Electronics Forums
Electronics Forums > Electronics Forums > Circuit Help > RJ12 Phone Jack help
Reply
Thread Tools Display Modes
Member
      10-19-2011, 11:58 PM
Does anyone know if there is a YouTube video of how to install an RJ-12 phone Jack?
And what all the 4. color wires mean?
Senior Member
davelectronic's Avatar
      10-20-2011, 12:16 AM
Hi not sure on the type of phone your referring to, but is this any good.
Dave.
http://www.lanshack.com/wire_phone_jack.aspx
Senior Member
MattyMatt's Avatar
      10-20-2011, 11:50 AM
The link that Dave has put up is excellent, this gives both new and old wiring standards/color codes.
RJ-12= 6 conductor, 3 lines (3 pair), if you have more conductors (wires) than that, then you may have a UTP LAN cable/Ethernet Cable (UTP = Unshielded Twisted Pair, LAN = Local Area Network).
As for the installation, this is the same as installing any other home telephone line in the US or network jacks.
If this is for a digital PBX or data installation, make sure you mind the polarity of the connections. If it is for a 3 line voice only communication cable, polarity won't matter too much, but I will say, the quality will be better and the overall installation will be better if your colors line up correctly.
As far as the actual jack connection, it should be color coded, simple as that. If it is not color coded, or the colors don't match, make sure you have the correct jack for the job. Also note, there are several types of connections that could be present, there are punch down type jacks, and screw terminal type jacks, its up to you, I personally like punch down blocks better, they do need a special tool, which is cheap if it doesn't already come with a plastic one.
Post again if you have any issues, and have fun!
Matty-
"One must be sane to think clearly, but one can think deeply and be quite insane."
- Nikola Tesla
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
Switching Audio Jack & Power Jack Wiring scampa Datasheets, Schematics, Manuals and Parts 7 11-29-2011 01:12 PM
Crimpable Rj12 female vjp2.at@at.BioStrategist.dot.dot.com Electronic Repair 0 04-23-2010 12:40 AM
rj12 crimp punch vjp2.at@at.BioStrategist.dot.dot.com Electronic Repair 0 04-23-2010 12:35 AM
Is an EARPHONE JACK the same as EXTERNAL SPEAKER jack??? Leesa_Tay@softhome.net Misc Electronics 1 04-29-2006 08:47 AM
Cordless Phone Plug/Jack Quest: Help for A Disabled, Please ? Robert11 Electronic Components 0 07-03-2003 11:45 AM
