(E-Mail Removed) (indago)
050620 1126 -
phil-news-(E-Mail Removed) posted:
On Mon, 20 Jun 2005 02:15:39 GMT indago <(E-Mail Removed)> wrote:
| You don't suppose that you could plug this 240 volt plug into one of
the | T-slot 110 volt outlets do you?
No. A NEMA 6-20P plug will not mate with a NEMA 5-20R receptacle. With
the configuration oriented ground pin up, facing the receptacle, the
left blade is the hot/line/phase blade on the 5-20R and is oriented
vertical. The corresponding blade on a 6-20P is horizontal.
Then, you don't have any of these T-slot plug appliances in your house?
Does anybody here have a T-slot plug appliance in their house?
I've got one, it's next to a duplex outlet with a 3 outlet plate in the
same box nest to a window in my room., I think they are here in the
event we got a 220V AC unit all we'd need to do is change the Circuirt
Breaker & the neutral over to it..... I don't think it's a good idea,
since a 120V plug fit's into it., if one is not careful you'd end up
ruining your equipment. Žoy
