Electronics Forums
Electronics Forums > Newsgroups > Electronics Newsgroups > Hobby Electronics > Re: Replacing NiCd batteries in an obsolete Uniden UH-052XR radio?
Reply
Thread Tools Display Modes
Phil Allison
Guest
Posts: n/a
      12-25-2011, 04:33 AM
"c14" <c14@c14
> Although it's 10 years old it works OK and is built like a tank which is
> why I
> would like to replace the long expired detachable NiCad battery pack which
> is no
> longer available as a spare part (model BP-052).
> The problem is that the battery pack is also built like a tank and there
> is no
> obvious way of pulling it apart. There are no screws, glue or weld lines.
> Has anyone tried surgery on one of these? There's no heavy or light end so
> I
> don't know where to start.
> The original battery spec was 7.2v, 950mAh.
** Means there are 6 AA " high capacity" cells inside.
WES may have some Sanyo KR900 cells available - but they will be old stock.
Replacement with NiMHs is the way to go - capacity will then be 2000mAh or
more - check the old cells for height, it may be critical to get
replacements that are no taller.
> There's a captive attachment screw that runs through the middle of the
> pack from
> bottom to top slightly offset to one side, so I'm assuming that it fits in
> the
> gap between 4 of the 6 (?) batteries arranged vertically inside.
** Cut the damn thing open round the middle - use a hack saw if necessary.
Bind it back together with some 3M Strapping Tape - like normal tape but
thicker and with fibreglass strands.
.... Phil
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
Re: Replacing NiCd batteries in an obsolete Uniden UH-052XR radio? Phil Allison Hobby Electronics 0 12-26-2011 04:25 AM
Replacing NiCd camcorder battery with NiMH Happy Friar Misc Electronics 5 08-04-2005 08:36 PM
Replacing an obsolete battery...? Martin Rosenfeld Beginner Electronics 5 03-26-2005 03:37 PM
replacing NiCd batteries Orange Electronic Repair 2 02-11-2004 09:57 PM
How to store NiCd batteries up to a year. Tibur Waltson Electronic Basics 5 01-09-2004 05:54 PM
