Electronics Forums
Electronics Forums > Newsgroups > Electronics Newsgroups > Electronic Design > Re: Fast, efficient IR LEDs?
Reply
Thread Tools Display Modes
Joerg
Guest
Posts: n/a
      02-05-2010, 10:20 PM
Phil Hobbs wrote:
> On 2/5/2010 2:13 PM, (E-Mail Removed) wrote:
>> On Feb 5, 8:56 am, Phil Hobbs<pcdhSpamMeSensel...@electrooptical.net>
>> wrote:
>>> I need a fast IR LED (> 20 MHz,< 50 pF) for an optical feedback gizmo.
>>> I have some Stanley DN310s, but they've been discontinued. Other
>>> possibilities are:
>>> Vishay TSFF5410 -- 870 nm, 0.% W/A typ 15 ns rise/fall, 125 pF typ
>>> Vishay VSLB3940 -- 940 nm, 0.4 W/A typ 15 ns rise/fall, 70 pF typ
>>> Panasonic LNA4905L -- 880 nm, 0.3 W/A min 30 MHz typ, no other specs
>>> Osram SFH4550 -- 850 nm, 0.5 W/A typ 12 ns rise/fall, no C spec
>>> It would be really nice to find something with a flat front facet and
>>> (especially) lower capacitance, because it has to work at quite low
>>> currents (5-10 uA).
>>> Any suggestions?
>>> Thanks
>>> Phil Hobbs
>> Isn't low current and high speed mutually exclusive, like intelligence
>> and Republicans?
> Nice try, Soup. I enjoy talking electronics too much though.
His "email address" always makes me crave miso soup and sushi. So, we
just went to the Japanese restaurant in town ...
But this time I had pork teriyaki after the miso soup. We usually have
sushi in the evenings, I can't really work after that, it's so good that
I tend to eat too much of it.
Regards, Joerg
http://www.analogconsultants.com/
"gmail" domain blocked because of excessive spam.
Use another domain or send PM.
Joerg
Guest
Posts: n/a
      02-06-2010, 05:41 PM
> On Feb 5, 2:20 pm, Joerg <inva...@invalid.invalid> wrote:
>>>>> possibilities are:
>>>>> currents (5-10 uA).
>>>>> Any suggestions?
>>>>> Thanks
>>>>> Phil Hobbs
>>>> and Republicans?
>> Regards, Joerg
> Sushi doesn't make for an evening meal. Just too light, even when
> supplemented with miso soup. It's better for lunch.
4-5 rolls (servings) with 4 people and I am really stuffed afterwards.
But it's delicious.
> Getting back to electronics., this is really an i=c*dv/dt issue. It
> seems to me all you can do is reduce C if current is limited.
If Phil has to switch constantly, yes. Otherwise there could be a
"spiking circuit" that swings the C with gusto.
Regards, Joerg
Joerg
Guest
Posts: n/a
      02-06-2010, 08:13 PM
>>>>>>> gizmo.
>>>>>>> possibilities are:
>>>>>>> and
>>>>>>> currents (5-10 uA).
>>>>>>> Any suggestions?
>>>>>>> Thanks
>>>>>>> Phil Hobbs
>>>>>> intelligence
>>>>>> and Republicans?
>>>> that
>>>> Regards, Joerg
>> But it's delicious.
> It's inside a feedback loop that needs to have >1 MHz bandwidth, so it's
> more a loop stability vs bandwidth issue. There are alternatives, but
> they're all more complicated than what we've got. I'd probably prefer
> to trade off efficiency rather than speed and capacitance.
Then you'll probably be in the market for the good stuff. This is an
example of one I've used in an optical feedback situation. I only needed
a little under 100MHz BW but it could have given me a lot more:
http://www.excelight.com/pdf/device/...00-x(revC).pdf
Regards, Joerg
JosephKK
Guest
Posts: n/a
      02-07-2010, 05:29 PM
>>>>>>>>> gizmo.
