Electronics Forums
Electronics Forums > Newsgroups > Electronics Newsgroups > Electrical Engineering > Re: Running a 200V 3 phase motor with 230 volts?
Reply
Thread Tools Display Modes
SQLit
Guest
Posts: n/a
      07-14-2005, 08:52 PM
"gtslabs" <(E-Mail Removed)> wrote in message
news:(E-Mail Removed) oups.com...
> I am trying to run a quincy compressor with two 1 hp 3 phase motors.
> The motor nameplates says 200 volts. I get an overload message running
> 230V from my phase converter. The compressor has an elctronic
> switching system to cycle the 2 pumps and motors.
> Should I step down to 208v volts? I did not see any indicaton of a
> Delta or Wye confirguration.
> Thanks
> Steve
Delta and wye on small motors is not really an issue.
200 volts? What frequency is it?
Is it possible your phase converter can not handle the load?
At one horse I would be considering new single phase motors to get rid of
all the nonsense.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
200V N-channel FET 200V with nsec speed? Joerg Electronic Components 28 11-17-2006 07:29 PM
200V N-channel FET 200V with nsec speed? Joerg Electronic Design 30 11-17-2006 07:29 PM
Re: 200V vs. 208V grids, 3 phase Charles Perry Electrical Engineering 1 09-20-2006 09:31 AM
Re: Running a 200V 3 phase motor with 230 volts? PCK Electrical Engineering 0 07-16-2005 11:32 AM
FIX Tip: CTC203 SMPS running too high 200V or so. Jason D. Electronic Repair 0 11-21-2004 12:24 AM
