Electronics Forums
Electronics Forums > Newsgroups > Electronics Newsgroups > Electrical Engineering > Re: Good brand of 3KW 2:1 transformer?
Reply
Thread Tools Display Modes
SQLit
Guest
Posts: n/a
      07-07-2005, 09:27 PM
"RedFox" <(E-Mail Removed)> wrote in message
news:gMfze.14198$(E-Mail Removed) link.net...
> I want to buy a 3KW 2:1 transformer and have seen one at a very
reasonable
> price - $120.
> PowerBright brand - made in China
> 220-240 volt to 110-120 volt AND from 110-120 volt to 220-240 volt.
> Features
> FREE Grounded Adapter Included ($3 Value)
> On and Off Breaker Switch
> Fuse protected
> 2 Spare Fuses Included
> 1 Year Parts and Labor Warranty
> Specifications
> Capacity 3000 watts
> Input 110/200/220/240 Volt
> Output 110/220-240 Volt
> Dimensions (W x H x D) 7.2 x 6.0 x 9.8 in.
> The specs are pretty sparse.
> Are these transformers typically the usual primary and secondary windings
> on a steel core, with no electronics? If so, they should be simple and
> reliable. With
> electronics, their reliability could be questionable, like the
Chinese-made
> Altec Lansing
> speaker system I bought a couple of years ago that went belly up. They
have
> no
> replacement components and gave me the number of .the replacement model. I
> told them
> what to do with it ;-)
> I have also seen some great looking Chinese made furniture recently.
Looked
> exactly like mahogany
> but most of it was CARDBOARD!!!
> I would rather pay more for a trafo with a good reliable brand. .
> Help appreciated
> TIA
> rf
A good brand, Acme, Square D, CH now Eaton, GE and
http://www.allbreakers.com/store.asp...d_tran_control
As for the price, that will probably be another issue.
I missed the intended use so to speculate more useless.
Don Kelly
Guest
Posts: n/a
      07-07-2005, 10:45 PM
"SQLit" <(E-Mail Removed)> wrote in message
news:B7hze.42$_(E-Mail Removed)...
> reasonable
> > price - $120.
> > Features
> > Fuse protected
> > Specifications
> > Capacity 3000 watts
windings
> > reliable. With
> Chinese-made
> > Altec Lansing
> have
> > no
I
> > told them
> Looked
> > Help appreciated
> > TIA
> > rf
The dimensions scare me. This looks pretty small for a 3Kw 120/240V unit. I
suspect that it is an autotransformer (core and windings equivalent to a
1.5KW unit - see Hammond's 1.5Kw 2 winding unit which is about the same
size!). May be fine but if so there is no isolation between the 110 and 220V
sides.
(PS Hammond units do what was required but the ones I've seen weren't noted
for good efficiency or regulation -skimp on material to keep capital cost
down)
Don Kelly
(E-Mail Removed)
remove the urine to answer
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
Design for brand wins, or brand wins. Boki Electronic Design 0 03-06-2006 07:49 AM
Build your own 3kW wind turbine Steve Spence Home Power and Microgeneration 0 08-27-2005 09:47 PM
Re: Good brand of 3KW 2:1 transformer? operator jay Electrical Engineering 2 07-12-2005 06:41 PM
3kW SMPS artem_bond Electronic Design 16 04-13-2004 08:39 AM
Ebay item??? "Hydrogen Powered 3Kw Generator - NEW" Richard W. Home Power and Microgeneration 14 09-06-2003 12:29 PM
