On Sat, 16 Jan 2010 21:54:26 +0100, Falk Willberg
<(E-Mail Removed)> wrote:
>krw schrieb:
>> On Sat, 16 Jan 2010 20:36:41 +0100, Falk Willberg
>>> RogerN wrote:
>>>> That would be a nice microcontroller project, use a temperature
>>>> sensor and RTCC, if it's freezing out, start the car so many minutes before
>>>> the end of shift, the colder it is, the more warm up time is allowed.
>>> Are you really going to waste 50% gas by blowing warm air (and harmful
>>> gases) out of the exhaust, torture the engine by running it cold and
>>> idle for minutes?
>> 50%?
>A rough guess. Hot exhaust gases, heat radiation...
It's *all* waste of you aren't going anywhere.
>> The car isn't "tortured" by running it at idle. OTOH, it isn't
>> good running a car at high speed until it's warmed some.
>Running an engine at low temperatures causes a lot of wear. Starting it
>and drive at reasonably low RPM is the best way to reach operating
>temperature in short time.
Nonsense. The wear is at least as great by driving it at any speed as
it is by letting it idle. You *should* idle at least as long as it
takes to get off high-idle. Some recommend warming then engine
completely.
>> The car
>> needs to be started anyway. It may "waste" a little gas by idling a
>> *little* longer than normal.
>The amount of waste depends on what you consider a "little longer".
Long enough for the engine to come up to temperature.
>>> Why not use an auxiliary heater and control this with a micro?
>>> That would be a smart approach.
>> With what are you going to power this "heater". Electricity (from
>> where?) rather than waste heat?
>Not necessarily electricity. This is common practice in Scandinavia.
Anything other than waste heat is even more energy wasted.
>Auxiliary heaters can be powered with gas or diesel. Besides that there
>are two types. One heat the coolant, thus heating the car's inside and
>avoid cold starting the engine.
You're going to have a gasoline fire burning to keep the engine warm?
>The other type only heats the inside of the vehicle.
....and you bitch about "wasting" a little gas.
>Both have a much better efficiency than an idling engine.
Nonsense. Heat from the engine is free.
>http://www.webasto.us/am/en/am_auto_heaters.html
>Falk
