Electronics Forums
Electronics Forums > Newsgroups > Electronics Newsgroups > Electrical Engineering > Re: Sub Panel Sizing Question?
Reply
Thread Tools Display Modes
gfretwell@aol.com
Guest
Posts: n/a
      08-24-2005, 06:04 AM
On Wed, 24 Aug 2005 01:51:05 -0400, (E-Mail Removed) wrote:
>You could do this with a 2 pole 30a disconnect type box with a 20a 2
>pole breaker in it and you would be about 500% more than you need for
>160 sq/ft (480va) and still have a dedicated circuit for your A/C
>unit.
Just be sure to buy the suplimental ground bus and don't install the
neutral bonding screw.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
Re: Running a sub panel off of a sub panel Rich. Electrical Engineering 5 10-23-2009 12:57 AM
Re: Running a sub panel off of a sub panel Archimedes' Lever Electrical Engineering 0 10-17-2009 02:07 PM
Please check calculations in Excel for system sizing please? - Small System Sizing Calculator.xls (0/1) - Small System Sizing Calculator.xls (0/1) Anti-Spam Photovoltaics 3 08-26-2007 03:00 PM
Re: Sub Panel Sizing Question? SQLit Electrical Engineering 1 08-24-2005 07:05 PM
Does SUB-BGT mean SUB Brightness? david Electronic Repair 1 09-09-2003 09:22 PM
