Electronics Forums
Electronics Forums > Newsgroups > Electronics Newsgroups > Electronic Design > Re: Headphone Jack Install
Reply
Thread Tools Display Modes
Ken Taylor
Guest
Posts: n/a
      08-17-2003, 11:38 PM
"Larry G." <(E-Mail Removed)> wrote in message
news:(E-Mail Removed) om...
> Does anyone have any thoughts on how to safely wire a stereo headphone
> jack into a stereo TV circuit? Thanks in advance.
Does the TV have stereo line outputs? If so just get an
RCA-to-stereo-headphone adaptor cable.
Ken
Larry G.
Guest
Posts: n/a
      08-29-2003, 08:49 PM
"Ken Taylor" <(E-Mail Removed)> wrote in message news:<bhp3lv$1p4ua$(E-Mail Removed)>...
> Ken
Good point Ken. I have considered this as a first option, before
dissecting a brand new TV. I do have one set of AV outputs in the
rear of the TV(L Audio, R Audio, Video). I had a suspicion that I
would still get volume from the TV speakers, after plugging into the
rear RCA jacks with the adapter hookup. If these are true line out
jacks, I should be able to get a signal through them to my headphones,
even though the TV volume is set to zero? The jacks are not labeled
as "Line Level". It's an Apex TV, so the information for different
configurations leaves a lot to the imagination. I think the adapter
is only three or four dollars, so it would probably be a wise choice,
since the alternative option is surgery, and it's potential
complications.
LG
roma
Guest
Posts: n/a
      08-30-2003, 11:05 PM
(E-Mail Removed) (Larry G.) wrote in
news:(E-Mail Removed) om:
>> > headphone jack into a stereo TV circuit? Thanks in advance.
>> Ken
> complications.
> LG
The TV audio output level impedance matches any amplifier auxiliary input .
But as you suspect the TV sound to the speaker is not disabled .
To overcome this , I build a small stereo amplifier using two LM324 with
dual input (10K)level control ,powered by a 9 volts battery .The
amplifier is set to maximum amplification with the use of the 10K and 10uF
feed back as required .
Use RCA cables to the amplifier and a the required stereo output plug for
your headphones.
Set the TV volume output as low as possible and adjust the amplifier input
volume to suit .
With Headphone on you will not hear the TV speakers , but will be able to
use all the TV sound control to yoyur headphone .
http://members.shaw.ca/roma/ten.html
Roma
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
Headphone jack install in turntable Kroensburg Circuit Help 17 07-19-2010 08:01 AM
Tips For Installing A Headphone Jack Larry G. General Electronics 2 06-24-2009 07:32 PM
Aircraft Headphone Double Jack System Robert Electronic Basics 4 02-06-2004 08:38 PM
Thanks - headphone install - old TV LBJGH Electronic Basics 0 01-08-2004 06:07 AM
Laptop Headphone Jack Volume problem Matthew Mucklo General Electronics 1 08-01-2003 03:07 AM
