Electronics Forums
Electronics Forums > Newsgroups > Electronics Newsgroups > Rocketry > rec.models.rockets FAQ Part 01 - General Information
Reply
Thread Tools Display Modes
Wolfram v.Kiparski
Guest
Posts: n/a
      04-23-2011, 04:24 AM
Archive-name: model-rockets/general
Rec-models-rockets-archive-name: rockets-faq/part01
Posting-Frequency: weekly
Last-modified: 1998 November 16
URL: http://www.ninfinger.org/~sven/rockets/rmrfaq.toc.html
Rec.Models.Rockets FAQ (Frequently Asked Questions): PART 1 OF 14
GENERAL INFORMATION
This portion of the r.m.r FAQ is maintained by Buzz McDermott, at
(E-Mail Removed). Comments, criticisms, suggestions and corrections
for this section should be sent to that email address.
1.1 What, exactly, is a 'model rocket' versus a 'high power' rocket? Where do
liquid fueled and homemade rocket motors fit in? What about amateur
rockets?
'Model', 'high power', 'advanced', and 'amateur' are all terms which have
many definitions, depending to whom you are speaking. In r.m.r., and in the
FAQ documents, the definitions (if any) accepted by the NFPA, National
Association of Rocketry, and Tripoli High Power Rocketry Association are
used. If these definitions conflict the NAR definition is used.
'Model rockets' are rockets that conform to the guidelines and restrictions
defined in the NFPA 1122 document. These rockets weigh less than 1500
grams, contain less than 125 grams of total fuel, have no motor with
more than 62.5 grams of fuel or more than 160 NS of total impulse, use
only pre-manufactured, solid propellant motors, and do not use metal
body tubes, nose cones or fins. One inconsistency with this is the
CPSC definition of a model rocket motor, which by their definition must
contain no more than 80NS total impulse. NFPA document 1127-94 contains
the most complete definition of a model rocket and the model rocket safety
code. This is the same safety code as adopted by the NAR.
'Large Model Rockets' is a term used in the FAA FAR 101 regulations. It
refers to NAR/NFPA model rockets that are between 454 and 1500 grams
(1 to 3.3 pounds) total liftoff weight or contains more than 113 grams
but less than 125 grams of total fuel.
'High power rockets' are rockets that exceed the total weight, total
propellant or single motor total impulse restrictions of model rockets,
but otherwise conform to the same guidelines for construction materials
and pre-manufactured, commericially made rocket motors. High power rockets
also allow the use of metal structural components where such a material
is necessary to insure structural integrity of the rocket. High power
rockets have no total weight limits, but do have a single motor limit of
no more than O power (40,960NS maximum total impulse) and have a total
power limitation of 81,920NS total impulse. NFPA document 1127-1985 contains
the most complete definition of a high power rocket and also the high power
rocketry safety code. This safety code has been adopted by both the NAR
and TRA. Metal bodied rockets are allowed by NFPA 1127 where metal is
required to insure structural integrity of the rocket over all of its
anticipated flight.
'Amateur' rockets covers all other non-professional rockets that do not
meet the criteria for model or high power rockets. This includes metal
bodied rockets, liquid or hybrid fueled rockets, and rockets with any
type of homemade rocket motor.
'Experimental' rockets is an ambiguous term. In the early 1980's it
was used (reportedly coined by the magazine 'California Rocketry') to
describe rockets that exceeded the model rocket limit at that time (1
pound total liftoff weight and no motor above F power). More recently,
it has been used by the Tripoli Rocketry Association to describe the
class of rockets that use pre-manufactured solid or hybrid rocket
motors but that do not qualify as high power rockets. This includes
metal bodied rockets and those with more than 80,000NS of total
power.
'HPR-lite' is not any type of 'official' rocket designation but has been
used to refer to rockets that exceed the old NFPA model rocket limit of
1 pound but still qualify as NFPA model rocket under current guidelines.
These rockets typically use E through G power and are built with much
the same techniques as high power rockets. This term originated in the
internet 'rec.models.rockets' newsgroup. It should be noted that this
term refers to legal model rockets, not any type of high power rocket,
and might therefore be misleading to many. The term 'Large Model Rocket'
should be used instead.
Another term that has no formal definition but is more and more being
used in the literature is 'hobby rocketry'. This term includes both
model and high power rockets, but excludes amateur rockets. The
term 'consumer rocketry' has also been used, and means the same thing.
The term 'non-professional rocketry' encompasses all forms of model,
high power and amateur rocketry.
Finally, the editor of this document wishes to get on his soapbox for
just one moment and add the term 'stupid rocketry' to cover all those
who attempt to casually produce their own rocket fuel and/or motors
without the benefit of very serious study, and implementation, of the
processes involved and safety measures required. Especially note
that this comment is NOT aimed at serious amateur rocketry
organizations, college level research, etc. End of soapbox.
1.2 NFPA, FAA, DOT, ... Who are all these organizations and how do they
affect the rocketry hobby?
DOT (Dept. of Transportation) regulates shipping of rocket motors and
reloads.
CPSC (Consumer Products Safety Commission) regulates what may and not
be sold as a 'consumer' items at the retail level.
FAA (Federal Aviation Administration) is responsible for airspace
control and regulates flights of rockets that exceed 1 pound and
enter FAA regulated airspace.
NFPA (National Fire Protection Association) makes recommendations for
use of non-professional rocket motors. Although the NFPA only
makes recommendations, most state and local laws concerning the
use of model rockets are based, at least in part, on NFPA
recommendations; especially NFPA 1122. The NFPA also has a draft
definition and safety code for High Power rockets, NFPA 1127.
BATF (Bureau of Alcohol, Tobacco and Firearms) has responsibility for
regulations concerning storage and use of explosives. This agency
has taken a recent interest in looking into how high power rocket
motors are stored and used.
ATC (Air Traffic Control) You must notify the nearest FAA ATC center
prior to flying Large Model Rockets or High Power Rockets.
1.3 What is the current legal status of model and high power rocketry in the
U.S.?
A. FAA Regulations:
* Rockets containing less than 113 grams of total fuel and weigh
less and one (1) pound do not require any type of FAA notification
and are not restricted by the FAA except where they pose a threat
to aircraft.
* FAA "large model rockets" (see the definition in #1, above)
require that the nearest Air Traffic Control center (ATC) be
notified of the launch between 24 and 48 hours prior to the
launch. This is notification and not permission. In the U.S., try
calling 1-800-WX-BRIEF to get the number of the ATC center nearest
you.
* FAA High power rockets (weighing more than 3.3 pounds, containing
HPR motors, or containing a total of more than 125 grams of
fuel) require a formal waiver be approved by the FAA and activated
prior to the launch. Refer to the full r.m.r FAQ (dated 1 Oct 94
or later) for more complete details.
* NOTE THAT THE FAA DOES NOT PLACE ANY RESTRICTIONS ON FUEL-PER-
MOTOR OTHER THAN THE TOTAL LIMIT OF FUEL. HOWEVER, MOTORS WITH
MORE THAN 62.5 GRAMS OF FUEL ARE HIGH POWER ROCKET MOTORS AND
REQUIRE HIGH POWER CERTIFICATION TO FLY. This does allow HPR
certified flyers to conduct low-end HPR launches (with up to about
240NS composite motors) without having to obtain a waiver.
* Remember that HPR waivers, ATC notification and high power
certification are all separate issues and must all be properly
followed.
B. CPSC Regulations/Restrictions:
* G class model rocket motors (80.01-160.00NS total impulse) have been
classified as high power by the CPSC. They are considered model
rocket motors by the NFPA. These motors are now restricted for sale
to buyers 18 years of age or older. This includes the sale of G
reloadable motors.
C. DOT Shipping Restrictions:
* Most single use rockets motors with less than 62.5 grams of
propellant are now classified as UN 1.4s and can be shipped via
UPS (with a HAZMAT fee) or regular parcel post.
* Most reloadable rocket motor fuel grains weighing less than 62.5
grams each are now classified as 'flammable solids' and may be
shipped via UPS (with HAZMAT fee) or regular parcel post.
* The UPS HAZMAT fee is now $10
* Any single use rocket motor containing more than 62.5 grams of fuel,
and any reloadable motor fuel grain weighing more than 62.5 grams
are classified as UN 1.3c, or Class B, explosives. These motors and
reload grains may be shipped ONLY via Federal Express to certain
designated shipping points.
