Electronics Forums
Electronics Forums > Newsgroups > Electronics Newsgroups > Electrical Engineering > Re: Feed Thru breakers
Reply
Thread Tools Display Modes
PCK
Guest
Posts: n/a
      07-16-2005, 11:11 AM
"321zyx" <(E-Mail Removed)> wrote in message
news:nqYBe.14378$(E-Mail Removed).. .
>I need a I.T.E. 3 pole feed thru breaker, minimum of 30 amps, and I went to
> the local electrical supply and the said they don't really make them
> anymore
> so he came up with a concoction of a breaker with lugs on one end and tabs
> on the other with lugs that slide over the tabs and some mounting bracket
> and after all that it was going to be about $150.00 and I don't want to
> spend that much. I have tried looking on the internet without much luck.
> If
> anybody can help me out please let me know. Thanks in advance.
here in ontario i use a couple of places that salvage electrical equipment
one is
http://canada411.yellowpages.ca/mp/O...047740007.html
ITE was also GE for a while and now check siemens
Paul S.
Guest
Posts: n/a
      07-16-2005, 01:10 PM
Sounds like you need a MCB (Molded Case Circuit Breaker). The have lugs on
both line and load ends
All breaker manufacturers make them.
"PCK" <(E-Mail Removed)> wrote in message
news:U6CdnatrZ972dkXfRVn-(E-Mail Removed)...
>>to
>> anymore
>> tabs
>> If
> one is
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
DAC voltage feed thru from analog to digital side namdeguerre@gmail.com Electronic Design 0 02-29-2008 02:27 PM
Paralleling L-C feed-thru filters for increased current capacity mark Electronic Design 1 08-05-2007 02:41 AM
8Kx8 static rams thru-hole 28-pin type 6264 Anders Johansson Electronic Components 4 04-11-2006 07:30 PM
Re: Feed Thru breakers SQLit Electrical Engineering 0 07-16-2005 02:49 PM
Recommendations on low temperature thru-hole 32768 xtal Bob E. Electronic Basics 2 08-09-2003 01:10 AM
