Electronics Forums
Electronics Forums > Newsgroups > Electronics Newsgroups > Electronic Repair > Re: Repair Oral B 3D Pulsating Toothbrush
Reply
Thread Tools Display Modes
Martin Whybrow
Guest
Posts: n/a
      08-01-2008, 12:13 AM
"Nelson" <(E-Mail Removed)> wrote in message
news:(E-Mail Removed) .com...
> Braun Oral B 3D Pulsating Toothbrush, Model 4729
> OK, so I know it would be cheaper to just buy a new one but I like the
> challenge... and I just bought a pack of 7 replacement brushes... grrr!
> This model charges a rechargeable battery inductively and is sealed up
> tighter than a ... (supply your own metaphor).
> Anyone know how to disassemble one of these? I'm assuming the battery
> has reached the end of it's charging life cycle, but I have to open it
> up to find out. And if it has, I'll probably have to jury rig in a
> replacement since I can't find anyone selling replacement parts on the
> web. My guess is that Braun doesn't make them available.
> Google is pretty much worthless on this since it pushes all the
> advertising sites to the top.
> Nelson
> ** Posted from http://www.teranews.com **
I recently took a similar unit apart, the charger post engages in the base
of the toothbrush and can be used to twist the bottom of the unit off and
the guts then slide out. Mine had an O ring seal so it would, theoretically,
be possible to reassemble it; the top bush on mine was so worn that it had
leaked and it wasn't worth the effort to clean up as it needed a new NiCd
anyway. Other similar units have a cross slot moulded into the base and a
matching, for want of a better word, screwdriver blade moulded on the
underside of the charging base; the dismantling procedure is similar.
Martin
martin<dot here>whybrow<at here>ntlworld<dot here>com
Geo
Guest
Posts: n/a
      08-01-2008, 12:10 PM
On Fri, 1 Aug 2008 01:13:05 +0100, "Martin Whybrow"
Yes - my wife's OralB toothbrush has stopped working a couple of times and this
is how it opens. The main problem is corrosion. It has suffered a corroded main
pcb track (along the edge of the pcb)to the power FET - replaced with wire link.
Also corroded through charging coil wire at the pcb solder pad. I think the
charging coil wires were short to begin with but I was able to get some extra
length (forget how) so that it now opens without breaking them.
I sprayed the pcb with varnish a couple of years ago but it has recently been
playing up again so will have to dismantle again soon.
Couple of 74 series chips LV00 and LV4060. The timer stopped working so
suspecting leakage/corrosion again.
Geo
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
Re: Repair Oral B 3D Pulsating Toothbrush Bob Shuman Electronic Repair 6 08-04-2008 06:23 PM
Re: Repair Oral B 3D Pulsating Toothbrush Rodney Pont Electronic Repair 1 08-01-2008 08:03 PM
Re: Repair Oral B 3D Pulsating Toothbrush me@privacy.net Electronic Repair 0 07-31-2008 10:11 PM
FREE Oral-B Pro Toothbrush - check out the features nabazamail@yahoo.com Electronic Repair 0 01-14-2005 05:07 AM
Braun/Oral B Power Toothbrush Owners Needed Oral B PowerBrush Survey General Electronics 1 06-11-2004 09:50 PM
