Electronics Forums
Electronics Forums > Newsgroups > Electronics Newsgroups > Electronic Basics > Re: Using a Panel Meter movement
Reply
Thread Tools Display Modes
Rich Grise
Guest
Posts: n/a
      09-15-2008, 06:27 PM
On Mon, 15 Sep 2008 10:43:28 -0400, Patrick Keenan wrote:
> Hello All,
> I'm trying to sort out how to use an analog, needle-style, coild&spring type
> of panel meter movement. I have a couple of samples to play with,
> unfortunately I have no infomation about them. On one, the needle rests on
> the left, on the other, the in the center - this is actually the one I am
> most interested in using.
> For clairty this is the kind of device I'm referring to:
> http://www.process-controls.com/Modt...Taut_Band.html
The web site says they have "100 ľA" movements - that's probably 0-100FS
for one, and 50-0-50 for the other.
So, take a 1.5V battery, a 10K pot, and a resistor of (1.5V/100 ľA) ohms;
wire them like this:
1.5V _ [10K]<----[15K]----+
| | [meter]
That should give you zero to full-scale deflection. The 15K resistor
will turn a 100ľA meter into a 0-1.5 voltmeter. Reverse the leads for
negtive deflection (like to test the 50-0-50 meter.)
Start the 10K pot at the low end (i.e., 0 volts) and crank it up
slowly, to make sure you have the polarity right and that I've guessed
right on the 15K value. ;-)
IOW, check my math! ;-)
Have Fun!
Rich
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
Meter movement for Simpson 260? Angela Marsh Electronic Equipment 14 08-26-2010 05:00 AM
Re: Using a Panel Meter movement extremesoundandlight@yahoo.com Electronic Basics 5 09-17-2008 03:21 AM
Re: Using a Panel Meter movement christopher@NOSPANoldtemecula.com Electronic Basics 0 09-17-2008 12:40 AM
WTD: Boonton 260A Q-Meter Meter Movement Mike Nowlen Electronic Equipment 1 09-05-2003 07:08 AM
WTD: Boonton 260A Q-Meter Meter Movement Mike Nowlen Electronic Equipment 1 08-17-2003 12:49 AM
