refigh wrote:
> hi,
> I need a series current limiter circuit. the characteristic which I
> need is that circuit has very low resistance and also limit the
> current from going too high,
> I want to use it as current protect for a circuit.
> I don want to use fuse because it broken in high current. I also dont
> want to feed back from any other point of circuit so I can use
> something like switch.
When you say high current, to me, that is in the hundreds to
thousands of amps at some voltage far above 100 volts..
Clarification of those specifications will make it possible
to better assist you.
Jamie