* Aerotech has announced it has received an exemption for single use
motors up to K class and reload grains for at least L, and possibly
M class motors, which allow these motors and reload grains to be
shipped UPS ground in the same manner as motors containing less
than 62.5 grams of propellant. Aerotech says these are now shippable
as class 4.1 flammable solids.
D. BATF Restrictions:
* Any rocket motor or reloadable fuel grain containing more than 62.5
grams of propellant is now classified by the ATF as a Class B Low
Explosive. This includes Aerotech reloads from J power and up.
* You must have a federal Low Explosives Users Permit (LEUP) to
legally purchase Class B rocket motors, reloads, and thermalite except
under certain restricted circumstances.
* You must have a federal LEUP to legally store rocket motors or reload
grains which contain more than 62.5 grams of propellant.
* You must comply with federal low explosives regulations when
transporting and storing Class B rocket motors.
* You must be 21 years of age to obtain an LEUP.
E. Other High Power Restrictions:
* You must be 'high power certified' to fly high power rockets.
* The NAR and Tripoli both have programs for obtaining high power
certification. You need to join one or both of these organizations if
you want to fly high power rockets.
* You must be at least 18 years of age to become high power certified.
1.4 I would like to get into Large Model Rockets. What are my options?
Who has NAR certified E, F and G motors today?
The following manufacturers currently have NAR certified E, F and G motors,
as indicated.
Motor Class Manufacturer Propellant Type
E Flight Systems, Inc. Black Powder
E Aerotech/Apogee Composite (ammonium perchlorate)
F Flight Systems, Inc. Black Powder
F Aerotech/Apogee Composite (ammonium perchlorate)
G Aerotech Composite (ammonium perchlorate)
There are 18, 21, 24, 27 and 29 mm diameter motors available. One
manufacturer (Aerotech) has reloadable motor casings for 18, 24, and
29 mm motors.
Several manufacturers sell rockets designed for E through G powered
flight. Refer to the previous list of addresses and get a few catalogs.
R.m.r readers have recommended kits from NCR, THOY, LOC, Aerotech,
Vaughn Brothers, and others. Look for the following
minimum features in E through G powered kits:
- plywood or fiber centering rings rather than paper or cardstock
- plywood, thick plastic, or G10 fins rather than balsa
- thicker motor tubes
- cloth rather than plastic parachutes
- thicker-walled body tubes
Remember to build these models stronger than smaller model rockets. Use
CA and epoxy rather than white or yellow glue. These rockets will
have to survive much higher stresses than smaller model rockets.
1.5 Is the proper term rocket 'engine' or rocket 'motor'?
I don't know. I don't really care. And neither should you! In this
document 'motor' and 'engine' are taken to mean the same thing and both
refer to "the thing in the rocket which makes it go 'whoosh!!' (or 'roar',
if flying high power :-)". If you want a sure way to start a fight with
a fellow rocketeer, just argue that whatever term he/she uses is the wrong
one.
1.6 What do the letters and numbers on a model rocket motor mean?
The NAR has developed a motors classification scheme which has been
mandated by NFPA 1122 and most state regulations. This system
specifies the motors total impulse class, average thrust, and ejection
charge delay. This is printed on any motors certified by the NAR.
the pieces are as follows, given the example:
E15-10W
The first letter indicates the power range, as specified in the table
below. The number to the left of the dash is the average thrust of
the motor, in newtons. The number to the right of the dash is the
approximate ejection delay in seconds starting at the time of motor
burnout. The final letter is an optional manufacturer designation
for motor or fuel type. Note that letter designating total impulse of
the motor specifies an impulse *range*, not an exact total impulse. For
example, there are G motors that have anywhere from 90 to 160 NS of total
impulse....an Aerotech G42 is rated at 90NS and a G40 is rated at 120NS.
Motors with more than either 62.5 grams of total propellant or have more
than 160NS of total impulse are considered High Power motors. You must
be certified to purchase and fly these motors. Soon, it may also become
necessary to have a license to store high power motors.
Andrew Mossberg ((E-Mail Removed)) recently posted this chart to
rmr, which includes approximate propellant weights for maximum impulse
motors for each class:
P
O
W Low High Low High 200 ISP Propellant
E Limit Limit Limit Limit Weight
R (NtSec) (NtSec) (lbsSec) (lbsSec) (grams) (lbs)
A 1.26 2.5 0.28 0.56 1.3 0.0028
B 2.51 5.0 0.56 1.12 2.5 0.0056
C 5.01 10.0 1.13 2.25 5 0.0112
D 10.01 20.0 2.25 4.5 10 0.02
E 20.01 40.0 4.5 9 20 0.04
F 40.01 80.0 9 18 41 0.09
G 80.01 160.0 18 36 82 0.18
H 160.01 320.0 36 72 163 0.36
I 320.01 640.0 72 144 326 0.72
J 640.01 1,280.0 144 288 652 1.44
K 1280.01 2,560.0 288 575 1,305 2.88
L 2560.01 5,120.0 575 1,151 2,609 5.75
M 5120.01 10,240.0 1,151 2,301 5,219 11.5
N 10240.01 20,480.0 2,301 4,602 10,438 23.0
O 20480.01 40,960.0 4,602 9,204 20,875 46.0
P 40960.01 81,920.0 9,204 18,409 41,751 92.0
Currently, consumer rocketry stops at rockets with a total of no more
than 81,920NS of total impulse. Anything larger than that is by
definition an amateur rocket.
1.7 What is a CATO? Is it CATO pronounced KAY-TO or CAT-O?
The following definition has been posted to r.m.r. by Jack Hagerty,
((E-Mail Removed)) editor of the excellent r.m.r Glossary. For even more
complete information on the term CATO, refer to the glossary.
A motor failure, generally explosive, where all the propellant
is burned in a much shorter time than planned. This can be
a nozzle blow-out (loud, but basically harmless), an end-cap
blow-out (where all of the pyrotechnic force blows FORWARD
which usually does a pretty good job of removing any internal
structure including the recovery system) or a casing rupture
which has unpredictable, but usually devastating, effects.
Another form of CATO is an ejection failure caused by either
the delay train failing to burn or the ejection charge not
firing, but the result is the same: the model prangs.
Opinions on the meaning of the acronym range widely. Some
say it's not an acronym at all, but simply a contraction of
'catastrophic' and should be pronounced 'Cat-o' (which sounds
better than 'cata' over PA systems :-). Others maintain that
it is an acronym but disagree on the meaning, offering a
broad spectrum of 'CAtastrophic Take Off,' 'Catastrophically
Aborted Take Off,' 'Catastrophe At Take Off' and the self
referential 'CATO At Take Off.' The acronym crowd pronounces
it 'Kay-Tow', like the Green Hornet's side kick. It has been
pointed out, though, that all of the above are 'post-hoc'
definitions since LCO's were using the term over range PA
systems long before any formal acronym was established.
1.8 When a consumer rocket motor fails (i.e., CATOs) does it explode or
detonate?
To be precise, consumer rocket motors do NOT 'detonate'. Black powder
rocket motors 'deflagrate'. Detonation involves the creation of super-
sonic shock waves. Use the term 'explode' when discussing CATOs involving
split motor casings, holes blown out the sides of models, etc.
1.9 Why don't I just make my own model rocket motors? Shouldn't I be able
to custom-make better, more powerful motors at a cheaper price?
This subject has been hotly debated on r.m.r. It is one of those
'emotional' subjects that find people either firmly for or against.
The bottom line is that rec.models.rockets is primarily a newsgroup for
discussing *consumer* rocketry (which covers model rocketry and high
power rocketry). Some amateur issues are discussed, but these are not
the primary focus of the group. Manufacturing your own rocket motors can
be a very dangerous thing to do, unless done properly, and with extreme
care. The odds are you will not make motors that are of any higher quality,
total impulse, reliability, or cost less than pre-manufactured consumer
rocket motors.
It is the opinion of the editor(s) of this FAQ that you should NOT try
to manufacture your own motors. If, however, you insist on partaking
in amateur rocketry, then the editor(s) of this FAQ urge you to get in
contact with an established amateur rocketry group for guidance and
assistance.
Copyright (c) 1996, 1997, 1998 Wolfram von Kiparski, editor.
