Electronics Forums
Electronics Forums > Newsgroups > Electronics Newsgroups > Electronic Basics > Re: Higher wattage for a resistor ever bad?
Reply
Thread Tools Display Modes
Jon Kirwan
Guest
Posts: n/a
      08-17-2011, 02:21 AM
On Tue, 16 Aug 2011 19:11:18 -0700 (PDT), "larry moe 'n
curly" <(E-Mail Removed)> wrote:
>When I come across a burnt resistor, I usually replace it with one
>rated for twice the wattage as the original, but I was told it's
>sometimes bad to do that. Why? I'm not referring to fuse resistors
>but ordinary carbon composition resistors.
Hmm. Not obvious why there would be a worry. The
differences amount to the following:
1) Longer body, and
2) Larger body diameter, and
3) More weight, and
3) Lower temperature at given power dissipation.
Other than the thought that it does have a fuse function,
which you dispute above, there can be:
A) The longer body or larger body diameter causes the wiring
to be too close to nearby parts, mechanically stresses
something, or blocks some hole that needs to be clear, or
B) The greater weight causes some problem (such as if it
were at the end of a propeller, for example), or
C) The lower temperature affects something else that depends
on the earlier higher temperature.
In short, I can't think of a problem that would not be pretty
obvious when you were replacing it. But then my imagination
ain't what it used to be, either.
Jon
Don Lancaster
Guest
Posts: n/a
      08-17-2011, 03:13 PM
> 1) Longer body, and
> 3) More weight, and
> Jon
If the original resistor burnt, something is wrong and needs fixed.
Replacing the resistor with a bigger one is not in any manner a solution.
Many thanks,
Don Lancaster voice phone: (928)428-4073
Synergetics 3860 West First Street Box 809 Thatcher, AZ 85552
rss: http://www.tinaja.com/whtnu.xml email: (E-Mail Removed)
Please visit my GURU's LAIR web site at http://www.tinaja.com
Jon Kirwan
Guest
Posts: n/a
      08-17-2011, 08:34 PM
On Wed, 17 Aug 2011 08:13:16 -0700, Don Lancaster
>> 1) Longer body, and
>> 3) More weight, and
>> Jon
> fixed.
That _may_ be the case. You don't know and neither do I. But
the OP is asking about whether or not it could be bad, so I
think it's good you point this out -- others already have,
though, so there's no need to do it twice. And I already
know, so it doesn't help telling me.
> manner a solution.
Designers aren't always perfect. Some of them are even
hobbyists or worse. These are carbon and the devices may be
old and just gradually failed -- I've seen that happen. They
do develop fissures and fail, sometimes just from vibration
sometimes from just aging or part variability that wasn't
accounted for. It _may_ be a problem elsewhere in the
circuit. It _may_ just be a failed part, itself.
I'm just glad the OP is getting all the options laid out.
Jon
Spehro Pefhany
Guest
Posts: n/a
      08-18-2011, 12:26 AM
On Wed, 17 Aug 2011 13:34:16 -0700, the renowned Jon Kirwan
>Jon
S/he should keep in mind that all absolute statements made on Usenet
are false.
Best regards,
Spehro Pefhany
"it's the network..." "The Journey is the reward"
(E-Mail Removed) Info for manufacturers: http://www.trexon.com
Embedded software/hardware/analog Info for designers: http://www.speff.com
Jon Kirwan
Guest
Posts: n/a
      08-18-2011, 03:14 AM
On Wed, 17 Aug 2011 20:26:20 -0400, Spehro Pefhany
>>Jon
>are false.
Jon
JW
Guest
Posts: n/a
      08-18-2011, 09:28 AM
On Wed, 17 Aug 2011 08:13:16 -0700 Don Lancaster <(E-Mail Removed)> wrote in
Message id: <(E-Mail Removed)>:
>> 1) Longer body, and
>> 3) More weight, and
>> Jon
Not always true. Open up a Keithley 236 or 237 (if anyone has one) and
check the 2 watt drain resistors across the main input capacitors in the
power supply. You'll likely see that they've been getting extremely hot.
In time their resistance will lower until they burn out. Hopefully the
fuse goes first, but I've seen them catch fire. Replacing them with a 3
watt resistor fixes them.
Not true in the case above.
krw@att.bizzzzzzzzzzzz
Guest
Posts: n/a
      08-18-2011, 10:14 PM
>>> 1) Longer body, and
>>> 3) More weight, and
>>> Jon
Well, it's obvious that using a 2W resistor is "something wrong". ;-)
Our rule was 50% underrating on all carbon comps, and tantalum caps. I try to
do the same with thick-film SMTs, now.
Jon Kirwan
Guest
Posts: n/a
      08-19-2011, 04:05 AM
On Thu, 18 Aug 2011 17:14:45 -0500, "(E-Mail Removed)"
>>>> 1) Longer body, and
>>>> 3) More weight, and
>>>> Jon
><snip>
But I think his point in telling the story is that replacing
a resistor with a higher wattage isn't _always_ masking some
other problem. Sometimes, it is fixing the _actual_ problem
at hand. He was responding to Don's absolutist claim that,
"replacing the resistor with a bigger one is not in any
manner a solution."
Jon
Guest
Posts: n/a
      08-19-2011, 04:19 AM
On Thu, 18 Aug 2011 21:05:04 -0700, Jon Kirwan <(E-Mail Removed)>
>>>>> 1) Longer body, and
>>>>> 3) More weight, and
>>>>> Jon
>><snip>
>manner a solution."
I guess a smiley wasn't enough to tip you off that the point wasn't a serious
one. Not that it surprises me that you didn't get it.
Jon Kirwan
Guest
Posts: n/a
      08-19-2011, 05:26 AM
On Thu, 18 Aug 2011 23:19:27 -0500, "(E-Mail Removed)"
>>>>>> 1) Longer body, and
>>>>>> 3) More weight, and
>>>>>> Jon
>>><snip>
>>manner a solution."
One can never be sure what a smiley means. And I'm kind of
proud of being literal-minded, anyway.
Jon
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
Re: Higher wattage for a resistor ever bad? Jon Kirwan Electronic Design 15 08-21-2011 04:58 AM
Re: Higher wattage for a resistor ever bad? Rich Grise Electronic Basics 0 08-17-2011 02:21 AM
Re: Higher wattage for a resistor ever bad? Rich Grise Electronic Design 0 08-17-2011 02:21 AM
Re: Higher wattage for a resistor ever bad? John Tserkezis Electronic Basics 0 08-17-2011 02:19 AM
Re: Higher wattage for a resistor ever bad? John Tserkezis Electronic Design 0 08-17-2011 02:19 AM
