplies carry transients of upto 60v.
And there is also the fact that such 12v sources are really 10-15 v.
Regards, NT
Sylvan Butler
Guest
Posts: n/a
      05-06-2004, 10:36 PM
Yeah, me to.
However, there are sites on the web with details how to convert a PC
power supply to run from an auto 12v source instead of 120vac. So
it can be done.
sdb
| Sylvan Butler | Not speaking for Hewlett-Packard | sbutler-boi.hp.com |
| Watch out for my e-mail address. Thank UCE. >>>> change ^ to @ <<<< |
It may be better to live under robber barons than under omnipotent moral
busybodies. The robber baron's cruelty may sometimes sleep, his
cupidity may at some point be satiated; but those who torment us for our
own good will torment us without end, for they do so with the approval
of their consciences. -- C. S. Lewis
Ian Stirling
Guest
Posts: n/a
      05-07-2004, 03:03 PM
> Yeah, me to.
> it can be done.
There are also sites where you can purchase a power supply that will
run off 12V, for not much money.
Dorothy Bradbury
Guest
Posts: n/a
      05-08-2004, 05:40 PM
There are several approaches to 12V-PC running.
You need to consider if it is running in a car re voltage
o Cars can spike very high even in normal operation
o Particularly so on intermittent bad ground (battery = capacitor)
Two basic 12V PC PSUs exist
o Traditional ATX SMPS -- switch the 12V up to HV AC & back down
---- pro -- they can do 350W, anything you want
---- con -- they are often (very) expensive
o Laptop brick fed DC-to-DC convertor board -- convert 14-24V to 12/5/3.3V
---- pro -- they are cheaper, compact
---- con -- some can't power an ATX board, despite highish rating
The DC-to-DC convertor boards...
o Good efficiency 75-80-85%
---- you might get a bit better with pricey true industrial solutions
---- some PC104 solutions might give higher reliability if critical
o 55, 60, 70, 80, 110, 150, 170, 190W ratings
---- subject to the particular laptop brick you use
o Fanless, at least for the lower wattage items
---- some of the high wattage laptop bricks do have a fan
o Some can power ATX boards
---- however a P4-Prescott might be pushing it
---- if you need P4 in a car/12V-battery, the P-M is available
If it's a car application, remember shock figures are often for 1ms and
tight temperature environment re hard-drives (even 2.5"), so shockmount.
You can go down to <5W PC/104 boards, if needed for say 12V battery
life or use Mini-ITX cheapies, or forthcoming Nano-ITX which move the
consumer market closer to the embedded PC style at a lower price point.
Dorothy Bradbury
www.stores.ebay.co.uk/panaflofan for fans, books & other items
http://homepage.ntlworld.com/dorothy...ry/panaflo.htm (Direct)
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
Re: How can you power superbright LED from a battery efficiently Nobody Electronic Design 7 08-30-2009 03:08 AM
Re: How can you power superbright LED from a battery efficiently Jim Yanik Electronic Design 0 08-29-2009 02:37 PM
how to use eaglecad efficiently ? robb Electronic Design 19 01-19-2008 07:36 AM
how to use eaglecad efficiently ? robb CAD 19 01-19-2008 07:36 AM
LED driver to illuminate 300+ LEDs efficiently help Kristopher keller Electronic Design 29 10-14-2003 06:57 AM