Refer to Part 00 for the full copyright notice.
rmrfaq@n2netmail.com
Guest
Posts: n/a
      04-23-2011, 04:25 AM
Archive-name: model-rockets/addresses
Rec-models-rockets-archive-name: rockets-faq/part02
Last-modified: 2002 May 14
Rec.Models.Rockets Frequently Asked Questions: PART 2 OF 14
NAMES AND ADDRESSES
Last update: May 29, 2002
This portion of the r.m.r FAQ is maintained by Wolfram v.Kiparski.
If you notice any errors, inconsistencies, or ommissions, kindly email
Wolf, at (E-Mail Removed) so that it can be corrected.
2.1 Are their any national-level rocketry organizations which I might join?
What services do they offer?
National Association of Rocketry Model and high power rocketry for
P.O. Box 177 aerospace modelers in the U.S. and
Altoona, WI 54270 around the world.
(800) 262-4872 - sanctions contests and records
- NARAM and NSL yearly national
nar-(E-Mail Removed) competition and sport launches
http://www.nar.org/ - Liability insurance for rocket
flying activities
Complete information is - "Sport Rocketry" magazine
available at the NAR's - Motor safety certification (model
web site. and high power rocket motors)
- High Power (Level 1-3) flyer
certification
- NARTREK continuing education
program
Tripoli Rocketry Association, Inc. High power rocketry enthusiasts
P.O. Box 970010 - Sanctions & insures high power
Orem, UT 84097-0010 rocket launches
http://www.tripoli.org - High power certification
- Yearly national sport launch
(LDRS)
2.2 What are the addresses of some the rocketry manufacturers and suppliers?
Do they offer catalogs?
Here is a list of rocketry manufacturers and suppliers. The list is
divided
into a number of categories. Each address appears only once, but may in
fact qualify to fit into more than one category. The rocketry industry is
rather dynamic, so if this list is six months old, it may be out of date.
The editor(s) of this FAQ can not verify if the companies are, or are
not in
business. Reasonable attempts have been made at completeness, though it
is reasonable that this list may not be complete. If you notice any
errors or omissions, kindly email Wolf at (E-Mail Removed), and the
corrections will be applied ASAP.
Caveat Emptor
2.2.1 Model and High Power Rocket Manufacturers - kits/motors/supplies/etc.
AAA Model Aviation Fuels OUT OF BUSINESS
Aardvark Rockets mid-to-high power kits
http://www.aardvarkrockets.com parts and supplies, custom work
Aerospace Specialty Products Scale and competition kits, parts,
P.O. Box 1408 G-10 fiberglass, adhesives,
abrasives,
Gibsonton, FL 33534 mylar parachutes, sheeting,
and tape
http://www.asp-rocketry.com Catalog - $2.00
Aerotech, Inc. Composite motors, reloadables
(B - M)
3100 E. Charleston Blvd. Large model rocket kits; high
Ste. 123 power rockets, parts, supplies
Las Vegas, NV 89104 Hybrid motors
(702) 641-2301
(702) 641-1883 FAX
(E-Mail Removed)
http://www.aerotech-rocketry.com
Apogee Components rocket motors 1/4A - F
1431 Territory Trail Micro Motors (10.5mm)
Colorado Springs, CO 80919-3323 Composite B and C motors
(E-Mail Removed) Long burn D, E, and F motors
(Timothy Van Milligan) Kits, supplies, and software
(719) 535-9335 Educational materials and books
http://www.ApogeeRockets.com Catalog - see website
Binder Design mid-high power rocket kits
P.O. Box 13376 parts and components
Salem, OR 97309 experimental
(503) 581-3180 phone/fax
(E-Mail Removed) online ordering
http://www.binderdesign.com/
Blackhawk R&D mid-high power rocket kits
1 Grand Central Park parts and supplies
Suite 2152 fiberglass parts specialist
Keyser WV 26726
(304) 788-7660 online ordering
(E-Mail Removed)
http://www.blackhawkrd.com/
Centuri Engineering OUT OF BUSINESS 9/81
Phoenix, AZ
Cesaroni Technology, Inc. Reloadable rocket motors
P.O. Box 246 38mm G - J impulse range
2561 Stouffville Road also mfgs Hypertek Hybrid motors
Gormley, Ontario
CANADA L0H 1G0
http://www.cesaroni.net/
http://www.pro38.com/mainpage.html
Cluster R See 'Rocket R&D/THOY/Cluster R'
Competiton Model Rockets OUT OF BUSINESS 12/87
Alexandria, VA (see Pratt Hobbies)
Cosmodrome Rocketry E - H power scale rocket kits
1724 W. Great Oak Dr.
Tucson, AZ 85746 online ordering
(520)295-1529
(E-Mail Removed)
http://www.cosmodromerocketry.com/
Custom Rocket Co. Model rocket kits and parts
somewhere in Arizona
Doctor Rocket Licensed manufacturer of Aerotech
(E-Mail Removed) compatible reloadable
motors.
http://www.drrocket.com/
Dynacom High power rockets (fiberglass
P.O. Box 85 and composite components).
Boston, PA 15135-0085 Catalog - $3.00
(412) 751-9515
(E-Mail Removed)
http://www.Dynacom-Inc.com/
Eclipse Components OUT OF BUSINESS
Edmonds Aerospace Model rockets and competition
13326 Preuit Place kits, B/G, R/G, RC/G
Herndon, VA 22070 Inexpensive, and reputedly of
(703) 471-9313 high quality.
(E-Mail Removed)
http://Members.aol.com/RobEdmonds/Edmonds.html
Energon Systems, Inc. OUT OF BUSINESS
Estes Industries, Inc. Model rocket kits & motors
P.O. Box 227 Largest rocketry manufacturer
1295 H Street 1/2A through E engines
Penrose, CO 81240
(719) 372-6565
(719) 372-3419 FAX
(800) 525-7561
(800) 820-0202 replacement parts
http://www.estesrockets.com/
Fat Cat Rockets, Inc. unique custom rocket kits
1465 Orlando Circle model rocket through high power
Orlando, FL 32818
(407) 298-1363
(E-Mail Removed)
http://www.fatcatrockets.com/
Flight Systems, Inc. OUT OF BUSINESS
Hawk Mountain Enterprises All fiberglass mid-high power kits
RD 1 Box 231 G-12 fiberglass tubing, FR4
phenolic
New Ringgold, PA 17960 sheet, kevlar, fiberglass
nose cones,
(570) 943-7644 and more...
(570) 943-2735 fax Online ordering
(E-Mail Removed) Catalog and tube sample: $2.50
http://hawkmountain.blastzone.com/
Holverson Designs, Inc. Model rocket kits, rocket/gliders
25075 Co Hwy L20 launch pads, tubes and parts
Soldier, Iowa 51572 Centuri-equivalent tubing
(E-Mail Removed)
http://pionet.net/~holvrson/index1.html
Hypertek Hybrid high power rocket
mfg. by Cesaroni Technology motors and launch systems.
P.O. Box 246 (I, J, L, and M total impulse)
Gormley, Ontario
CANADA L0H 1G0
(E-Mail Removed)
http://www.hypertekhybrids.com/mainpage.html
Kosdon East reloadable rocket motors
c/o Paul Robinson E-M impulse range
5 Old Bridge St. South
Pelham, NH 03076
(E-Mail Removed)
http://www.kosdon.com/
(The) Launch Pad midpower and clustered model
rocket
477 North Carolina Road kits and plans.
Manquin, VA 23106 specializes in scale military
missiles
(E-Mail Removed) Catalog - $2.75
http://www.the-launch-pad.com/ (see part 07 of this FAQ)
Lawn Dart Rocketry model rocket kits
879 Westfield Row reproduction classic kits
Acworth, GA 30102-6900 helicopter duration kits
(E-Mail Removed) CogAero dealer
http://www.lawndartrocketry.com/
LOC/Precision Large model rocket kits; high
P.O. Box 470396 power rocket kits;
Broadview Heights, OH 44147 parts and supplies;
(440) 546-0413 Catalog - $4.00
(440) 546-7942 fax
http://www.locprecision.com/
Maximum Thrust Rocketry Big kits for Big HPR
a division of RDS
formerly HOTT Rockets
http://www.maximumthrust.com/ see also Rocket Dyanamic
Systems entry
Model Rectifier Corporation OUT OF THE ROCKET BUSINESS
Nordic Rocketry Model Rocket kits
P.O. Box 1164 mid-power, high power
Wisconsin Rapids, WI 54495-1164 Catalog - $1.00
(715) 424-0240 - free with email request
(E-Mail Removed)
North Coast Rocketry OUT OF THE BUSINESS
Nova Hobbies scale model rocket kits
PO Box 70547 space history oriented
Fairbanks, AK 99707-0547 ASP kit (see part 7 of FAQ)
(E-Mail Removed) (James Wentworth)
Original Rockets, Inc. scale models of old kits for HPR
P.O. Box 611722
Port Huron, MI 48061-1722
(810)982-3690 voice
(810)985-4643 fax
(E-Mail Removed)
http://users.aol.com/rgilbert1/ori/ori.html
Propulsion Polymers hybrid rocket motor systems
RR#3 38mm I140 motor
Smiths Falls, ON
Canada K7A 4S4
http://propulsionpolymers.com/
Public Enemy Rockets mid-to-high power rocket kits
RWW Distributing clustered, scale, etc.