>>>>>>>>> possibilities are:
>>>>>>>>> specs
>>>>>>>>> facet and
>>>>>>>>> (especially) lower capacitance, because it has to work at quitelow
>>>>>>>>> currents (5-10 uA).
>>>>>>>>> Any suggestions?
>>>>>>>>> Thanks
>>>>>>>>> Phil Hobbs
>>>>>>>> intelligence
>>>>>>>> and Republicans?
>>>>>> His "email address" always makes me crave miso soup and sushi. So,we
>>>>>> that
>>>>>> Regards, Joerg
>>>> But it's delicious.
>>> it's more a loop stability vs bandwidth issue. There are alternatives,
>>> but they're all more complicated than what we've got. I'd probably
>>> prefer to trade off efficiency rather than speed and capacitance.
>Hopefully not--that's megahertz, not gigahertz. But I do want to be
>able to work down at 500 nA or 1 uA.
>Cheers
>Phil Hobbs
You may wish to consider a laser diode operating below critical current.
Joerg
Guest
Posts: n/a
      02-07-2010, 09:10 PM
>>>>>>>>>>> feedback
>>>>>>>>>>> gizmo.
>>>>>>>>>>> possibilities are:
>>>>>>>>>>> pF typ
>>>>>>>>>>> typ
>>>>>>>>>>> specs
>>>>>>>>>>> facet and
>>>>>>>>>>> quite low
>>>>>>>>>>> currents (5-10 uA).
>>>>>>>>>>> Any suggestions?
>>>>>>>>>>> Thanks
>>>>>>>>>>> Phil Hobbs
>>>>>>>>>> intelligence
>>>>>>>>>> and Republicans?
>>>>>>>> So, we
>>>>>>>> usually have
>>>>>>>> that
>>>>>>>> Regards, Joerg
>>>>>> afterwards.
>>>>>> But it's delicious.
>>>>> It's inside a feedback loop that needs to have>1 MHz bandwidth, so
>>>> needed
>>> Cheers
>>> Phil Hobbs
> Thanks, I know that trick. Thing is, I need a 5000:1 output power
> range, or thereabouts--i.e. 3 uW - 15 mW. The bandwidth is going to
> be way more than enough at the high end, and the problem is to keep the
> feedback poles from crossing at a frequency where there's over-unity gain.
> There are other approaches possible that require different approaches,
> but they require more tweaking--e.g. two ranges with two LEDs using
> different optical coupling fractions.
Or have an offset in there where the LED (or LD below lasing threshold
as Joseph suggested) runs at a regulated base power level. BTDT, but in
my case that was in order to remain above lasing threshold.
Regards, Joerg
Joerg
Guest
Posts: n/a
      02-07-2010, 10:10 PM
Phil Hobbs wrote:
>>>> current.
>>> range, or thereabouts--i.e. 3 uW - 15 mW. The bandwidth is going to be
>>> gain.
> This gizmo is an advanced photoreceiver that maintains
> shot-noise-limited performance (2 dB above shot noise) from ~10 nA to
> 100 uA, with an honest 1 MHz bandwidth over (almost) the whole range.
> Doing that down near the minimum photocurrent is a real genuine parlour
> trick.
Luckily I never had to do that. BW was always tens of MHz but they gave
me plenty of amplitude to work with. However, up there on that pedestal
it had to be super low noise because we had to extract modulation.
> The ones uses two photodiodes wired in series (!) to get a
> sub-Poissonian photocurrent to null out the primary photocurrent. That's
> a trick I've never seen before, so I might have invented it. It
> obviously requires some careful feedback to keep the currents in
> balance, but the result is a nice linear photoreceiver with almost no
> additional input capacitance.
Neat! But now you've spilled the beans and can't patent it :-(
Patents aren't worth much anyhow these days. Seems like most of what
they do is trigger patent trolls who then bog down whole businesses.
> Two photodiodes in series have the same photocurrent but *half the shot
> noise*, so the cancellation current is actually quieter than the
> photocurrent, without needing resistive degeneration. (I also manage to
> keep all 300-kelvin resistors out of the signal path, which is key.)
