Electronics Forums
Electronics Forums > Newsgroups > Electronics Newsgroups > Electrical Engineering > Re: Grounding a generator???
Reply
Thread Tools Display Modes
SQLit
Guest
Posts: n/a
      07-07-2005, 04:50 AM
"SomeBody" <(E-Mail Removed)> wrote in message
news(E-Mail Removed). ..
> Hello,
> I have a diesel powered 10Kw generator, puts out 240V@43A.
> I have a small un-attached garage that has a sub-panel, with
> power coming from the main house. The sub panel has a grounding rod
> attached.
> I install an outdoors sub-panel, under a lean-to, where the
> generator is permanently installed. Can I use the ground rod from the
> other sub-panel to attached the generator ground too?
> A7N8X-Deluxe, AMD XP2500+ (Un-locked)
> 2x256mb Crucial PC3200 DDR ram
> Palit-Daytona Ti4200/64M AGP
Not unless you tie the new grounding point back to the main electrical
service. Then you have to decide if you want to separate the neutral and
ground in the generator. Best check with the manufacture about that.
Your going to need a transfer switch of the correct number of poles. Tying
the neutrals together can create more problems than switching the neutrals.
Example a 3 pole switch instead of a two pole.
Best check locally to see how it is done correctly.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
Re: Panel Grounding vs. Lightning Rod Grounding Crash Gordon Security Alarms 21 09-29-2008 04:35 AM
Re: Panel Grounding vs. Lightning Rod Grounding tourman Security Alarms 3 09-26-2008 04:59 AM
Re: Panel Grounding vs. Lightning Rod Grounding Jim Security Alarms 4 09-24-2008 03:11 AM
Re: Panel Grounding vs. Lightning Rod Grounding Crash Gordon Security Alarms 0 09-19-2008 02:40 PM
Need Some Grounding on "GROUNDING" John.Clement@verizonwireless.com Electronic Design 19 01-09-2004 08:26 AM
