Electronics Forums
Electronics Forums > Newsgroups > Electronics Newsgroups > Electrical Engineering > Re: Connecting Portable Generator To A Service Entrance Panel
Reply
Thread Tools Display Modes
SQLit
Guest
Posts: n/a
      07-06-2005, 10:06 PM
"MPO" <(E-Mail Removed)> wrote in message
news:(E-Mail Removed) oups.com...
> I recently moved a small building to a ranch where there is no
> electricity service. The building had been connected to the power
> company and has a Service Entrance Panel on it. I want to connect it to
> a 5500 Watts 120/240 Volt Generator. The Generator has a bonded
> neutral. The neutral and ground are bonded at the Service Entrance
> Panel. Because the Generator has a bonded neutral and the Service
> Entrance Panel ground and neutral are bonded, my question is this.
> How should I connect the generator at the Service Entrance Panel?
> Since the Generator will be the only power supply I was trying to avoid
> buying a Transfer Switch. I was going to "unbond" the neutral and
> ground at the Service Entrance Panel and connect the 2 power leads,
> neutral and ground from the Generator to the corresponding connections
> on the Service Entrance Panel. Will this work or am I screwing up?
> Thanks for your help.
Does the generator have a overcurrent device? like a 2 pole breaker?
If it does then separate all of the grounds and neutrals in the service, and
drive a ground rod for the generator and run 2 hots and a neutral and ground
to feed the panel.
I would hesitate to tell you to unground the neutral at the genny as I do
not know how it is wound and doing that may be a problem for the generator.
As long as you do not have two sources of power you do not need a transfer
switch.
Some large weather proof twist lock plugs could be used for portability and
safety for the generator. ( if you take the genny with you it, will be less
likely to be stolen )
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
Residential service entrance power drop repair? John E. Electronic Repair 27 10-29-2006 06:53 AM
Residential service entrance power drop repair? John E. Misc Electronics 21 10-29-2006 06:53 AM
Service entrance/Main panel upgrade Mike Martin Electrical Engineering 7 01-11-2006 07:22 PM
NEC service entrance ???????? Chief McGee Electrical Engineering 7 08-02-2004 09:23 PM
Re: Grounding of Neutral at Service Entrance J. B. Wood Electrical Engineering 0 08-18-2003 04:59 PM
