Electronics Forums
Electronics Forums > Electronics Forums > Datasheets, Schematics, Manuals and Parts > Read value of SMD diode (mini-melf)
Reply
Thread Tools Display Modes
Junior Member
      02-09-2012, 08:28 AM
I've a problem with a switching power supply and I've found a diode in short circuit. It's a SMD component, minimelf with only one blue band... I've found that it's a zener diode, but nothing other info on it's body as you can see from the photo (ZD1).
How do I know its value to replace it?
Sebastian
Senior Member
      02-09-2012, 11:45 AM
If it's a zener, read the voltage across the good one.
Zeners act like a simple voltage regulator in their effect.
Junior Member
      02-09-2012, 09:23 PM
I know as a zener diode works, but the problem is that they are not the same (you need to enlarge the photo to view differences).
Sebastian
Super Moderator
davenn's Avatar
Send a message via Yahoo to davenn
      02-09-2012, 10:46 PM
cant see any difference
care to tell us why you think they are different ?
Time is an illusion -- Lunchtime doubly so - Douglas Adams
When all else fails.... Read the instructions!
Junior Member
      02-10-2012, 12:52 AM
One of the two blue bands is smaller, the body inside the glass have different orange color (one more dark) and size (the interruption between the two bodies seems shifted)...
Senior Member
Rleo6965's Avatar
      02-10-2012, 08:11 AM
Remove the defective zener first then read hidden label around the zener using magnifying glass.
Junior Member
      02-10-2012, 11:07 PM
I've already desoldered the SMD diode, only the photo was done with component mounted, but there is no written on the body (I use a 10x magnifier) so I've decided to do a post here if someone can help me.
Senior Member
Rleo6965's Avatar
      02-11-2012, 01:11 AM
The only way we can assume the zener voltage value was you have to trace the portion of circuit.. Much better if you include voltage value of capacitors, name of ic, optocuplers etch connected to defective of the zener diode.. Post that portion of schematic.
Then, we can help you.
Super Moderator
davenn's Avatar
      02-11-2012, 01:58 AM
Quote:
could easily fall within manufacturing variations
Junior Member
      02-11-2012, 02:24 AM
the object is a switching power supply, output 9V 1,3A.
The mosfet is a STK0460F (removed because I must replace it), no optoisolator on circuit, precision shunt regulator TL431.
The SMD diode removed is connected to the single pin of SMD transistor.
If you need other info ask to me.
Sebastian
Read value of SMD diode (mini-melf)-pws_9v_back.jpg   Read value of SMD diode (mini-melf)-pws_9v_front.jpg
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
SMD diodes Melf/Mini Melf series Jacy Electronic Projects 0 09-04-2009 09:19 AM
mini-melf diode color rings? francesco.messineo@gmail.com Electronic Repair 4 09-22-2006 07:35 AM
Mini-Melf and Quadro-Melf 4148 diode blasterbill Electronic Components 1 05-22-2004 04:44 PM
MELF or chip? Daniel Haude Electronic Design 14 09-28-2003 05:27 PM
Wanted 200 SPDT MINI or Sub Mini Toggle Switches (NO PCB Mount) Must Have Mounting Hardware MRQuickBoard Electronic Components 0 09-08-2003 09:05 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98
