Most sliding glass door frames are made of aluminum or wood, which would not
require a steel door magnet. Is yours not made of aluminum?
"Surebet" <(E-Mail Removed)> wrote in message
news:(E-Mail Removed)...
> I've read many of the FAQ's here and reviewed many of the switches
> available, but believe most of the ones listed as steel door contacts
> are for larger, commercial steel type doors or perhaps steel front
> doors on homes, etc.
> My home was prewired and contacts were installed on the sliding door
> wall doors going out to the back porch, however, when no magnetic
> contacts were installed in the doors.
> Being that the inside of the doors is not solid and mainly hollow
> before you get to the glass is it still not appropriate to use the
> magnet that comes with standard recessed door contacts?
> The reason I ask is because I have looked at some of the steel contact
> magnets out there and they appear to be quite long and I am not sure
> they would fit inside the door wall frame, but the standard recessed
> magnets will.
> So, if I cannot use standard recessed magnets in the door can anyone
> recommend one that might work in thinner door wall type sliding doors
> typically found in residences going out to a back porch?
> Thanks.