> The optical feedback is sort of a poor-man's photomultiplier: most of
> the LED light goes to another photodiode, driving an ordinary TIA which
> produces the output. It's a really sweet solution overall, with the one
> disadvantage that it needs two tweaks.
I assume you mean the balancing of the two PDs in series. Is there no
way to servo that? Maybe by occasionally interrupting the optical path?
Regards, Joerg
JosephKK
Guest
Posts: n/a
      02-08-2010, 06:08 AM
>>>>>>>>>>> gizmo.
>>>>>>>>>>> possibilities are:
>>>>>>>>>>> Vishay VSLB3940 -- 940 nm, 0.4 W/A typ 15 ns rise/fall, 70 pFtyp
>>>>>>>>>>> specs
>>>>>>>>>>> facet and
>>>>>>>>>>> currents (5-10 uA).
>>>>>>>>>>> Any suggestions?
>>>>>>>>>>> Thanks
>>>>>>>>>>> Phil Hobbs
>>>>>>>>>> intelligence
>>>>>>>>>> and Republicans?
>>>>>>>> that
>>>>>>>> Regards, Joerg
>>>>>> But it's delicious.
>>> Cheers
>>> Phil Hobbs
>Cheers
>Phil Hobbs
Perhaps accurately controllable optical attenuation can be done?
Don't know myself but it sounds possible to me.
Joerg
Guest
Posts: n/a
      02-08-2010, 05:05 PM
Jim Thompson wrote:
> On Sun, 07 Feb 2010 14:10:48 -0800, Joerg <(E-Mail Removed)>
>>>>>> current.
>>>>> gain.
>>> trick.
> Sounds fascinating! More info please ;-)
I'd have to think about Phil's circuit but would need more info for that
(and time ...). My case with the single diode, not at liberty to say.
But we built dozens and they all cal'd automagically.
Regards, Joerg
Joerg
Guest
Posts: n/a
      02-08-2010, 05:14 PM
Phil Hobbs wrote:
>>>>>> current.
>>>>> gain.
>>> parlour trick.
>>> That's a trick I've never seen before, so I might have invented it. It
> I can patent it for the next year, at least in the USA. I might do
> that, we'll see.
Just don't wait until T minus 360 days :-)
>>> shot noise*, so the cancellation current is actually quieter than the
>>> to keep all 300-kelvin resistors out of the signal path, which is key.)
>>> which produces the output. It's a really sweet solution overall, with
>>> the one disadvantage that it needs two tweaks.
> There's a bias feedback loop that looks after that. It doesn't have to
> be that accurate since the PDs run at 14V of reverse bias--keeping the
> junction of the two PDs reasonably still is all that's required.
Good, so it seems automatic. 14V sound like a white-knuckle ride :-)
> The tweaks are for making sure that the two photocurrents are reasonably
> close to begin with, and to govern the poorly specified efficiency of
> the LEDs. (IR LEDs have output power specs that are almost as loose as
> the V_T spec of your average JFET.)
> You should be able to buy them in a couple of months, if all goes well.
> (No home should be without one, after all.)
Hehe, that's what I used to say as well. No home without a fully
certified cardiology ultrasound scanner. And another one for ob/gyn if
the freshly married couple is inclined to ...
Regards, Joerg
Joerg
Guest
Posts: n/a
      02-08-2010, 05:15 PM
>> Cheers
>> Phil Hobbs
It can, but it's expensive.
Regards, Joerg
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
Re: Fast, efficient IR LEDs? Joerg Electronic Design 0 02-05-2010 06:37 PM
Re: Fast, efficient IR LEDs? Fred Bartoli Electronic Design 0 02-05-2010 05:08 PM
Re: LEDs vulnerable to physical shock? Don Klipstein Electronic Design 1 11-17-2009 01:46 PM
UV LEDs die fast? John Bokma Electronic Basics 4 06-26-2005 07:50 PM
Do LEDs become older after being used for 1 year? Q Gang Electronic Components 8 10-31-2004 09:00 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33