PO Box 6001 Catalog - $2.00
Moreno Valley, CA 92554-6001
909/243-7398
(E-Mail Removed) (Roy Weid)
http://www.publicenemyrockets.com
Public Missiles, Ltd. Large model rockets and high power
349 Cass Ave., Suite C rocket kits, parts, and supplies
Mt. Clemens, MI 48043 phenolic tubing, G-10 fins
(810) 468-1748 Catalog: $3.00
(810) 465-2911 FAX
http://www.publicmissiles.com/
Qualified Competition Rockets Offers a wide variety kits for
c/o Kenneth Brown competition rocketry, incl.
7021 Forest View Drive piston launchers, tubing,
Springfield, VA 22150 NARTREK packages, publications
http://www.cybertravelog.com/qcr/ inexpensive
Catalog: SASE
Quest/Toybiz Inc. Model rocket kits & engines (A-C),
P.O. Box 42390 launch systems, and supplies
519 West Lone Cactus Drive Catalog: FREE
Phoenix, Arizona 85989-2390
(800) 858-7302 (toll free)
(602) 582-3438 (voice)
(602) 582-3828 (fax)
R.A.T.T. Works Hybrid rocket motor systems
1504-A Industrial Park Street 29mm and 64mm (H/I and K)
Covina, CA 91722 launch rails and rods
(626) 967-2242
(626) 967-9044 (fax)
(E-Mail Removed)
http://www.rattworks.night.net/
Rocket Dynamic Systems Big kits for HPR
PO Box 801208 mid-HIGH power
Santa Clarita CA.
91380-1208
(888) 692-9548
http://www.rocketdynesys.com/
Rocketflite BACK IN BUSINESS!
836 Houston Dr. Magnalite Igniters in kit form
New Haven, IN 46774 ignition systems
(E-Mail Removed) (Greg Dyben)
http://www.rocketflite.com/
Rocketman Enterprises, Inc. High power rocket kits, recovery
8337 Penn Avenue South systems, videos and launch
Bloomington, MN 55431 support systems
(800) 732-4883 Catalog - $3.00
(612) 884-3424 FAX
http://www.the-rocketman.com/
Rocket R & D HPR kits and supplies, also
209 N. Main Street THOY/Cluster R dealer
Homer, IL 61849 tubes, centering rings, parts,
(217) 896-3041 nose cones, chutes.
(217) 896-3042 (FAX)
http://www.rocketrd.com/
Rogue Aerospace Corporation Model rocket kits, parts, and
P.O. Box 596 supplies
Lexington Park, MD 20653 Catalog - FREE
(410) 326-3761
(508) 462-0729 fax
(E-Mail Removed)
http://www.rogueaerospace.com/
http://www.roguelight.com/
Scotglas Manufacturing fiberglass components
7215 Gillett Road nose cones
Canutillo, TX 79835
(915) 877-4405
(E-Mail Removed)
http://www.scotglas.com/
Shecter Rockets Model rocket kits and parts:
20505 E Clear Spring CT BT-5 to BT-55, inexpensive,
Walnut, CA 91789-3887 Catalog - $1.00
http://www.geocities.com/fredeshecter/index.html
Shrox Industria fantasy-scale model rocket kits
(E-Mail Removed)
http://www.shrox.com/
Smokin Rockets big high power kits
183 Walnut St.
Northvale, NJ 07647
(E-Mail Removed)
http://members.aol.com/SMOKINRKTS/home.html
Stellar Dimensions OUT OF BUSINESS
Tiffany Hobbies of Ypsilanti (THOY) See 'Rocket R&D/THOY/Cluster R'
Trailing Edge Technologies Igniter manufacturer for all
types of motors
(214) 670 5244 micro through Level III HPR
(E-Mail Removed) (Jim Turner)
True Modelers Rocket Kits kits for the true
modeler/craftsman
P.O. Box 186 scale and scale-like model
rockets
Harbeson, DE 19951
(302) 684-5419 order online
http://www.truemodeler.com/
Vaughn Brothers Rocketry Model and high power rocket kits
4575 Ross Drive kits and supplies; group launch
Paso Robles, CA 93446-7320 systems
(805) 239-3818 Catalog - $2.00
(805) 239-0292 (fax)
(E-Mail Removed)
http://www.vaughnbrothers.com/
VectorAero R/C Rocket Gliders
(E-Mail Removed)
(Kevin McKiou)
Vulcan Systems, Inc. OUT OF BUSINESS
Yank Enterprises High power rocket kits
1004 Ollie Lane parts and supplies
Plymouth, WI 53073
(920) 254-0657
(810) 454-0152
http://www.yankenterprises.com/
2.2.2 Electronics/Recovery Systems/Other Rocketry Components and Supplies
ACME Engineering composite fin canisters for HPR
http://www.acmeaero.com/ conformal launch lugs
Adept Rocketry Electronic stagers, timers,
2545 Overlook Drive altimeters, flight computers.
Broomfield, CO 80020 Catalog - $2.00
http://www.diac.com/~adept/
Aero Pack International/Missile Systems Phenolic airframe tubing,
8190E Mira Mesa Blvd. 308 threaded aluminum motor
Miramar, CA 92126 retainers
(619) 566-2900 FAX
http://www.aeropack.net/
The b2 Rocketry Company Parachutes for high power
rocketry
(E-Mail Removed)
http://b2rocketry.home.mindspring.com/
Balsa Machining Services Balsa and hardwood nose
cones, centering rings,
11995 Hillcrest Dr. transitions, and fins
Lemont, IL 60439-4145 semi-custom work
(630) 257-5420 Replica Estes/Centuri nose cones
(630) 257-0341 (fax) Tower Launcher
(E-Mail Removed) Catalog - download from web site
http://www.balsamachining.com/
Black Sky Research Associates altimeters, timers, launch rails
3179 Roosevelt St. electic matches, ignition
systems
Carlsbad, CA 92008 38mm reloadable motors and
reloads
(619) 730-3702 (voice) hydrid motor dealer
(619) 730-3704 (fax) high power kits
(E-Mail Removed)
http://www.blacksky.com/
Cotriss Technology OUT OF BUSINESS
Emmanuel Avionics, Inc. OUT OF BUSINESS
Giant Leap Rocketry most inexpensive phenolic tubing
6061 Hibiscus Drive on the rocketry market
Baton Rouge, LA 70808 G10 fiberglass sheet
(504) 769-6040 evenings and weekends fiberglass nose cones
(504) 769-0710 FAX custom work
http://www.giantleaprocketry.com/
Impulse Aerospace Ignition and recovery systems,
22833 Bothell Way SE, Suite 1148 launch pads, high power
supplies,
Bothell, WA 98021 tubular nylon,
(800) 568-2785
http://www.homestead.com/impulseaerospace/
Jim Walston Retrieval Systems Electronic rocket locators
725 Cooper Lake Road, S.E. (transmitter/receiver)
Smyrna, GA 30082 Catalog - FREE
(404) 434-4905
(800) 657-4672
Mach 1 Industries Inc. Balsa-Ply specialty balsa
plywood
20 W. Lake St. airframe tubing, nose
cones, modeling
Chisholm, MN 55719 supplies, and rocket kits
(888) 225-4007 Catalog - FREE
http://www.cpinternet.com/~mach1/
Missile Works Corp. R/C ejection systems,
barometric altimeters
453 East Wonderview Ave. mid-high power scale kits
Estes Park, CO 80517 flexible phenolic/kraft
hybrid tubing
(303) 823-9222 tel/fax online ordering
http://www.missileworks.com/
North Country Radio CCD cameras,
PO Box 53 Wykagyl Station kits, and other electronics
New Rochelle, New York 10804-0053 suitable for rocketry use.
