Electronics Forums
Electronics Forums > Newsgroups > Energy Generation > Photovoltaics > Re: Connection between Charge Controller & Inverter
Reply
Thread Tools Display Modes
George Ghio
Guest
Posts: n/a
      04-11-2006, 07:43 AM
Because in a stand alone system the inverter may draw 200Amps or more
from the batteries and the charge controller would not handle this
amount of current draw.
Charge Controller = Input
Inverter = Output
Two different jobs done by two different machines.
Siddhartha wrote:
> In a Solar Stand Alone Off-grid AC System, Inverter is generally
> connected to battery and not through Charge Controller DC load output.
> Why is it so?
> Regards.
> Siddhartha
George Ghio
Guest
Posts: n/a
      04-16-2006, 12:10 AM
There is nothing stopping you from using the regulators load circuit to
run the inverter.
Of course the load side of a regulator may only provide 5 to 20 amps.
This means that the chances of sudden death of the regulator is likely.
There are many regulators that will allow you to programme everything
you want. One such reg is the PL series from plasmatronics. You can
download the full manual from their site. Just do a google for
Plasmatronics. These are just one example. There are other regs that do
as much or more.
If you need to switch off the inverter use a relay on the regs load to
switch the inverters AC output.
Connecting the inverter to the load of a reg is not a good idea. Please
do not do it.
Siddhartha wrote:
> Hi George,
> If the load is not a motor load where there is a high starting current,
> what will happen if I connect the Inverter at the load output terminal
> of Charge Controller. If the load is simple like small telecom
> continuous AC load, do you think Inverter will draw more current than
> required. Many small inverters do not have field adjustable LVD (low
> voltage disconnects) and we have to set the LVD at Charge Controller.
> Apart from that there are lot of Telecom customers want lot of alarm
> output and high voltage alarm, low voltage alarm, module failure alarm
> etc. They want remote monitoring of those alarms. Most of the small
> inverter do not have those facilities. In these cases there is not
> other option but to connect the inverter at the DC load output of
> Charge Controller.
> Regards.
> Siddhartha
>>Inverter = Output
>>>Why is it so?
>>>Regards.
>>>Siddhartha
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
Re: Inverter Charger & Charge Controller Coordination Bughunter Home Power and Microgeneration 1 11-20-2006 10:52 PM
Re: Inverter Charger & Charge Controller Coordination Derek Broughton Home Power and Microgeneration 0 11-14-2006 01:31 PM
Re: Inverter Charger & Charge Controller Coordination wmbjk Home Power and Microgeneration 0 11-13-2006 11:38 PM
Re: Connection between Charge Controller & Inverter samc Photovoltaics 0 04-11-2006 09:02 AM
is total charge always simply +charge + -charge? David Virgil Hobbs Misc Electronics 4 04-18-2004 04:59 PM
