Electronics Forums
Electronics Forums > Newsgroups > Electronics Newsgroups > Electrical Engineering > Re: DC motors
Reply
Thread Tools Display Modes
Re: DC motors
SQLit
Guest
Posts: n/a
      08-09-2005, 06:20 PM
"smitha4u" <(E-Mail Removed)> wrote in message
news:(E-Mail Removed) oups.com...
> Hi Guys
> Can any one suggest what are the various methods of performing bench
> test for a 20 Kw(25HP) DC electrical variable speed motor.
> Thank you
> Regards
> smitha
What are you trying to do?
I have found that testing can be done with out removing the motor if you
have the right equipment. Having the spare 20 kw drive around is just not an
opinoin where I work.
SQLit
Guest
Posts: n/a
      08-09-2005, 09:01 PM
not an
> I need to write a test plan/ procedure how in vaious methods we can
> bench test a 20Kw motor rated with 260-350 volts. we have motor in our
> lab so we need to test the performance of that. do you have any
> suggesstions for that
> thanks
> regards
Your going to need something substantial to bolt it down. Torque on a 25 hp
motor can surprise ya. Next your going to need a load. I suggest a
generator and resistive heaters in stages that can be switched on and off at
will. This load should be go beyond the service factor of the motor. The lab
should be able to be cooled and heated along with the humidity levels so
that you can actually see real life applications. Motors are installed in
some pretty dirty, ugly hot and humid places. All that has to be taken into
consideration.
Your going to need some calibrated test equipment. Volts, amps, rpm,
megger, possibly a hi pot. I have used a hi pot on low voltage motors
because that is the method that the engineer asked for, usually you do not.
Your going to need a calibrated power supply so you can do high and low
voltage.
Sure hope management has some deep pockets. This course is not going to be
cheap.
http://www.avotraining.com/training/index.asp
http://www.reliabilityweb.com/fa/motor_testing.htm
http://www.magtrol.com/motortesting/
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
Stepping Motors, Hobby Motors for Sale goshgee@nowhere.com Electronic Components 1 12-26-2006 05:48 PM
Stepping Motors, Hobby Motors for Sale goshgee@nowhere.com Electronic Repair 0 12-26-2006 02:56 PM
FS: DC Motors, Stepping Motors Surplus and Salvage therepairman Electronic Repair 0 12-12-2004 05:05 PM
FS: DC Motors, Stepping Motors Surplus and Salvage Kristy Electronic Repair 0 10-06-2004 01:24 AM
FS: DC Motors, Stepping Motors Surplus and Salvage Kristy Electronic Components 0 10-06-2004 01:23 AM