(914) 235-6611
(914) 576-6051 fax
http://www.northcountryradio.com/
Perfectflite microAlt Alitmeter - fits in
BT-50
15 Pray Street
Amherst, MA 01002
(413) 549-3444
http://www.perfectflite.com
Pratt Hobbies Nomex recovery systems &
cool rocket stuff
2513 Iron Forge Road altimeters, kits, kevlar
Herndon, VA 20171 NiCad systems. CMR-style
nose cones
(703) 689-3541 (voice/fax) and egg capsules.
(E-Mail Removed) Catalog: FREE
http://www.pratthobbies.com
Retro Rocket Works OUT OF BUSINESS
Robby's Rockets Ignition and ejection
P.O. Box 171 supplies
Elkhart, IN 46515 Catalog: $1.00 in postage on
(219) 679-4143 large SASE, or $2 for catalogs
Sentell Enterprises Parachutes, streamers, and
104 Linden Drive other recovery devices.
Hendersonville, TN 37075-2032 Catalog - $1.00
(800) 4-CHUTES (orders only) (includes fabric samples)
(615) 822-6565
Sonic Systems Ltd Custom nosecone for LOC 7.67"
4509 East Hobart nice cones
Mesa, Arizona 85205 Clear polycarbonate tubing
Spherachutes Parachutes/recovery devices.
433 38th Ave. Catalog: $1 (includes fabric
Greeley, CO 80634 sample)
(877) 4CHUTES
(E-Mail Removed)
http://www.spherachutes.com/main.html
Tango Papa Decals Reproduction decals from out of
1901 Mitman Rd. production Estes and
Centuri kits
Easton, PA 18040 Mars Lander kits, upscale
decals,
(610) 252-8543 decal paper, printer cartridges
(E-Mail Removed)
http://www.tangopapadecals.com/
Thrust Aerospace OUT OF BUSINESS
Top Flight Recovery Recovery devices (parachutes,
S12621 Donald Road X-form chutes, and streamers).
Spring Green, WI 53588 Catalog: $2.00
(608) 588-7204
(E-Mail Removed)
http://www.topflightrecoveryllc.homestead.com/
Totally Tubular rocket tube supplier - wide
variety
10555 McCabe Rd. 6mm through 4.5" size
Brighton, MI 48116-8526 couplers and rings
(810) 231-6474 FAX hard to find items
(E-Mail Removed) (Jim Fackert) nomex paper, kevlar cord
http://www.totubular.com/
Transolve Corporation Timers, altimeters, location
6501 Sebert #3 beepers, etc.
Cleveland, Ohio 44105 Catalog: FREE
(216) 341-5970
(E-Mail Removed)
http://www.transolve.com/Transolve/index.html
Tru Point Products, Inc. Heavy duty launch pads
140 Baker St.
Coloma, MI 49038
(616) 486-4611
http://www.trupoint.com
2.2.3 Miscellaneous suppliers
For those of you who like to buy their tubing, balsa, and other materials
in bulk, this section may have the supplier that you are looking for.
Also included are suppliers of the kind of goods that many of us find
useful for model and high power rocketry. While there are very many
sources of materials from which one can build rockets, and there is
no way that a
list can completely cover this broad category. Here is a list of
companies that have been mentioned on r.m.r., or have been recommended to
the author. No company listed in this section is a rocketry specialty
company. Many of the companies in the preceding sections also sell "raw
materials," so rocketry-related questions are best directed to them.
Ace Resin Resin casting and molding
supply
7481 E. 30th St. polyurethane rubber and
Tucson, AZ 85710 RTV rubber, supplies
(520) 886-8051
http://crystaltower.com/aceresin/
Aerospace Composite Products Composite building materials
14210 Doolittle Drive fiberglass, kevlar,
carbon
San Leandro, CA 94577 Full line of supplies and
orders: (800) 811-2009 equipment
technical: (510) 352-2022 Custom fabrication and
FAX: (510) 352-2021 specialty products
(E-Mail Removed)
http://www.acp-composites.com/
Alexander Aeroplane Company Composite building materials
P.O. Box 909
Griffin GA 30224
(800) 831-2949 Catalog - FREE
http://www.airsport.com/alexaero.htm
Alumilite Corporation resin casting and molding
supply
315 North Street resins and supplies
Kalamazoo, MI 49007 will send literature, specs,
(800) 447-9344 and cured samples on request
(616) 488-4001 FAX
http://www.alumilite.com/
American Science & Surplus All kinds of surplus, used,
and
3605 Howard St. new equipment, gadgets,
gizmos,
Skokie, IL 60076 and useful odds and ends.
(847) 982-0870 Their address here is for mail
(800) 934-0722 FAX order, but they also have
http://www.sciplus.com/ retail stores in Chicago,
Geneva (IL), and Milwaukee.
Balsa USA Balsa, basswood, plywood,
P.O.Box 164 and adhesives,
Marinette, WI 54143 fresh US-mfg CA
(906) 863-6421 Wholesale prices
(800) BALSA-US orders only Catalog - $2.00
http://www.balsausa.com/
Bare Metal Foil and Hobby Co. Por-A-Kast, Por-A-Mold dealer
P.O. Box 82 urethane resin molding and
Farmington, MI 48332 casting, adhesive metal foil,
(248) 477-0813 decal paper
http://www.bare-metal.com/
The Castolite Company casting resins
4915 Dean St. polyester resins and rubber
Woodstock, IL 60098
(815) 338-4670
(815) 338-4671 FAX
Composite Structures Technology Composite materials
P.O. Box 622 fiberglass,kevlar,carbon,epoxy,
Tehachapi, CA 93581 foam core, vacuum bagging, etc.
(800) 338-1278 Catalog - FREE
http://www.cstsales.com/ occasionally sells materials
at bargain prices.
Fibre Glast Developments Corp. Large supplier of composite
1944 Neva Drive materials, polyester and epoxy
Dayton, OH 45414 resins, vacuum bagging
equipment,
(800) 821-3283 and all related supplies
(E-Mail Removed) Catalog - FREE
http://www.fibreglast.com
McMaster-Carr Supply Company Looked everywhere?
P.O. Box 440 Can't find that "rocket part"
New Brunswick, NJ 08903-0440 anywhere? Give McMaster a
call.
http://www.mcmaster.com/
Micro-Mark Small tool company.
340 Snyder Ave. The company isn't small!
Berkeley Heights, NJ 07922-1595 Perfect tools for working on
(800) 225-1066 rockets.
http://www.micromark.com
Middlesex Paper Tube Company, Inc. Large manufacturer of paper
tubes
P.O. Box 588 I.D.'s from 0.250" to 18.000"
345 Chelmsford Street
Lowell, MA 01851
(800) 466-9317
(978) 458-9317 FAX
Para-Gear Equipment Co., Inc. Full-service parachuting supply
3839 West Oakton Street company.
Skokie, IL 60076-3438 Parachute fabric, tapes,
threads,
708/679-5905 cords, webbing, and hardware.
708/679-8644 - FAX Nylon, nylon, nylon!!!
800/323-0437 (orders - outside IL only) Catalog - $5.00 (refundable)
http://www.para-gear.com/
Paramount Tube Division Large manufacturer of
P.O. Box 80400 paper tubes.
Fort Wayne, IN 46898 I.D.'s 0.093" - 12.000"
(219) 484-4111
(219) 483-0393 FAX
http://www.paramounttube.com/
Peck Polymers Japanese tissue for tissuing
P.O. Box 710399 those contest gliders.
Santee, CA 92072-0399 Dethermalizer fuse, wood,
(619) 448-1818 free-flight glider kits
http://www.peck-polymers.com/ Jetex dealer
SIG Manufacturing Co., Inc. Balsa, basswood, plywood.
401-7 S. Front St. Wood building supplies for
Montezuma, IA 50171-0520 hobbyist, and more...
(800) 247-5008 (Orders) Catalog - $3.00, or order
online
http://www.sigmfg.com/
2.2.4 Mail Order Sources
This is a very incomplete list. Check out the pages of 'High Power
Rocketry'
or 'Sport Rocketry' for many more possibilities. Check your phone book
too!
