Electronics Forums
Electronics Forums > Newsgroups > Energy Generation > Photovoltaics > Re: Solar panel to run laptop
Reply
Thread Tools Display Modes
Glenn
Guest
Posts: n/a
      10-04-2006, 09:45 PM
Bob,
I'm looking into running our laptop on solar as well (just purchased a
Dell Inspiron B130). My wife would like to be able to sit out,
utilizing the wireless connection.
If I wanted to put together a system that would use your SolarUPS,
what other parts would I have to get (could you provide a list for
those of us new to the solar world) that would power just one laptop?
Also, what would be a ballpark price?
Much thanks
Glenn
On 29 Sep 2006 08:44:37 -0700, "Bob" <(E-Mail Removed)> wrote:
>Hi DW,
> Running a laptop from solar power can be confusing. What you need
>depends on how much you plan to use the laptop and if you want to be
>portable or use it in a fixed location. First you need to know what the
>laptop requires.
> I have made measurements on a couple of laptop computers (Dell and
>IBM) and found they typically require 50 to 75 Watts of power when
>first plugged into the external power source (whether AC, solar, or
>cigarette lighter adapter). If the laptop battery is fully charged,
>then the power requirement will decrease in a few minutes to about 20
>Watts. If the laptop battery needs charging then the high power will
>continue for longer until the battery is charged. Of course when the
>laptop is turned off, or in standby mode, it uses less power as long as
>the internal battery has finished charging. You need to estimate how
>many hours a day you will use the computer and as a good average
>multiply the number of hours times 20 Watts to get the minimum
>watt-hours per day required. As an example I will assume you want to
>run the computer for 8 hours per day, resulting in 160 Watt-hours of
>power usage. Next consider how solar panels work.
> A solar panel produces power in proportion to the amount of light
>striking the surface. The actual power at any given moment will depend
>on weather conditions, temperature, the time of day, and the angle
>between the solar panel and the sun. Assuming clear weather, the next
>three factors become important, and are related. Unless you have a
>solar tracker (or are willing to move the panel during the day) you
>will probably just mount it facing South and tilt the panel from
>horizontal by an angle equal to the latitude where you live. In this
>case you will achieve the best compromise that is possible without
>adjustments for time of day and season. If you simply mount the panel
>horizontal, then your power will vary from summer to winter, and will
>be considerably less than optimum. With the panel facing South and
>tilted correctly you will achieve an average of 6 to 7 hours of "full
>power" per day. "Full power" is not what the panel is rated for
>unfortunately since all ratings are made at room temperature (20-25
>degrees C), and the panel will become much hotter than this when placed
>in the sun unless it is very cold outside. Typical summer time
>conditons will result in about 80% of the rated power at noon. Early in
>the morning and late in the afternoon the power will be much lower of
>course, which explains why you only get 6-7 hours of "full power" per
>day. All these factors combined means you can get about 4.8 to 5.6
>Watt-hours per day from a 1 Watt solar panel. To achieve the 160
>Watt-hours per day in my example you will need about a 30 Watt solar
>panel which should produce about 144 to 168 Watt-hours per day. For
>successful operation of the laptop you will need an external battery to
>store the solar energy, and to provide the high power required when
>first connected. Without the storage battery you would need a much
>larger solar panel (probably at least 100 Watts even at noon). You
>will also need either a Auto Power adapter (cigarette lighter adapter)
>for your laptop or an inverter to convert the DC of the battery to AC
>power.
> External batteries are available from several companies, but many
>of them will not charge from solar power while running the laptop
>computer. I have developed what I call a "Solar UPS" that is designed
>to use all the solar power available to run the laptop and either store
>any excess in its internal battery or make up the difference if demand
>is more than the solar panel is producing. This unit is small and light
>enough that you can store it in your travel bag, and is capable of
>powering up to two laptops or one laptop and a satellite terminal
>simultaneously when connected to an adequate solar panel. It will
>accomodate any nominal 12 volt solar panel up to 60 Watts. See
>www.locoengineering.com for more details. If you need an inverter and
>size and weight do not matter Xantrex sells lead acid batteries with
>built in inverters that will work. You may need to increase the solar
>panel size a bit ( maybe 15-30% more solar panel) to accomodate the
>inefficiencies of inverters and battery charging. I hope this reduces
>your confusion, and have fun.
>dw wrote:
>> So I'm confused.
>> The AC adapter for one laptop says it's 90W 20V.
>> The other laptop's adapter says it's 100-240V 1.5A AC, 19.5V 4.62A DC
>> I'd like to set up a shack in the woods as a studio and use them there.
>> What kind of solar setup can I use for 1 or two laptops?
>> Knowing nothing except I don't want to spend a lot of money here, will
>> a 6W solar charger like this
>> http://cgi.ebay.com/Solar-Panel-Powe...QQcmdZViewItem
>> do the trick?
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
Re: Do I really need a solar collector to heat my home? Fat Moe Home Power and Microgeneration 0 11-29-2008 09:57 PM
Re: Solar panel to run laptop dold@XReXXSolar.usenet.us.com Photovoltaics 0 09-29-2006 06:25 PM
Re: Solar panel to run laptop George Ghio Photovoltaics 0 09-29-2006 12:42 PM
NYT article on PV shortage wmbjk Photovoltaics 69 09-08-2005 01:26 AM
Re: Welding Cable 1/0 awg SHb Photovoltaics 3 08-14-2005 11:46 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93
