<(E-Mail Removed)> wrote in message
news:(E-Mail Removed) ups.com...
> I have just installed an Generac automatic transfer switch (ATS) for my
> house. I am going to use this with my portable generator. Everything
> has been tested and works fine.
> Obviously the portable generator does not have the connections to trip
> the internal coil of the ATS. Generac has provided a manual way to do
> this however it requires that I remove the cover from the panel and use
> an insolated screw driver of sorts.
> My Question:
> How can I hook up a switch that I can push on the outside of the ATS
> that will mimic my manual pulling of the switch?
First you need to find out if the contacts on the switch are maintained or
momentary.
