Electronics Forums
Electronics Forums > Newsgroups > Electronics Newsgroups > Electrical Engineering > Re: DC Wave Questions
Reply
Thread Tools Display Modes
John Popelish
Guest
Posts: n/a
      06-11-2005, 01:05 AM
(E-Mail Removed) wrote:
> 2 questions about a fully DC Sine Wave....let's suppose you have a DC
> Sine wave which varies from +5V to +15V peak-to-peak going into a load
> with R, L, and C components.....
> Question #1:
> Is the load's impedance a function of R, L, and C (and wave frequency)
> or is it simply just R (i.e. Z=R)? In other words does non-resistive
> impedance (L + C) really only matter with an AC signal OR anytime
> voltage varies periodically (even if it is all DC)?
> Question #2:
> Would a "regular" negative peak detector ciruit, like shown here:
> http://www.elektroda.net/cir/index/D...CTOR.htmgative
> work for the DC Wave described? Will it output +5V or do negative peak
> detectors only work for AC signals?
> Thank you.
According to Fourier analysis, any repeating waveform can be
decomposed into harmonically related and appropriately phase shifted
sine waves and also a DC component. If all the components involved
are linear, then they react to each of these components,
independently, and the result is the linear sum of all those
reactions. So the capacitors react to the DC component as open
circuits, and the inductors as short circuits. At all frequencies,
the resistances follow ohms law, and at each AC harmonic, the
inductances and capacitances react in their normal frequency dependent
ways.
Throw in one nonlinear component, like a diode, and you have to do a
completely different kind of analysis.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
Full wave square wave generator from dual led flasher. ngdbud@hotmail.com Electronic Basics 4 08-26-2005 11:26 AM
Re: Wave-to-Wave Recording. Noisy on Low Volume! Geoff Wood General Electronics 0 04-01-2004 04:15 AM
Re: Is an electrical pulse through a wire a longitudinal wave or a transverse wave? EEng Electronic Design 1 07-29-2003 04:57 PM
Re: Is an electrical pulse through a wire a longitudinal wave or a transverse wave? George R. Gonzalez Electronic Design 0 07-29-2003 01:02 PM
Re: Is an electrical pulse through a wire a longitudinal wave or a transverse wave? Kevin McMurtrie Electronic Design 0 07-29-2003 09:41 AM
