Electronics Forums
Electronics Forums > Newsgroups > Energy Generation > Photovoltaics > Re: Using Grid-tie inverters
Reply
Thread Tools Display Modes
Randy
Guest
Posts: n/a
      07-14-2008, 02:13 AM
<(E-Mail Removed)> wrote in message
news:162fcaba-5c05-4e60-a218-(E-Mail Removed)...
> Hello everyone,
> Im currently trying to install a PV system at my home. I have 12v,24v
> dc producing solar panels, and was wondering what grid tie inverter
> should I use. According to SMA,Xantrex,Fronius companies the input
> voltage is really big, more than 100v.
> I appreciate any help,
> Thanks in Advance
> Antonio
Check out the Outback GTFX inverters available in 24 and 48 volt models.
They are battery based systems also I found these lower volt/watt units:
http://www.affordable-solar.com/enph...24-240-s01.htm
They do not have battery backup but are much cheaper if you plan to stay
with a small system.
Hope this helps
Randy
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
Using Hex Inverters to generate 0, -5V output alex.panther@gmail.com Electronic Basics 6 02-08-2006 02:30 PM
Using hex inverters as op amp Greg Electronic Components 3 02-23-2005 08:06 PM
Using hex inverters as op amp Greg Electronic Components 1 02-21-2005 09:24 PM
Re: Oscillator Design using CMOS Inverters Jim Thompson Electronic Design 10 08-28-2003 10:26 PM
Re: Oscillator Design using CMOS Inverters maxfoo Electronic Design 0 08-28-2003 12:03 AM
