Electronics Forums
Electronics Forums > Newsgroups > Electronics Newsgroups > Electronic Design > Re: Oscilloscopes
Reply
Thread Tools Display Modes
Re: Oscilloscopes
Rich Webb
Guest
Posts: n/a
      02-07-2010, 10:29 PM
On Sun, 7 Feb 2010 15:31:46 -0600, "RogerN" <(E-Mail Removed)> wrote:
>What's the best scope to get for the money for mostly digital circuits?
>I'll have some analog but nothing real high frequency, like analog
>connections to the microcontroller, maybe some SMPS circuits. I was looking
>at some microcontroller and fpga designs that you can get kits starting at
>less than $100 and going up with more speed and features. Also, I see on
>eBay you can get some nice looking Techtronics scopes for $350 or so, 4
>channel digital, etc. Just wondering if something like the AVR scope would
>be a useful tool or if I would be wishing I went ahead and bought a nice
>used scope on eBay.
"The" AVR scope? Hard to comment on it, knowing only that...
In general, though, USB-based scopes typically don't have particularly
high sample rates. I'd suggest looking into one of the smaller "real"
digital 'scopes, such as Instek or Rigol. There was a loooong discussion
on this back in December in this group with the subject "A good digital
oscilloscope?" (As you may imagine, this comes up fairly often here.)
A USB logic analyzer, on the other hand, is a useful gadget. I've been
using an Intronix for years and wouldn't go anywhere without it. Overdue
for a new model, though. http://www.pctestinstruments.com/
Rich Webb Norfolk, VA
mike
Guest
Posts: n/a
      02-08-2010, 10:25 AM
RogerN wrote:
> "Rich Webb" <(E-Mail Removed)> wrote in message
> news(E-Mail Removed)...
>>> looking
>>> would
>>> used scope on eBay.
> Here's some of the stuff I was looking at, some stand alone, some use PC:
> http://www.youtube.com/watch?v=fxViYQ5WWOE
That looks closest to a whole oscilloscope.
> http://www.fpga4fun.com/digitalscope.html
Looks like an interesting toy for dedicated use. You'll be disappointed
with all the hassle of trying to use it as a general purpose scope.
> http://cgi.ebay.com/Pocket-Oscillosc...item25589f14ff
This is a TOY. 1MHZ sample rate...useless...
> But I thought this looked pretty nice:
> http://cgi.ebay.com/Tektronix-2465-F...item20af54a6f4
2465 is a VERY nice scope. Beware that they have a part that goes bad
and it's made of unobtanium. Only way to get the chip is to buy another
scope with a chip that hasn't failed YET. I sold mine while it was
still working.
> RogerN
Buy one of the toy scopes above if ANY of the following are true.
1 You are an experienced measurement tech and you know every measurement
you'll ever want to make and can verify that the unit can measure it.
2 You have too much free time on your hands, are tired of playing
solitaire and need a better time waster.
3 You want hands-on experience with the easy part of crappy digital
oscilloscope designs.
4 You want to spend more time futzing with the scope than working
on the project.
Never make your first scope a KIT unless #1 applies.
Never make your first scope a computer accessory unless #1 applies.
Never buy a digital (or analog) scope that doesn't let you view
what happens before the trigger event.
There may be exceptions, but a scope that doesn't have an input
attenuator and specified input capacitance is a poor choice.
Getting the signal into the acquisition unit and scaled appropriately
is HARD for the novice. Last thing you need is a scope that
smokes every time you touch the 12V power supply.
Don't buy a cheap scope on EBAY. Freight costs more than the scope
is work, even if you do get lucky and it works. A scope that's
guaranteed to work ain't gonna be cheap. Be especially wary of
"can't test it, don't have time to test it, don't have equipment
to test it". That's code for "broken".
I once asked about a "can't test it" scope on ebay. He accidentally
replied from an email account at the world's largest used test equipment
dealer. Seems that they sell the bad stuff out the back door on ebay.
If you want to make oscilloscope measurements, buy a real commercial
scope. I prefer analog for a first scope.
Find a local ham and put out the word you want a scope.
Most of us have more scopes than we can ever use.
Maybe you can borrow one 'till you figger out what you need.
Geography matters, but put a request for a scope on Craigslist or
equivalent.
You have a LOT more options if you are experienced, already have
a scope you can use to fix a busted new scope etc.
If you're a novice, go get a 30-40 year old analog scope CHEAP.
Rich Webb
Guest
Posts: n/a
      02-08-2010, 01:53 PM
On Mon, 8 Feb 2010 06:05:19 -0600, "RogerN" <(E-Mail Removed)> wrote:
>Lot of good info there, thanks. I have a 10mhz leader single trace scope
>that worked fine last time I tried it. Do you have any recommendations on a
>used repairable scope? I've seen some recommend the Techtronics 465, since
>a lot of what I plan to use it on is digital signals/communication, I
>thought storage would almost be necessary.
If you're interested in the information content of a data stream instead
of (or in addition to) the waveform, then you'll get a lot more mileage
out of a logic analyzer than a 'scope. The oscilloscope will let you
check the rise/fall times, envelope, eye diagram, etc. The analyzer will
let you read an I2C or CANbus conversation right off the screen without
a lot of tedious bit counting.
mike
Guest
Posts: n/a
      02-08-2010, 02:02 PM
RogerN wrote:
> "mike" <(E-Mail Removed)> wrote in message
> news:hkooth$5qh$(E-Mail Removed)...
