Electronics Forums
Electronics Forums > Newsgroups > Electronics Newsgroups > Electronic Design > Re: Oops
Reply
krw@att.bizzzzzzzzzzzz
Guest
Posts: n/a
      02-24-2012, 03:44 AM
On Thu, 23 Feb 2012 21:53:22 -0500, Phil Hobbs
<(E-Mail Removed)> wrote:
>Robert Baer wrote:
>> John Larkin wrote:
>> > On Wed, 22 Feb 2012 23:34:04 -0800, Robert Baer
>> >> Phil Hobbs wrote:
>> >>> John Walliker wrote:
>> >>>> http://news.sciencemag.org/sciencein...8O-G8w.twitter
>> >>>> It appears that the faster-than-light neutrino results, announced last
>> >>>> September by the OPERA collaboration in Italy, was due to a mistake
>> >>>> after all. A bad connection between a GPS unit and a computer may be
>> >>>> to blame.
>> >>>> According to sources familiar with the experiment, the 60 nanoseconds
>> >>>> discrepancy appears to come from a bad connection between a fiber
>> >>>> optic cable that connects to the GPS receiver used to correct the
>> >>>> timing of the neutrinos' flight and an electronic card in a computer.
>> >>>> After tightening the connection and then measuring the time it takes
>> >>>> data to travel the length of the fiber, researchers found that the
>> >>>> data arrive 60 nanoseconds earlier than assumed.
>> >>>> John
>> >>> That isn't too plausible unless they have really, really slow edges on
>> >>> that light pulse. I sort of suspect that they loosened a connector,
>> >>> removed 40 feet of fibre, and then tightened it again.
>> >>> Cheers
>> >>> Phil Hobbs
>> >> Light fibers are THAT slow? Then why not use less costly coax?
>> > About 2/3 c or something like that. About the same as coax.
>> > We use fiber because of the horrible pulse transmission of coax over
>> > tens of meters... rise times go to hell, and ground loops make things
>> > worse. You can shoot a 10 ns pulse over a kilometer of multimode fiber
>> > and it hardly changes. You can get 10 ps RMS edge jitter with cheap
>> > parts. Ditto a hundred km of singlemode.
>> > Multimode fiber is cheaper than good coax anyhow.
>> Hmm..as i remember, coax i used ran in the 80-90% C, a lot faster
>> than 60-70% cited for fiber.
>> Signal loss and edge loss over a long line is another story, natch.
>Foam dielectric coax can get up there, but it has a lot of drawbacks,
>e.g. when you bend it, the centre conductor tends to cut through the
>foam and cause all sorts of nasty impedance discontinuities, and in
>really bad cases, may even short to the shield.
The GoreTex "high-speed" coax we used in the '80s was pretty decent stuff,
albeit expensive as hell.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
Oops schematic mistake on first message. Correction made --> Help. Transistor circuit that connect or disconnect 75ohm terminator for video application LRCR General Electronics 12 02-04-2006 11:18 PM
Oops schematic mistake on first message. Correction made --> Help. Transistor circuit that connect or disconnect 75ohm terminator for video application LRCR Electronic Components 18 02-04-2006 11:18 PM
oops! Lord Garth Electronic Basics 0 10-27-2004 09:09 PM
Oops.. Watson A.Name - \Watt Sun, the Dark Remover\ Electronic Components 11 05-07-2004 07:10 PM
Oops!! Winfield Hill Electronic Design 4 09-12-2003 11:51 PM
