Electronics Forums
Electronics Forums > Newsgroups > Electronics Newsgroups > Electronic Basics > Re: current limiter circuit
Reply
Thread Tools Display Modes
Phil Allison
Guest
Posts: n/a
      07-05-2011, 06:10 AM
"refigh"
> hi,
> I need a series current limiter circuit. the characteristic which I
> need is that circuit has very low resistance and also limit the
> current from going too high,
> I want to use it as current protect for a circuit.
> I don want to use fuse because it broken in high current. I also dont
> want to feed back from any other point of circuit so I can use
> something like switch.
** This might be what you need.
http://www.littelfuse.com/resettable-ptcs.html
Don't be afraid to give us the details of what you are doing.
Get much better advice that way.
..... Phil
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
help with LM317T current limiter circuit teslahed Circuit Help 6 01-19-2012 10:18 AM
Re: current limiter circuit P E Schoen Electronic Basics 1 07-07-2011 05:39 AM
Re: current limiter circuit Jamie Electronic Basics 0 07-05-2011 11:06 PM
Re: current limiter circuit Rich Grise Electronic Basics 1 07-05-2011 09:38 PM
Current limiter or current booster Claudio Bonavolta Electronic Basics 4 01-28-2004 09:16 AM
