Electronics Forums
Electronics Forums > Newsgroups > Electronics Newsgroups > Electronic Basics > Re: Permanent magnet alternators?
Reply
Thread Tools Display Modes
Jamie
Guest
Posts: n/a
      03-11-2010, 11:05 PM
Michael wrote:
> Why do vehicle alternators not employ permanent (Nd) magnets?
cost, heat, and size ?
TE Cheah
Guest
Posts: n/a
      03-12-2010, 11:21 AM
| car alternators are regulated by adjusting the current to their
| field coils; in effect their motor constants are changed by the
| regulator circuit. This makes them fairly easy to control with very
| little, and efficient, circuitry.
I loath the amperes wasted by alternator's excitor circuit before
engines are started successfully. Does a brushless alternator
likewise waste amperes before an engine is started successfully ?
Sjouke Burry
Guest
Posts: n/a
      03-13-2010, 04:47 AM
You must hate 99.8 percent of all cars, or more likely
you are trolling.
Jasen Betts
Guest
Posts: n/a
      03-13-2010, 08:44 AM
have you measured it? typically it is exactly enough to light the
'altenator warning' lamp.
no, but it could make the engine harder to start.
I assume you mean a permanent magnet altenator, the are brushless
electromagnet field altenators.
--- news://freenews.netfront.net/ - complaints: (E-Mail Removed) ---
TE Cheah
Guest
Posts: n/a
      03-13-2010, 01:41 PM
No.
| typically it is exactly enough to light the 'altenator warning' lamp.
Wikipedia says a 70 amp alternator uses 2 amp as exciter, so I
think exciter should be activated only after engine starts.
How ?
No, see http://en.wikipedia.org/wiki/Alterna...ss_alternators
, in 4-09 1 Toyota salesman said new Camry ( but not lower models
) has this.
I suspect rare earth magnets can't be used ; heat will ruin these
magnets.
Jasen Betts
Guest
Posts: n/a
      03-13-2010, 09:32 PM
> No.
> How ?
the last altenator I looked closely at an altenator it took the exciter
current from separate (positive side) rectifier diodes (D+ terminal) which
was fed back into the altenator exitation (DF terminal) by the regulator
with it's stopped or at low RPM the exciter current coming from the lamp
circuit is is only a few hundered millianps, once the speed gets up
the rectifier kicks in to supply the power.
Those things still need power for the exiters stationary winding.
if that current is't taken mostly from the rectifiers then it's going
to cost the same,
if you're worried you could rig a horn relay (form C automotiver relay) to
cut the feed to the altenator when you activate the starter.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
max gauss of a permanent magnet dc motor field? BobG Electronic Basics 3 09-02-2005 12:13 AM
Permanent Magnet Alternator Torque and volts? BobG Electronic Basics 2 06-12-2005 04:27 AM
The Microwave Magnetron Tube Structure and OperationThe Magnetron Tube Br Dan Izzo General Electronics 5 09-08-2004 08:10 PM
permanent magnet alternator for turbine matthew Electronic Design 4 09-05-2003 02:15 PM
why doesn't my permanent magnet alternator work? matthew Electronic Design 4 07-23-2003 05:19 AM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93