Advanced Rocketry Group Ltd. (ARG) Model and high power rocket
kits,
130 Matheson Blvd., East - Unit 10 parts, motors, and supplies.
Mississauga, Ontario L4Z 1Y6 Also mfgs their own line of
kits,
(905) 501-0456 Imported Competition supplies,
(905) 501-1846 fax airframe tubes, scale data,
scale kits
(E-Mail Removed)
http://www.uk-air.com/arg/
Ballistic Bob Model and high power rocket
kits,
1575 Catalina Blvd. parts, motors, and supplies
San Diego, CA 92107 20% discount on everything
(619) 224-6435
(E-Mail Removed)
http://www.ballisticbob.com
Belleville Wholesale Hobby Estes motors,
1944 Llewellyn Road rocket kits, supplies, etc.,
Belleville, IL 62223-7904 at 30-40% discount from
(618) 398-3972 retail.
(618) 398-3477 (fax) Catalog - $3.00
http://www.bellevillehobby.com/
Bobby Hall's Hobby House Model and high power rocket
kits,
4822 Bryan Street parts, motors, and supplies
Dallas, TX 75204
(214) 821-2550
Bruckner Hobbies Estes, Quest, Aerotech, Launch
3587 E. Tremont Ave. Pad, Top Flite Recovery,
Bronx, NY 10465 1/2A - G motors.
(718) 863-3434 (Info) Catalog - Free
(800) 288-8185 (Orders only)
http://www.brucknerhobbies.com/
Commonwealth Displays, Inc. Model and high power rocket
kits,
12649 Dix-Toledo Road parts, motors, and supplies.
Southgate, MI 48195 Catalog - $2.00
(734) 282-1055
(E-Mail Removed)
http://www.commonwealth.net
Countdown Hobbies Model and high power rocket
kits,
7 P.T. Barnum Square parts. motors, and supplies;
Bethel, CT 06801-1838 discontinued kits; space,
(203) 790-9010 (voice/fax) science, and collectors items
(E-Mail Removed) catalog - $3.00 ($3 Canada,
(Kevin Nolan) $4 overseas)
http://countdownhobbies.com/
C&T Hobbies Inc. Model and high power rocket
kits,
10181 Townline Rd. parts, motors, and supplies
Cheboygan, MI 49721
(616) 627-3603
http://www.cthobbies.com
Discount Hobby Center Model and high power rocket kits
P.O. Box 370 parts, motors, and supplies
Utica, NY 13503
(315) 733-3741
(315) 733-1723 FAX
http://www.discounthobbycenter.com/
Discount Rocketry Aerotech, Apogee, Binder,
Edmonds,
25944 Kaywood Court Cosmo., Custom, LaunchPad,
LOC,
Escondido, CA 92026-8408 Quest, Estes, more
(760) 432-9626 Miss Rocket Booster posters
(E-Mail Removed) (Kevin Funk)
http://www.discountrocketry.com/
Magnum Rockets, Hobbies and More, Inc. Model and high power rocket
kits,
P.O. Box 124 motors and supplies. "Class B"
Mechanicsburg, Ohio 43044 motor sales. Hybrid motors.
(513) 834-3306 (voice and fax) Catalog - $4.00
http://www.magnumrockets.com
Orbital Dynamics, Inc. Model and high power rocket
kits,
P.O. Box 45375 motors and supplies.
Rio Rancho, NM 87174-5375
(505) 994-4000 Voice
(505) 994-1000 Fax
(E-Mail Removed)
http://www.OrbitalDynamics.com
Red Arrow Hobbies Model and high power rocket
kits,
5095 Red Arrow Hwy. motors and supplies.
Stevensville, MI 49127
(616) 429-8233 Catalog - FREE
email: (E-Mail Removed)
http://www.redarrowhobbies.com
Ring Rocketry Model rocket kits, motors,
supplies
206 East Mary Street specialty and hard-to-find
items
Holland, IN 47541
(812) 536-5000
(E-Mail Removed) (Chad Ring)
http://www.wooshrocketry.org/misc/catalog0202.htm
Rocket Science HPR and model rocketry dealer
Larry Smith kits, motors and supplies.
2714 Augusta Hwy. "Class B" motor sales
Lexington, SC 29072 Hypertek dealer
(800) 221-7205
Space Modeling Solutions Model and high power rocket
kits,
486 East Devon Drive motors, parts, and supplies.
Gilbert, AZ 8529
(480) 497-1960
(703) 832-3237 Fax
(E-Mail Removed)
http://www.smsrocketry.com
Uptown Sales Inc., The Hobby Place Discount Estes dealer
33 North Main St.
Chambersburg, PA 17201 catalog - $1.00 refundable
(800) 548-9941 orders only
http://www.hobbyplace.com
Zeppelin Hobbies Model and high power rocket
kits,
92 Route 23 North motors and supplies.
Riverdale, NJ 07457-1200
(973) 831-7717
(973) 831-5989
http://www.zephobby.com
2.2.5 Sources for Out-of-Production Model Rocket Kits
Wondering if you can ever find and build that old kit you that you once
had? Give these folks a call (find their addresses, phone numbers,
etc. in
the preceding section).
Countdown Hobbies Estes, Centuri, MPC, Cox, and
more... kits, parts, ephemera
2.2.6 Books/Videos/Computer Software/Technical References
NAR Technical Services (NARTS) Plans, technical reports, scale
P.O. Box 1482 data and more.
Saugus, MA 01906 Catalog: Free to NAR
members and
(E-Mail Removed) also on r.m.r archive and www.
http://www.nar.org/NARTS
Odyssey Productions Videos high power and model
P.O. Box 450264 rocket launches
Garland, TX 75045-0264
(972) 495-8576
(E-Mail Removed)
http://members.aol.com/rlt2k/index2
Point-39 Productions Videos of high power rocket
c/o Earl Cagle, Jr. rocket launches (like LDRS)
1607 Apple Valley Drive
Augusta, Georgia 30906
(706) 790-5544
(E-Mail Removed) (Earl Cagle)
Raging Rockets 'How to' videos for high power
(800) 899-2788 rocketry.
Rogers Aeroscience Altitude prediction software
P.O. Box 10065 and reference materials.
Lancaster, CA 93584-0065 Rocketry books - new and used
(818) 349-4825
(E-Mail Removed)
Saturn Press Books on scale rocketry,
P. O. Box 3709 rocketry scale reference
Ann Arbor, MI 48106-3709 materials, a great rockets
(313) 677-2321 of the world poster.
(E-Mail Removed) (see section on books)
(Peter Alway) Catalog: FREE
http://members.aol.com/satrnpress/saturn.htm
2.2.7 International (outside U.S.A.) rocketry sources.
The following is a listing of rocketry dealers, suppliers, manufacturers,
hobby shops, etc. This listing is very incomplete. Please send
comments and revisions to (E-Mail Removed) so that this listing can be
updated. In the future, it is hoped that Part 13 of the
rec.rockets.models
FAQ will handle this section. Please refer to Part 13 of the FAQ for more
information.
Advanced Rocket Components High-power rocketry supplier
P.O. Box 12957 motors, kits, books, supplies
London W12 0WE
England, UK
44 (0) 181 932 7772
(E-Mail Removed)
Aerospace Education Model rocketry and high power
Box 13-368 Onehunga kits, engines, and supplies
Auckland NEW ZEALAND
09-624 3091
09-624 2165 (FAX)
(E-Mail Removed)
http://www.creative.co.nz/index/lyle/hpr.htm
Atlas Ingenjorsfirma AB Manufacturer
Nordana 147 Scale rocket kits
S-232 91 Arlov Model rocket motors (1/2A - D)
Sweden
46 40-44 55 80
Rocketeers Model rocketry and high power
Box 7032 kits, engines, and supplies
Roodeport
SOUTH AFRICA 1715
011 27 11 475 0880
List of known European Manufacturers and Dealers:
http://www.EuropeRocketry.com/
2.3 What are some good books to read to learn more about model and high power
rocketry?
Handbook of Model Rocketry, Sixth Edition
G. Harry Stine
Synopsis:
THE handbook on model rocketry. Covers just about everything you need
to get started. Good tips for experienced modelers as well. Sixth
edition was published March 1994. Available from several sources,
including NARTS.
Basics of Model Rocketry, 2nd edition
Douglas R. Pratt
Kalmbach Books, 1993
Synopsis:
A general introduction to model rocketry.
The 2nd edition is highly revised and has become available as of Jan.
