Electronics Forums
Electronics Forums > Newsgroups > Energy Generation > Photovoltaics > Re: DC to AC Inverter Input range.
Reply
Thread Tools Display Modes
you
Guest
Posts: n/a
      04-03-2012, 06:41 PM
In article
<7523643e-078c-4101-aef0-(E-Mail Removed)>,
bob haller <(E-Mail Removed)> wrote:
> my best friend has a windmill and solar panels on a battery bank with
> inverters to run CF lights.
> as the voltage fluctuates the harbor freight inverters go off and on,
> its very annoying
That is what you get when you buy cheap Chinese Inverters.... cheap
Crap... If you had invested in OutBack gear you wouldn't have these
issues....
Mho
Guest
Posts: n/a
      04-05-2012, 07:17 PM
Baloney!
Inverters may have larger tolerances but when there are clouds and no DC,
you get no AC either.
Try reading the OP's text and stop hijacking his thread.
"you" wrote in message news:you-(E-Mail Removed)...
issues....
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
6.5 Inch Stand-alone Monitor, Two Video Input, One Audio Input dirskyster@gmail.com Electronic Design 0 04-09-2008 01:26 PM
OPA657 oscillates with no input,but works with the input Vitaliy Electronic Design 13 06-18-2006 08:41 AM
4 input NAND w/ 2 input NANDs? Shawn Electronic Basics 7 09-27-2005 02:37 PM
Input electronic signal to sound card input ? boki Electronic Design 4 10-16-2004 12:08 PM
Why PMOS input transistors are usually have lower flicker noise in OPAMP input pair? Boki Electronic Design 1 07-18-2003 03:14 PM
