Electronics Forums
Electronics Forums > Newsgroups > Electronics Newsgroups > Electronic Basics > Re: Need to confirm resistor selection
Reply
Thread Tools Display Modes
ehsjr
Guest
Posts: n/a
      08-27-2011, 05:04 AM
SklettTheNewb wrote:
> I don't like to start a post with a disclaimer, but in this case I
> must; I am a programmer, not a EE or hardware guy. However I can
> handle some very simple tasks and do enjoy the rare chance to work
> with electronics.
> So, with that said I find myself in a situation where I am taking over
> on a circuit design for a project we are working on. Logic problems I
> can handle, but it's some of the more rudimentary electronics issues
> that I stumble on. At this point I need to specify a resistor network
> for use with a SSR (http://www.clare.com/home/pdfs.nsf/www/
> CPC1014N.pdf/$file/CPC1014N.pdf) that draws 2mA. The SSR requires
> 1.2v for it's input.
> The resistor networks are needed to bring the 5v source down to the
> required ~1.2v range for the SSR input. An engineer that was (no
> longer is) involved on this project specified a 1k ohm resistor.
> Today I was faced with the question of which power rating was needed
> for this use. I did some research and found the formula:
> P = V2 / ohm
> or
> P = 25 / 1,000 = 0.025mW
Not mW, Watts. P = .025W - but that's not the best way to figure
the R value. See below.
> Is my understanding of the calculation correct? Did I provide enough
> information?
> Thanks for reading,
> Steve
A low wattage 1K resistor will be great for you.
The SSR uses an LED with a Vf of 1.2 and an If of 2 mA.
That If figure - 2 mA - is the maximum current needed to
guarantee that the SSR will be energized. You could run
the LED current a lot higher than that. What you want to
do is ensure that the LED gets _at least_ 2 mA and limit
the current to something a lot higher.
With a 5V supply, and ~1.2 volts dropped across the LED, you
want to drop ~3.8V across the resistor. At 3.8 mA a 1K resistor
will drop 3.8 volts. The LED inside the SSR will happily draw
the 3.8 mA - in fact, it will draw as much current as it can get.
The 1K resistor limits what it can get to 3.8 mA. The LED could
draw a helluva lot more current without damage to itself if the
resistor was a lower value, but there is no need to have it do
that, as the 1K will give it well over the 2 mA maximum it needs
for guaranteed correct operation.
The power dissipation for the resistor is computed with P = I^2*R,
or .014 watts in this case, so use .03 watts or higher for the
resistor wattage.
Ed
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
I need a tutorial on MOSFET gate resistor selection bonedoc General Electronics Chat 7 01-17-2012 09:54 PM
How to confirm a TV tuner is at fault? alitonto Hobby Electronics 17 08-06-2005 04:21 PM
How to confirm a TV tuner is at fault? alitonto Electronic Repair 16 08-06-2005 04:21 PM
Sony KV-2670 R has problems and is probably dead but please confirm John Stevens Electronic Repair 4 08-02-2005 12:32 AM
Re: Yes i confirm Wireless unreliability since 2001 Gary Security Alarms 0 07-05-2003 05:18 PM
