Electronics Forums
Electronics Forums > Newsgroups > Electronics Newsgroups > Electronic Equipment > Re: device for testing UK adsl signal
Reply
Thread Tools Display Modes
PeterD
Guest
Posts: n/a
      07-01-2009, 02:16 PM
On Wed, 1 Jul 2009 11:18:59 +0100, "tg" <(E-Mail Removed)>
wrote:
>in my job fixing internet connections (here in the UK) I constantly collide
>with bad adsl signals and dodgy home telephone wiring and I need a device
>that tests the presence/level/quality of the adsl signal on the line -
>something I can plug into the BT socket and get an accurate reading.
These (DSL) line test systems have existed and do exist. They are
available to industry, but are rather expensive, so you need to reveal
your budget before I'll bother researching and posting a list. We're
talking tens of thousands, IIRC for a reasonable tester.
> I
>specifically want to test for any deterioration in the adsl signal in
>extension sockets coming off the main socket.
>I figured there must be a gadget somewhere that can do this but I've never
>seen one.
Consider a simple signal strength meter, with a 20 KHz high pass
filter.
Study DSL some more. Understand the bands used, the frequencies used.
Then you can come up with something realistic to test with, assuming
your budget doesn't allow for a dedicated tester.
But... Why are you running DSL to multiple sockets? Catch the DSL line
as it enters the premises and run the modem there, then split the POTS
line to the sockets as needed. Don't try to run the DSL places where
it is 'not needed'.
> I've heard the argument about using routers but I'm not
>interested in that,
What does a router have to do with this problem. That's an ethernet
device, and knows zip, zero, nothing, nada about DSL.
>I'd rather get a dedicated device. Does anyone know of
>such equipment?
>thanks for any advice.
Brian Mc
Guest
Posts: n/a
      07-01-2009, 02:28 PM
In uk.telecom.broadband PeterD <(E-Mail Removed)> wrote:
: What does a router have to do with this problem. That's an ethernet
: device, and knows zip, zero, nothing, nada about DSL.
I had presumed this meant that most routers will give an analysis of the DSL
line (S/N levels, sync speeds etc.) on their control interface.
Adrian C
Guest
Posts: n/a
      07-01-2009, 02:35 PM
.... If the router is a modem-router (as most are these days used in the
context of ADSL)
Adrian C
reader443.eternal-september.org
Guest
Posts: n/a
      07-01-2009, 03:52 PM
"PeterD" <(E-Mail Removed)> wrote in message
news:(E-Mail Removed)...
>>collide
>> I
>>seen one.
> filter.
> it is 'not needed'.
>>interested in that,
>>such equipment?
I see your logic, but most domestic grade routers sold in the UK
are hybrid devices and include a DSL modem and often a wireless
access point too. I suspect you are not in the UK, are things
different where you are?
Oh and we pronounce it "rooter" and not "rawter".
I certainly carry such a device for diagnostic purposes.
Graham.
%Profound_observation%
The Natural Philosopher
Guest
Posts: n/a
      07-01-2009, 07:55 PM
Well it depends if you mean by router a 'generic device for machining
wood' a ' device that purely routes computer network traffic' or ' A
device thet purely routes ethernet traffic or 'a device that not only
routes IP traffic but also does NAT, and contains a DSL modem as well'
I THINK the definition is a device that maintains a routing state table
of some sort, that connects networks at a layer *above* the transport
address level. This clearly marking where an ethernet switch ends: That
being a device that routes Ethernet packets irrespoective of what
protocol is layered above.
Strictly a 'broadband router' is hardly a router at all. Its a DSL modem
with ATM support and almost (but not quite) a bridge between the CPE and
the ISP termination equipment.
Guest
Posts: n/a
      07-01-2009, 07:57 PM
ROWTER shirley?
Drilling holes and trepanning into peoples' mind sets perhaps? ;-)
Adrian C
Guest
Posts: n/a
      07-02-2009, 12:20 AM
There is a nation of sniggering ozzies having a great and crude time
with the word router and the pronounciation as rooter ...
Indeed, you do ;-)
Adrian C
Graham.
Guest
Posts: n/a
      07-02-2009, 12:35 AM
"tg" <(E-Mail Removed)> wrote in message
news:(E-Mail Removed). uk...
> "reader443.eternal-september.org" <(E-Mail Removed)> wrote in message
> news:h2ftd8$j30$(E-Mail Removed)...
> I am in the UK
I know you are, my remark was addressed to "PeterD"
Graham.
Graham.
Guest
Posts: n/a
      07-02-2009, 01:08 AM
>> it is 'not needed'.
> I can't do that. If the customer wants the adsl 'there', I've got to make
> it work there.
Of course you do, but that is not at odds with Peter's advice.
Ideally use a filtered faceplate on the master socket and
connect all the extension sockets to the filtered side.
Only the socket for the router (wherever the customer wants it)
should be direct from the line (use an RJ11 plate to prevent a phone
being plugged in).
Using multiple filters, one on each POTS device is not ideal,
despite what some ISPs might have you believe.
Tackling installations, especially marginal ones, using this
central filter approach is more important than investing in expensive
test equipment.
Graham.
PeterD
Guest
Posts: n/a
      07-02-2009, 02:23 AM
On Wed, 1 Jul 2009 15:52:21 +0100, "reader443.eternal-september.org"
US, and they go either way here. I use stand alone DSL modems, and
then feed a router which is a seperate box. Oh, and at least around
here, we say rooter too.
I know of some that do give diagnostic information, but I'd be
reluctant to depend on it.
But again, why wire DSL to all the phone jacks, instead do the jack
nearest the entry point, put the DSL modem (or router/modem) there,
and put the rest of the house's sockets on the other side of a DSL
filter.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
Re: device for testing UK adsl signal Adrian C Electronic Equipment 0 07-01-2009 11:34 AM
Prevent signal when device is turned on grubertm@gmail.com Electronic Basics 10 03-23-2007 09:08 PM
wireless signal generation device Jon Slaughter Electronic Design 1 01-01-2007 03:28 PM
!00 Mhz sine to (TTL or lock signal) translator Device? LOC Electronic Components 5 10-23-2004 03:32 PM
Testing the presence of DSL signal with an oscilloscope AC/DCdude17 Electronic Basics 4 07-29-2003 12:30 AM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33
