Electronics Forums
Electronics Forums > Newsgroups > Electronics Newsgroups > Electrical Engineering > Re: Sizing a 3 phase transformer
Reply
Thread Tools Display Modes
SQLit
Guest
Posts: n/a
      07-27-2005, 08:43 PM
"gtslabs" <(E-Mail Removed)> wrote in message
news:(E-Mail Removed) ups.com...
> I have been fighting high amp problems with a compressor 10 hp motor
> running at 240V 3 phase. I am getting 100+Amps using my clamp-on meter
> during the initial start before it blows my 50 amp breaker. I am
> considering bumping up the voltage after my 15 hp phase converter to
> 480 using a transformer. As I understand it the KVA = KV * A * 1.73
> for a 3 phase transformer. So a 30 KVA transformer should yield 36Amps
> at 480V. If I use this as the secondary I need 240 72 amp input for
> the primary.
> I assume I would need a tranformer to handle BOTH motors even though
> one is before and one after it? So 25Hp = 22.4 amps? And 30KVA =
> 30,000/746 = 40 HP bigger than my combined motors.
> Am I sizing this 30 KVA transformer correctly or do I need to add in
> other factors and need a bigger transformer?
I agree with the other poster. I believe your going to have to
1. get a bigger phase converter
2. change the motors to single phase
3. install a soft start, which MIGHT create more problems.
The 100 amps is about right for a the motor starting current. (6 x FLA)
Any way of unloading the compressor for start up?
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
Please check calculations in Excel for system sizing please? - Small System Sizing Calculator.xls (0/1) - Small System Sizing Calculator.xls (0/1) Anti-Spam Photovoltaics 3 08-26-2007 03:00 PM
Re: 2-phase source transformer to 3-phase load Ben Miller Electrical Engineering 2 03-01-2006 03:04 AM
Re: 2-phase source transformer to 3-phase load TimPerry Electrical Engineering 2 02-28-2006 03:26 AM
Re: Sizing a 3 phase transformer Don Kelly Electrical Engineering 1 08-24-2005 04:28 AM
Re: Sizing a 3 phase transformer Bud Electrical Engineering 0 07-27-2005 03:52 PM
