Electronics Forums
Electronics Forums > Newsgroups > Electronics Newsgroups > Electronic Design > Re: Wrong packaged diode
Reply
Thread Tools Display Modes
legg
Guest
Posts: n/a
      02-07-2010, 08:48 PM
On Sun, 7 Feb 2010 03:17:45 -0800 (PST), djj08230 <(E-Mail Removed)>
wrote:
>Hello all,
>A board we produce has a battery that power a static RAM through a
>diode. This is a SMD package, maybe a SMA, but can't say for sure
>right now.
>We have had a few problems with the battery circuit, that I know have
>been solved changing the diode.
>I have seen only one of those myself, and it looks like the diode is
>packaged the other way round i.e. the package strip pointing to the
>anode instead of pointing to the cathode.
>Is this at all possible ? Am I doing something wrong ? Any similar
>experiences around ?
>As the board is produced in China, I would tend to think it is a
>counterfeit diode.
>Thank you in advance.
>Josep
More info needed. Many diodw packages can be obtained with alternate
pin-out or polarity, at a premium.
Some diodes have functional characteristics in the forward and reverse
direction, which might require their use in what looks like an
inverted mode.
RL
legg
Guest
Posts: n/a
      02-09-2010, 02:40 AM
On Sun, 7 Feb 2010 23:36:33 -0800 (PST), djj08230 <(E-Mail Removed)>
wrote:
>On Feb 7, 9:48*pm, legg <l...@nospam.magma.ca> wrote:
>> On Sun, 7 Feb 2010 03:17:45 -0800 (PST), djj08230 <djj08...@gmail.com>
>> wrote:
>> >Hello all,
>> >right now.
>> >counterfeit diode.
>> >Josep
>> inverted mode.
>> RL- Hide quoted text -
>> - Show quoted text -
>Thank you.
>I've got the info now.(monday morning here)
>The diode is MURS105T3G from On Semiconductors in an SMB package.
>http://www.onsemi.com/pub_link/Colla...URS120T3-D.PDF
>Probably not the best bit, but to me, this is an odd behaviour.
>Testing the diode with a multimeter looks like the package is
>reversed. Do they hand-assembly these tiny diodes ? (!!!)
>Josep
There is no point in producing an 'axial' two-lead device with an
alternate pin-out. Alternate pinouts only occur if a mechanical
reversal is impractical or impossible to achieve as shipped.
Check part out-of-circuit. Forward voltage drop will be evident if
positive conventional current is forced into anode to return via
cathode. If cathode band (schematic symbol points to it) is
incorrectly impressed, you've got a load of rubbish.
RL
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
replacement for a MR2504s power diode jmariano Electronic Components 1 07-20-2006 07:28 PM
minimum current/voltage for diode? Tristar500 Electronic Basics 5 07-15-2005 06:14 PM
Q. on Diode Equation Blake Electronic Basics 10 05-27-2005 01:49 PM
Diodes in parallel Jack// ani Electronic Basics 10 02-21-2005 06:19 PM
Replacing PIN diode with Schotty diode... Mark Electronic Components 1 08-06-2004 08:52 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33
