Patrick Keenan wrote:
> <(E-Mail Removed)> wrote in message
> news:2f70ab98-4775-4ec0-b544-(E-Mail Removed)...
> On Sep 15, 7:43 am, "Patrick Keenan" <t...@dev.null> wrote:
>> Hello All,
>> I'm trying to sort out how to use an analog, needle-style,
>> coild&spring type
>> of panel meter movement. I have a couple of samples to play with,
>> unfortunately I have no infomation about them. On one, the needle
>> rests on
>> the left, on the other, the in the center - this is actually the one I am
>> most interested in using.
>> For clairty this is the kind of device I'm referring
>> to:http://www.process-controls.com/Modt...meters_Magcent...
>> So I'm looking for a sample circuit that shows me how this sort of
>> movement
>> is connected and driven, or just what words to use on Google to find such
>> circuits, and how to figure out details on the samples I have. I'm
>> finding
>> lots of results on meters except for how to do this.
>> I'm intending to use this movement to indicate whether a signal is
>> above or
>> below a given value - if you think of a guitar tuner, that's probably a
>> helpful example.
>> Thanks!
>> Patrick Keenan
> use a meter whith known values in a circiut to set your full scale
> deflection on your VU meter for what your going to measure
> what the application.
> what are you tring to measure
> Thanks for the reply. For application, think "guitar tuner".
> What is being measured is an incoming frequency, relative to a specific
> reference, so the needle rests in the middle and moves right or left.
> There's a microcontroller involved, so I assume that I'll be converting
> that incoming frequency to a voltage to run the meter itself. The
> meter won't be the only display, but I find that for me, the needle
> movement is the best visual cue.
> Do you know of any sample circuits so I can see what sorts of voltages
> and currents are normally acceptable for this kind of movement, and how
> they are normally connected? Or a sample datasheet? These seem
> harder to find than I expected.
> Thanks again,
> Patrick Keenan
The meter is driven by current. The voltage level powering
a microprocessor will be fine, but the current *must* be
limited to less than 100 ua, per the page you posted.
Assuming a 5 volt supply, you can use a 2 meg resistor in
series to limit the current to no more than 50 uA to give
yourself a wide safety margin when testing the meter.
Your actual circuit will dictate how the thing is wired when
in use, but in general it will have a fixed and a variable
resistance in series. The variable resistance is used to
calibrate the full scale meter reading. Something like this:
R1 VR1
[Source] [Meter]
Source in the diagram is whatever circuit element drives the
meter - transistor, op amp, uprocessor, whatever.
Ed
