Electronics Forums
Electronics Forums > Newsgroups > Electronics Newsgroups > Electronic Equipment > Re: Mains transformer weights
Reply
Thread Tools Display Modes
Sjouke Burry
Guest
Posts: n/a
      01-26-2012, 11:50 PM
"Jim Hawkins" <(E-Mail Removed)> wrote in
news:(E-Mail Removed) m:
> Jim Hawkins wrote:
>> Is a mains transformer designed for 60Hz significantly lighter than
>> one of the same VA rating designed for 50Hz ?
>> Jim Hawkins
> Following on from this, why is it that electricity generation is
> limited to such low frequencies as 50 or 60 Hz ?
> As the frequency rises, the energy lost through electromagnetic
> radiation from the wires rises, but is it really a significant amount
> ? Would it be significant at 1 kHz ? If not, why isn't generation
> done at that sort of frequency ? The savings in transformer weights
> and sizes everywhere would be enormous. Is it because of mechanical
> engineering limitations on the rotational speeds of the large rotary
> generators the power stations use ?
I have worked in the airforce, they also used 400 Hz
on(or under) the ground.
You could hear the 3rth harmonic(1200 Hz) all over the
place, wich is not such a good idea in your home.
Very iritating for new workers, old workers had a
measurable dip in their hearing curve, and could not
hear that frequency anymore.Permanent damage.
Cydrome Leader
Guest
Posts: n/a
      02-27-2012, 12:58 AM
>>> Jim Hawkins
Apparently they had line frequencies as 16.66 Hz and other strange stuff
like 25Hz, which was last used in the US for railway lines.
Here's a little about this:
http://www.nycsubway.org/articles/rotary_converter.html
josephkk
Guest
Posts: n/a
      05-20-2012, 08:23 PM
>news:(E-Mail Removed) om:
>>> Jim Hawkins
I had dips at 2400 and 4800 Hz as well as 1200 when i was done with the
navy.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
Re: Mains transformer weights krw@att.bizzzzzzzzzzzz Electronic Equipment 9 01-31-2012 08:19 PM
Re: Mains transformer weights Uwe Hercksen Electronic Equipment 0 01-26-2012 11:12 AM
Re: Mains transformer weights Jamie Electronic Equipment 1 01-17-2012 11:27 AM
Re: Mains transformer weights krw@att.bizzzzzzzzzzzz Electronic Equipment 0 01-16-2012 04:56 PM
Re: Mains transformer weights PeterD Electronic Equipment 0 01-16-2012 04:36 PM
