Electronics Forums
Electronics Forums > Newsgroups > Electronics Newsgroups > Electrical Engineering > Re: electric outlet for window AC question
Reply
Thread Tools Display Modes
Roy Q.T.
Guest
Posts: n/a
      06-17-2005, 06:07 PM
On Fri, 17 Jun 2005 02:16:10 -0400 Roy Q.T. <(E-Mail Removed)> wrote:
| But your instance that 15 amp receptacles are not permitted on 20 amp
| circuits despite a clear and obvious NEC rule that allows it, is not |
earning you any credibility here. [ * also one that disallows it ]
| Phil: I think you were exposed to one Rotgen too many back in the |
days., I don't have any instance left, but, you should switch to decaf |
anyway- ?oy
I was exposed to the text of the NEC. I suggest you get yourself exposed
to it as well. Start with 210.21(B)(3). Read the 2nd line of the table.
**** That ! I've got it right.,
I am through with this topic, you are a bunch of Illogical hard heads
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
electric outlet for window AC question ReadyToPuke Electrical Engineering 56 06-28-2005 07:51 PM
Re: electric outlet for window AC question Roy Q.T. Electrical Engineering 2 06-14-2005 01:22 AM
Re: electric outlet for window AC question Roy Q.T. Electrical Engineering 0 06-09-2005 07:43 AM
Re: electric outlet for window AC question Roy Q.T. Electrical Engineering 0 06-08-2005 05:44 AM
Re: electric outlet for window AC question Roy Q.T. Electrical Engineering 0 06-08-2005 05:29 AM