>>>>> looking
>>>>> at
>>>>> on
>>>>> would
>>>>> nice
>>>>> used scope on eBay.
>> scope with a chip that hasn't failed YET. I sold mine while it was still
>> working.
>>> RogerN
>> on the project.
>> equivalent.
Drag it out and use it. You'll quickly learn what features you need.
Already done that TEK 465, 7704 and relatives.
The 7704 is handy 'cause you can get plugins for logic analysis,
spectrum analysis, TDR, curve tracer etc.
You need to say a LOT more about what you mean by digital
signals/communication.
RS-232 is communication and well within the capability of your leader.
Demodulating Cellphone signals is quite another matter.
An oscilloscope is a poor substitute for good design judgment.
It's a time domain instrument that is very good at looking at
individual transients. You want to know the risetime, amplitude
and "cleanliness" of signals. An oscilloscope with a delay line
will let you do that, as long as it has sufficient bandwidth for the
risetimes you're observing. Two channels will let you see relationships
between two signals. As long as you stay away from the maximum speed
stuff will run, you'll have few problems that need high resolution timing.
Once you get beyond that, it becomes complicated real fast.
Just probing the system is a nightmare.
Your problem is triggering on the desired event. You quickly get into
logic analyzer types of triggering and display. A two-channel scope
is better than one. 4 is better, but still not too helpful if you
need to trigger on 8 or 64. I once got so frustrated that I built a fixture
with a PAL on it. Reprogrammed the PAL for each complex trigger
and used that as one channel into a logic analyzer.
Digital storage has some benefits.
Lets you see what happened to signals WAY before the trigger event.
But you still have to come up with some way to trigger on the symptom.
Lets you see signals WAY to slow to be visible on an analog scope.
I futzed around with a battery tab spot welder for years. About
10 minutes after I got my first digital storage scope, it was
working a LOT better. I could see what was happening.
Post processing can come in handy. It's kinda nice to set a square
wave to exactly 50% by punching the FFT button and nulling odd harmonics.
But digital storage has lots of issues with aliased displays,
triggering, single shot sampling rate, display update rate...the
list is endless. If you know what to expect, you can deal with it.
But I still get confused sometimes.
What you need depends on whether you're debugging your own design.
I use PIC processors for most of my hobby stuff. I don't run them
faster than they're designed to go. I fix problems by inspecting
the code and using "print statements". If needed, I can use a pin
to generate a scope trigger exactly where I want to look. I rarely
use more than two scope channels.
If you're reverse-engineering or repairing someone else's stuff,
you may need a LOT more capability.
For most of my stuff, I use a TEK 308 logic analyzer. It decodes
RS-232 and GPIB. It generates word triggers into a TEK TDS540
digital scope. It's OVERKILL for most things.
You can do a lot of stuff with a cheap analog scope.
Complex stuff needs $60K equipment.
There ain't much in between. Might as well go cheap
and suffer the consequences of not being able to do some stuff.
Patience pays off when you're looking for equipment.
My TDS540 was free...the 308 was $5...plus about $10 in parts
and a week to get it all working...but that's not the norm.
Fixing undocumented stuff is not for the faint of heart.
> RogerN
Nico Coesel
Guest
Posts: n/a
      02-08-2010, 11:02 PM
That depends on the depth. If you get a DSO, get one with at least 1Ms
record length and peak detection otherwise you'll miss glitches.
I like the Tektronix logic analyzers for that. The trigger pattern
(program is a more accurate description) can be quite complex
including counters and stuff.
If the memory is deep enough you can just grab data and look through
it. My logic analyzer has 4Ms per channel storage. I just trigger it
on something obvious and look what is going on.
Indeed. There are many good deals on Ebay. IMHO second hand equipment
from HP/Agilent or Tektronix is better than buying something new from
a Chinese brand. I still need to replace my trustworthy Tek 2230 DSO
but I still didn't find something that really fits the bill.
Failure does not prove something is impossible, failure simply
indicates you are not using the right tools...
nico@nctdevpuntnl (punt=.)
JosephKK
Guest
Posts: n/a
      02-12-2010, 05:09 AM
>>at some microcontroller and fpga designs that you can get kits startingat
>>used scope on eBay.
That is pretty good for an LA at that price.
JosephKK
Guest
Posts: n/a
      02-15-2010, 12:46 AM
>>>less than $100 and going up with more speed and features. Also, I seeon
>>>used scope on eBay.
After Nico's find i may have to amend that.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
Re: Oscilloscopes D Yuniskis Electronic Design 8 02-14-2010 07:32 PM
USB oscilloscopes no_one General Electronics 1 02-13-2006 04:04 AM
Mixed Signal Oscilloscopes vs Digital Signal Oscilloscopes (MSO vs DSO) benn686@hotmail.com Electronic Basics 3 12-13-2005 11:27 PM
PC Oscilloscopes mark349@lycos.com Electronic Components 8 10-08-2005 09:52 AM
Protek Oscilloscopes Rylos Electronic Basics 5 09-20-2004 10:05 AM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33
