Electronics Forums
Electronics Forums > Newsgroups > Electronics Newsgroups > Electronic Design > Re: Plasma Paper Cutter
Reply
Thread Tools Display Modes
Boris Mohar
Guest
Posts: n/a
      11-12-2009, 11:56 AM
On Thu, 12 Nov 2009 00:37:29 -0800, D from BC <(E-Mail Removed)>
wrote:
>I was thinking of buying a paper guillotine to cut circuit boards.
>While shopping for that, I discovered a plasma paper cutter that cuts
>up to 40 sheets.
>http://www.staples.ca/ENG/Catalog/ca...affixedcode=WW
>Neato.. I should have thought of that.
Well I'll be...
Boris
Ralph Barone
Guest
Posts: n/a
      11-12-2009, 02:57 PM
In article <(E-Mail Removed)>,
> >up to 40 sheets.
> >http://www.staples.ca/ENG/Catalog/ca...238&affixedcod
> >e=WW
> Well I'll be...
> Boris
Of course, it would be much more interesting if it actually USED plasma
to cut the paper...
amdx
Guest
Posts: n/a
      11-12-2009, 05:36 PM
"D from BC" <(E-Mail Removed)> wrote in message
news:(E-Mail Removed)...
> On Thu, 12 Nov 2009 06:57:18 -0800, Ralph Barone <invalid@not_real.ca>
>>> >up to 40 sheets.
>>> >e=WW
>>> Well I'll be...
>>> Boris
>>to cut the paper...
> There's no plasma...
> http://www.fellowes.com/fellowes/mat...8ManualEng.pdf
> Embarrassed and disappointed. Fk this post will be on servers for 2
> years or more.
> That's it...no more late night posts..
Aww, don't worry about it, you could have a posting background like Phil.
Mike
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
Re: Plasma Paper Cutter TheM Electronic Design 10 11-15-2009 07:57 PM
Re: Plasma Paper Cutter Baron Electronic Design 0 11-12-2009 08:03 PM
Re: Paper Cutter Next Door Causing Power Surges Beachcomber Electrical Engineering 0 06-24-2007 01:46 AM
Re: Paper Cutter Next Door Causing Power Surges phil-news-nospam@ipal.net Electrical Engineering 0 06-23-2007 09:10 PM
Re: Paper Cutter Next Door Causing Power Surges phil-news-nospam@ipal.net Electrical Engineering 0 06-23-2007 09:03 PM
