Electronics Forums
Electronics Forums > Newsgroups > Electronics Newsgroups > Electronic Components > Re: Toshiba motor control IC
Reply
Thread Tools Display Modes
N_Cook
Guest
Posts: n/a
      10-16-2011, 07:53 PM
<(E-Mail Removed)> wrote in message
news:ee3da138-b158-4f04-bc71-(E-Mail Removed)...
> Hi,
> Can anyone help identify a Toshiba IC used for bidirectional control
> of a brushed motor? The original part number is partially missing as
> the chip has a crater blown in the package when the mechanism
> seized...
> 12-pin staggered SIL package, with metal heatsink tab
> Legend says TOSHIBA, part number begins TA80
> The IC is part of the controller for the power antenna in a 1998 Mazda
> 323F (known as a Miata in North America I believe). Toshiba don't
> list anything similar in their current line-up, so I'm assuming the IC
> is EOL and I'm looking at obsolete parts suppliers.
> If anyone can identify this chip and, better still, point me to a
> datasheet, I might be able to find a similar part or lash something up
> using discretes if I can't locate a replacement.
> TIA
> R.
http://www.datasheets.org.uk/
for ta80* driver
ID 1 First line: motor mind c TA8082H TA8082H DUAL MOTOR DRIVER Abstract:
... DUAL DC MOTOR DRIVER. The TA8082H contains two motor driver circuits with
a current capacity of 1.5A for directly driving bidirectional DC motors.
Inputs DI1A / B and DI2A / B are combined to select .. Tags: motor mind c
Z/1.5A* TA8082H 213.24 Kb 7 Pages Original PDF Download
datasheet frame
ID 2 First line: TA8052S TA8052S 0.3A MOTOR DRIVER WITH BRAKE FUNCTION
Abstract: .. 0.3A MOTOR DRIVER WITH BRAKE FUNCTION. The TA8052S is a
full-bridge driver which directly drives a bidirectional DC motor. Inputs
DI1 and DI2 are combined to select one of forward, reverse, stop .. Tags:
TA8052S TA8052S 205.57 Kb 7 Pages Original PDF Download
datasheet frame
ID 3 First line: TA8062S TA8062S DUAL HIGHSIDE DRIVER Abstract: .. DUAL
HIGHSIDE DRIVER. The TA8062S is a 0.3A highside driver containing two
circuits in one package. The input level is TTL compatible so that the
output can be controlled directly from CPU system .. Tags: TA8062S 163.9
datasheet frame
ID 4 First line: TA8050F TA8050F Motor Driver with Brake Function Abstract:
... 1.5 A DC Motor Driver with Brake Function. The TA8050F is a 1.5 A motor
driver which directly drives a bidirectional DC motor. Inputs DI1 and DI2
are combined to select one of forward, reverse, stop .. Tags: TA8050F
174.02 Kb 9 Pages Original PDF Download
datasheet frame
ID 5 First line: TA8069F TA8069F SIDE DRIVER Abstract: .. 4CH LOW SIDE
DRIVER. TA8069F is built into four 0.5A low-side driver ICs which drive
lamp, relay, and solenoid actuators. Inputs from DI1, DI2, DI3, and DI4
switch ON and OFF modes. Inputs are TTL .. Tags: TA8069F 305.92 Kb 10
datasheet frame
ID 6 First line: TA8081P TA8081P 0.7A MOTOR DRIVER WITH DIAGNOSIS Abstract:
... 0.7A MOTOR DRIVER WITH DIAGNOSIS. The TA8081P is a 0.7A motor driver
which directly drivers a bidirectional DC motor. Inputs DI1 and DI2 are
combined to select one of forward, reverse, stop, and .. Tags: TA8081P
205.01 Kb 7 Pages Original PDF Download
datasheet frame
ID 7 First line: TA8083AF TA8083AF Dual Motor Driver Abstract: .. Dual DC
Motor Driver. The TA8083AF contains two motor driver circuits with a current
capacity of 0.5A for directly driving bidirectional DC motors. Inputs DI1
A/B and DI2 A/B are combined to select .. Tags: TA8083AF TA8083AF 315.39
Kb 11 Pages Original PDF Download
datasheet frame
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
Re: Toshiba motor control IC Jamie Electronic Components 0 10-16-2011 08:33 PM
Re: Toshiba motor control IC Jamie Electronic Repair 0 10-16-2011 08:33 PM
Re: Toshiba motor control IC N_Cook Electronic Repair 0 10-16-2011 07:53 PM
Using Toshiba vc-625 remote control to set picture settings on Toshiba 20af42 TV illegal.prime@gmail.com Electronic Repair 5 12-27-2006 04:51 AM
DC motor control system for reverse bucket position control on a jetboat Mike Electronic Equipment 7 09-06-2004 08:48 PM
