Electronics Forums
Electronics Forums > Newsgroups > Electronics Newsgroups > Security Alarms > Re: Panel Grounding vs. Lightning Rod Grounding
Reply
Thread Tools Display Modes
w_tom
Guest
Posts: n/a
      10-23-2008, 06:15 PM
On Oct 23, 11:32 am, bud-- <budn...@isp.com> wrote:
> “Intruder alarm systems using wires between sensors and their central
> control unit can be disturbed - and damaged in severe cases - by
> lightning striking close to the house. The wires necessary for this
> type of installation extend to all points of the house and act as an
> antenna system that collects energy from the field generated by the
> lightning strike, ...
Bud forgets to mention how easy that problem is eliminated even by
protection inside panels. That thousands of volts is easily
diminished to near zero by a milliamp conductor - the neon glow lamp.
Bud has hyped a fear and ignored the solution that already makes the
problem irrelevant.
What field is far more destructive? If trying to earth a surge via
a plug-in protectors, then the safety ground wire inside Romex induces
surges on all adjacent wires. Fields from nearby strikes are easily
made irrelevant. Fields created by an earthing wire not separated
from all other wires can induce surges on those other wires. Only one
of us actually learned this stuff from both IEEE papers and
experience.
Meanwhile Martzloff describes in the very first conclusion of his
IEEE paper how a plug-in (point of connection) protector can
contribute to damage of adjacent electronics (as also demonstrated on
Page 42 Figure 8):
> Conclusion:
> 1) Quantitative measurements in the Upside-Down house clearly
> show objectionable difference in reference voltages. These occur
> even when or perhaps because, surge protective devices are
> present at the point of connection of appliances.
Bud likes to forget the parts that show how obscenely profitable plug-
in protectors can even contribute to electronics damage.
Bob Worthy
Guest
Posts: n/a
      10-23-2008, 07:31 PM
Why don't you guys get a room? Jeeeeze!!!
This love affair needs to go somewhere else.
"w_tom" <(E-Mail Removed)> wrote in message
news:5a312c4b-ba2c-4476-bdae-(E-Mail Removed)...
problem irrelevant.
experience.
Page 42 Figure 8):
> Conclusion:
bud--
Guest
Posts: n/a
      10-24-2008, 03:46 PM
> problem irrelevant.
I said direct pickup was low energy and terminals "*may* not be
protected". Not all equipment is protected. I tried to cover the
sources of surge damage. Martzloff says in the NIST guide (quoted
above) direct pickup can be a problem.
> Page 42 Figure 8):
w_ likes to forget that Martzloff said in the same technical paper
"Mitigation of the threat can take many forms. One solution.
illustrated in this paper, is the insertion of a properly designed
[multiport plug-in surge suppressor]."
Martzloff says in the NIST guide plug-in suppressors are effective.
The IEEE guide says plug-in suppressors are effective.
Poor w_ doesn’t think they work.
bud--
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
Re: Panel Grounding vs. Lightning Rod Grounding JoeRaisin Security Alarms 33 10-31-2008 04:05 PM
Re: Panel Grounding vs. Lightning Rod Grounding Jim Security Alarms 27 10-13-2008 10:34 PM
Re: Panel Grounding vs. Lightning Rod Grounding tourman Security Alarms 3 09-26-2008 04:59 AM
Re: Panel Grounding vs. Lightning Rod Grounding Jim Security Alarms 4 09-24-2008 03:11 AM
Re: Panel Grounding vs. Lightning Rod Grounding tourman Security Alarms 2 09-22-2008 02:17 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93