1993. The first edition is very Estes/Centuri/FSI oriented. The
second edition includes sections on composite motors, Aerotech, NCR
and other more recent manufacturers.
Model Rocket Design and Construction
Timothy S. Van Milligan ((E-Mail Removed))
Kalmbach Books, 1995
Synopsis:
120 pages, 16 chapters, 240 illustrations, 40 photographs;
This book is geared towards modelers wanting to know more about the
art and science of building better rockets. Includes chapters on
design, improving performance, constructions and other topics.
The coverage of glider and helicopter recovery, the glossary, and
construction and repoir techniques is very good.
69 Simple Science Fair Projects with Model Rockets: Aeronautics
Published by Apogee Components
ISBN 0-9653620-0-0
Synopsis:
104 pages pages consisting of 5 chapters and 3 appendicies;
including
83 illustrations. Soft cover with 4-color artwork.
This book contains topic ideas for rocketry related science fair
projects
from very simple experiments that can be done in an afternoon, to some
complex ones that require more sophisticated measuring equipment. Each
project begins with some background information that explains why the
topic is important and should be researched. Most projects also give a
starting point that tell what type of equipment may be needed, and
also
where the experimenter should go for additional background research.
This is not a cookbook approach, as the actual experiment must be
designed
by the researcher.
The Model Rocketry Handbook
Stuart Lodge
Argus Books 1990
ISBN 1-85486-047-X
Synopsis:
British handbook on model rocketry. Geared towards beginners, but
some
good tips for more experienced rocketeers.
Stu's Space: The Gospel According to Stuart Lodge
Stuart Lodge
25 Huntington Drive
Castle Donington
Derby DE74 2SR
U.K.
Synopsis:
A more advanced book than his "The Model Rocketry Handbook". Includes
10 chapters on Construction Techniques, Ignition and Launch Systems,
Recovery Systems, Stability, and more. Self published by Stuart
using high quality photocopies. Available directly from Stu.
Rockets of the World, 2nd edition
Peter Alway ((E-Mail Removed))
Saturn Press, 1995
Synopsis:
This book contains information on more than 200 versions of 137
rockets from 14 countries and Europe. An absolute must buy for
scale modeling enthusiasts and rocketry enthusiasts in general.
Available via mail order from Saturn Press, NARTS, Quest, Countdown
Hobbies, Magnum, Mountainside Hobbies and other sources.
Retro Rockets: Experimental Rockets 1926-1941
Saturn Press, 1996
Synopsis:
More than 30 rockets flown by Robert Goddard and his
contemporaries, depicted with dimensioned drawings,
color-keyed drawings, and photographs. Historical
backgraound for each. 96-page hardcover.
Second Stage: Advanced Model Rocketry
Michael A. Banks
Kalmbach Books, 1985
Synopsis:
A good introduction to E/F/G level rocketry. Some good construction
hints.
(E-Mail Removed)
http://ourworld.compuserve.com/homepages/Mikebanks
Rocket Propulsion Elements, An Introduction to the Engineering of Rockets.
George P. Sutton.
Sixth Edition, A Wiley-Interscience Publication,
John Wiley & Sons, Inc., 1992
Teaching Science Through Model Rocketry
Tony Wayne
3 Pigs Publishing, 1994
Synopsis:
The book is for the individual who teaches rocketry to others or is
looking for another aspect of science to teach. It covers lesson plans,
class setup, physics demonstrations, rocketry labs, rocket science
background, teaching aides and more. Over 250 pages.
Contact:
Tony Wayne
58 Court Place
Charlottesville, VA 22901-2457
2.4 Are there any rocketry magazines available?
"Sport Rocketry"
Journal of the National Association of Rocketry
Published 6 times/year
Subscription: Sport Rocketry
c/o National Association of Rocketry Headquarters
P.O. Box 177
Altoona, WI 54270
(800) 262-4872
http://www.nar.org/SPR/
"Extreme Rocketry"
"An alternative rocketry magazine"
Oriented towards large high power projects
Subscription: Extreme Rocketry
109 E. Charleston Suite 101
Las Vegas, NV 89104
(E-Mail Removed)
http://www.extremerocketry.com/
"High Power Rocketry Magazine"
An independent consumer rocketry magazine. Formerly the journal of
the Tripoli Rocket Society.
Published irregularly 9 times/yr. or so
subscription $37.50/year
Subscription: High Power Rocketry
PO Box 96
Orem, Utah 84059
(E-Mail Removed)
Copyright (c) 1996-2002 Wolfram von Kiparski, editor.
Guest
Posts: n/a
Archive-name: model-rockets/internet
Rec-models-rockets-archive-name: rockets-faq/part03
Last-modified: 2002 May 29
Rec.Models.Rockets Frequently Asked Questions: PART 3 OF 14
ROCKETRY ON THE INTERNET
3.1 How do I get to the r.m.r archive site?
The old Sunsite rec.models.rockets archive has not been active since
sometime in 1999. The archives are now part of the ibilio.org domain:
http://www.ibiblio.org/pub/archives/rec.models.rockets
3.2 What is available from the r.m.r archive?
The r.mr. archive used to be the 'official' archive site for
rocketry-related
materials submitted by r.m.r contributors. The archive has been
static for
the past few years. The archive still has a number of useful
files. The following are some of the subdirectories of the archive,
and a brief description of what is in them.
ARTICLES - documents. Informative how-to articles, and other text.
BATF - BATF information
CATALOGS - manufacturer catalogs (a few might actually be current)
CYBERROC - various software for rocketry, including VCP
DIGITRAK - a directory for DigiTrak rocket flight modeling software
ELECTRONICS - rocketry electronics
FAA - FAA information
GRAPHICS - pictures of rockets, launches, and people, scale data,
logos, etc.
LISTS - certified motor lists, club listings
PLANS - rocket plans, including old kit plans and decal scans
PROGRAMS - rocketry software, including tracking software and propep
PROGRAMS.MAC - rocketry software for the Mac
PROGRAMS1 - more rocketry software
PROGRAMS2 - even more rocketry software
PROGRAMS3 - yet even more rocketry software
PROGRAMS4 - lots more rocketry software - Go Nuts!
R.M.R_POSTINGS - an archive of every r.m.r. posting since late Nov. 1991
RASP - a directory for RASP rocket flight modeling software (PC and Mac)
RMRFAQ - the r.m.r. FAQ
ROCKetCAD - demo CAD software for rockets
SOUNDS - .WAV and Macintosh System 7 sound files of launches
Winroc - a directory for WinRoc rocket flight modeling software
3.3 How do I upload files to the r.m.r. archive?
At this time, you can't. This will change soon.
3.4 I have read-only access to r.m.r. Is there any way I can still post
articles to the newsgroup?
Try http://www.google.com/
3.5 What are some neat rocketry web pages to check out?
*** IMPORTANT ROCKETRY WEB SITES ***
HTML version of the entire FAQ:
ROCKETRY ONLINE
http://www.rocketryonline.com/
Rocketry Online is a comprehensive web site for everything to do
with
rocketry and the Internet.
NAR - The National Association of Rocketry home page
http://www.nar.org
Home page for the worlds largest and oldest consumer rocketry
organization.
TRA - Tripoli Rocketry Association
Official home page of the Tripoli Rocketry Association
CAR - Canadian Association of Rocketry
http://www.canadianrocketry.org/
Home page of the Canadian Association of Rocketry. Check out
what's
happening north of the U.S.
UKRA - United Kingdom Rocketry Association
http://www.ukra.org.uk/
Home page for the United Kingdom's largest consumer rocketry
organization.
European Model Rocketry
http://www.europerocketry.com/
Comprehensive Web site for rocketry in Europe.
New Zealand Rocketry Association
http://www.rockets.co.nz/nzra/nzra.htm
Home page for the New Zealand Rocketry Association.
