On Thu, 5 Apr 2012 08:12:03 -0700 (PDT), gilak <(E-Mail Removed)>
wrote:
>I wonder whether someone could please help me in devising or buying a
>system for displaying changes in resistance caused by stretching a
>conductive material. I have got the material and able to measure the
>changes in resistance using an ohm meter. I am a computer programmer
>but know nothing about electronics. Ideally I want to be able to read
>data via USB port and then develop my own program to display the
>changes. Any help on this will be appreciated.
The simplest way to start would be to use a USB data logger. Connect the
conductive material and one other resistor in a "voltage divider"
configuration, and measure the voltage from the junction between the
two, referenced to ground. Then do the math to work backwards to the
resistance.
<http://www.mccdaq.com/usb-data-acquisition/USB-1208-Series.aspx> is one
option. It includes a basic data logging application as well as the
necessary DLLs for you to write a more sophisticated app, if desired.
The presence of (controllable) analog outs as well as a 5V output would
make your project pretty easy, requiring just this pod plus a resistor
and a little software.
http://www.dataq.com/usb-data-acquis...quisition.html is
another popular source. I don't think they're as flexible as the MCC
pods but they are an option.
Rich Webb Norfolk, VA
