Electronics Forums
Electronics Forums > Newsgroups > Electronics Newsgroups > Electronic Basics > Re: Switch on by Using the Terminal Strip vs. Using the Switch on the External Hard Drive
Reply
Thread Tools Display Modes
Rich Grise
Guest
Posts: n/a
      02-19-2011, 09:19 AM
Joe wrote:
> I recently got an external hard drive, an OWC Mercury AL-Pro. It has an
> external power supply - from the size of it, I thinks it's a switch-mode.
> The only power switch is on the hard drive enclosure itself, not on the
> power supply.
> I have the thing plugged into a terminal strip that has individual
> switches for each outlet.
> Does it make any difference to use the switch on the terminal strip for
> the on-off switch and leave the switch on the enclosure always on?
It might - the switch on the disk enclosure might depend on the switcher
already being powered up; if it were left on, and the power supply switched,
the drive _might_ not be able to handle the power-on transients from the
power supply.
Use the switch on the drive box to power up/down the drive, and the switch
on the power strip to save energy. Turn on the power strip first, then
the drive box switch, and when turning it off, turn off the drive box switch
first, then the power strip.
Cheers!
Rich
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
Re: lacie external usb hard drive, power connector pinout? Baron Electronic Repair 1 01-20-2012 04:19 AM
Re: Switch on by Using the Terminal Strip vs. Using the Switch on the External Hard Drive Rich Webb Electronic Design 0 02-19-2011 11:05 PM
External hard drive fried by static??? jack1981 Electronic Design 10 10-24-2006 09:17 PM
Stream Data Directly to External Hard Drive jjlindula@hotmail.com Electronic Design 5 03-09-2006 07:07 PM
Open IOmega external USB2 hard drive case? larry moe 'n curly Electronic Repair 4 03-13-2005 12:16 PM