SAMROC - South Africa Model Rocket Club
http://www.samroc.org.za/
*** ROCKETRY CLUB HOME PAGES BY STATE ***
ALABAMA
HARA: Huntsville Area Rocketry Association, NAR Section 403
http://home.hiwaay.net/~bday/hara/
ARIZONA
Arizona High Power Rocketry Association
http://www.goodnet.com/~roktdan/ahpra/
SARA: Southern Arizona Rocket Association, NAR Section 545
http://www.sararocketry.org/
SSS: Superstition Spacemodeling Society - Tripoli Phoenix
http://www.sssrocketry.org/
CALIFORNIA
AEROPAC: Association of Experimental Rocketry of the Pacific
http://www.aeropac.org/
BAYNAR: NAR Section 359
http://www.bynar.org/
DART: Diego Area Rocket Team
http://www.tns.net/dart
LUNAR: Livermore Unit of the NAR, NAR Section 534
http://www.lunar.org/
ROC: Rocketry Organization of California - Tripoli Anaheim
http://www.rocstock.org/
SCRA: Southern California Rocket Assoc., NAR Section 430
http://home.earthlink.net/~mebowitz/
COLORADO
COSROCS: Colorado Rocket Society, NAR Section 515
http://www.cosrocs.org/
Colorado Rocketry Association of Space Hobbyists - CRASH
http://www.crashonline.org/
CONNECTICUT
CATO: CATO Rocketry Club, NAR Section 581
http://www.catorockets.org/
CTRA/NARCONN
http://www.ctra-narconn.org/
FLORIDA
Florida Spacemodeling Association
http://fsatwp2001.tripod.com/
Spaceport Rocketry Association, NAR Section 342
http://home.cfl.rr.com/sra/
THOR - Tampa/Hillsborough Organization of Rocketry
http://members.surfbest.net/(E-Mail Removed)/thor.htm
GEORGIA
Southern Area Rocketry
http://www.soar571.com
ILLINOIS
CIA: Central Illinois Aerospace, NAR Section 527
http://www.prairienet.org/cia/
NIRA: Northern Illinois Rocketry Assocation, NAR Section 117
http://www.NIRA-rocketry.org/
INDIANA
Rocketeers of Central Indiana
http://www.indyrockets.org/roci.html
SCAM: Summit City Aerospace Modelers, NAR Section 282
http://www.mixi.net/~bobhart/
Launch Crue - Holland, IN
http://www.geocities.com/launchcrue519/
KANSAS
K.L.O.U.D.Busters Inc., TRA Prefect
http://www.kloudbusters.org/
KENTUCKY
Kentuckiana Rocketry Association
http://www.ntr.net/~cdutley/krahome.htm
MARYLAND - WASHINGTON DC
NAR Headquarters AeroModelers Society, NAR Section 139
http://www.narhams.org/
Tripoli Maryland
http://www.mdtripoli.org/
MASSACHUSETTS
CMASS: Central Massachusetts Spacemodeling Society, NAR
Section 464
http://www.cmass.org/
MICHIGAN
Huron Valley Rocket Society
http://www.huvars.org/
MISSOURI
St. Louis Rocketry Association
http://www.stlouisrocketry.org/
NEW JERSEY
Garden State Spacemodeling Society
http://www.robnee.com/gsss
Tripoli North Jersey
http://www.metrarocketclub.org/
Southern Jersey Area Rocket Society
http://www.sojars.org/
NEW YORK
ASTRE: Albany-Schenectady-Troy Rocket Enthusiasts of New York,
Section 471 of the NAR
http://www.astre471.org/
MARS: Monroe Astronautical Rocketry Society
Section 136 of the NAR
http://www.marsclub.org/
LIARS: Long Island Advanced Rocketry Society, TRA
Prefecture 29,
and the North Shore Section 142 of the NAR
http://www.liars.org/
Buffalo Rocket Society - Tripoli Western NY
http://www.buffalorocketsociety.org/
OHIO
Northern Ohio's Tri City Sky Busters, NAR Section 535
http://www.skybusters.org/
Northeastern Ohio's Mantua Township Missile Agency, NAR
Section 606
http://web.raex.com/~markndeb/rockets/mtma/
Queen City Area Rocket Klub - QUARK
http://crash.to/quark
Toledo Area Rocketry Society
http://pages.prodigy.net/jjschmidt/
OKLAHOMA
Oklahoma Tripoli
http://members.cox.net/tripoli-oklahoma
PENNSYLVANIA
Pittsburgh Space Command, NAR Section 473
http://www.psc473.org/
Southern Pennsylvania Area Association of Rocketry
http://www.spaar.org/
Blastoff Rocket Club - Erie
http://frontpage.velocity.net/duane/index.html
SOUTH CAROLINA
Tripoli South Carolina
http://www.tripolisc.com
TEXAS
DARS: Dallas Area Rocket Society, NAR Section 308
http://www.dars.org/
AARG: Austin Area Rocketry Group
http://www.aarg.org/
NHRC: NASA/Houston Rocket Club, NAR Section 365, TRA 002
http://www.nhrc.homestead.com/
UTAH
UROC: Utah Rocketry Club
http://www.uroc.org/
VIGINIA
NOVAAR: Northern Virginia Area Association of Rocketry
http://www.geocities.com/CapeCanaveral/8561
WEST VIRGINIA
West Virginia Society of Amateur Rocketry
http://www.wvsoar.org/
WISCONSIN
Wisconsin Organization of Spacemodeling Hobbyists - WOOSH
*** WEB SITES OF GENERAL INTEREST TO ROCKETRY ***
Apollo-Saturn Reference Page
John Duncan's guide to the Saturn V and Saturn 1b, with loads of
scale data for the modeler.
http://www.apollosaturn.com
BATF
http://www.atf.treas.gov/
BATF "Orange Book"
A scanned copy of the BATF non-copyrighted book titled,
"ATF - Explosives Law and Regulation,"
http://www.info-central.org/regulatory/orangebook/
http://members.aol.com/RocketWeb/reg...atf/orange.htm
Certified Motor Listings
NAR Standards and Testing Committee
http://www.nar.org/SandT/NARenglist.shtml
Tripoli Motor Testing
http://www.tripoli.org/motors.htm
Cineroc Sites
Places were you can find stuff about the old Estes Cineroc
movie camera
http://www.techblvd.com/Rvideo/rvideo.htm
http://groups.yahoo.com/group/OldRockets/
Competition Rocketry
http://www.nar.org/competition/
http://groups.yahoo.com/group/contestRoc/
http://www.acmenet.net/jvincent/nercb.html
Early Space Flight
John Sisson of UC Irvine has created terrific web page about early
visions of spaceflight, including material from Ley, Disney,
and our
own G. Harry Stine.
http://sun3.lib.uci.edu/~jsisson/john.htm
Electronics and Rocketry
Ed's web site devoted to electronics used in consumer rocketry.
Currently has VCP files and information about Taniwha Flight
Computers
http://www.geocities.com/CapeCanaveral/7318
FAA Form 7711-2 Application for Certificate of Waiver
downloadable/printable copy of Form 7711-2
http://www.faa.gov/avr/afs/Waiver.htm
Model/High Power Rocketry Motor Dimensions
http://www.dnaco.net/~dantassi/motors.html
Model Rocket Drag Analysis
John DeMar's R&D report containing useful CD data
http://web.syr.edu/~smdemar/rocketdrag.html
http://www.nfpa.org
Northeast Regional Contest Board page
Old Rockets, Old Rocketeers, Nostalgia
http://www.dars.org/jimz/rp00.htm
rec.models.rockets Design Contest Homepage
Enter your rocket design in the ongoing r.m.r. Design Contest!
Winners receive prizes from generous r.m.r. readers.
http://www.aeroconsystems.com/descon...scon_index.htm
VCP Software Archive
Official site for Gary Crowell's CP/CG Calculator.
Stabilize your designs!
http://www.v-serv.com/vcp/
Water Rockets
Gary Ensmenger's Water Rocket Playground:
http://www.h2orocket.com/
Yahoo -
http://www.yahoo.com/Recreation/Hobb...Crafts/Rockets
The above is a great starting point and has a large number of
pointers
to other rocketry sites.
This is the rocketry page of Sven Knudson.
He has the most up-to-date HTML version of the
rec.models.rockets FAQ.
He also has great rocketry pages and the rec.models.scale FAQ.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
rec.models.rockets FAQ Part 01 - General Information Wolfram v.Kiparski Rocketry 1 02-19-2005 05:32 AM
rec.models.rockets FAQ Part 01 - General Information Wolfram v.Kiparski Rocketry 1 08-11-2004 08:56 AM
rec.models.rockets FAQ Part 01 - General Information Wolfram v.Kiparski Rocketry 2 07-13-2004 04:17 AM
rec.models.rockets FAQ Part 01 - General Information Wolfram v.Kiparski Rocketry 2 04-11-2004 11:09 AM
rec.models.rockets FAQ Part 01 - General Information Wolfram v.Kiparski Rocketry 1 01-16-2004 09:18 AM
