Electronics Forums
Electronics Forums > Newsgroups > Electronics Newsgroups > Beginner Electronics > Resister help needed
Reply
Thread Tools Display Modes
mike urig
Guest
Posts: n/a
      12-29-2007, 12:49 PM
I want to reduce the voltage from 1.5 volts to 1.0 - .90 volts.
What resister would do this and what end goes toward to 1.5 volt side?
mike urig
Guest
Posts: n/a
      12-29-2007, 04:39 PM
On Sat, 29 Dec 2007 08:58:57 -0600, John Fields wrote:
> On Sat, 29 Dec 2007 12:49:01 GMT, mike urig <(E-Mail Removed)> wrote:
>>I want to reduce the voltage from 1.5 volts to 1.0 - .90 volts. What
>>resister would do this and what end goes toward to 1.5 volt side? Thanks
> That's not enough information. What are you trying to do?
The voltage drop will tell an onboard motorcycle computer to richen the
fuel ratio a little more than stock. The signal comes from an O2 sensor
in the exhaust header pipes. I'm just trying to reduce the voltage a
You can go here: http://www.nightrider.com/parts/
hd2007HD_nbo2_voltage_divide.htm and read the part about "Testing the
NBO2 Inline Enrichment Device off the bike".
mike urig
Guest
Posts: n/a
      12-29-2007, 05:35 PM
Never mind, I found the schematic.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
need resister help mike urig General Electronics 2 12-29-2007 05:36 PM
Need Force Sensor(Resister, Switch??) S Electronic Components 4 02-17-2004 03:57 AM
Need Force Sensor(Resister, Switch??) S General Electronics 3 02-17-2004 03:57 AM
help to find out the value of a base resister to a transistor Andrew Crook Electronic Design 10 12-21-2003 07:51 PM
Series Resister or not GrimReaper Electronic Basics 19 10-28-2003 08:23 AM
